Offline tnx jake
#1 Posted : 26 April 2005 06:36:38(UTC)
tnx jake
I have a questions regarding boosters. I use the 6017. For many years I was told that there should be insulation on the center rail between the various sections that boosters feed. Today, quite by accident, I hooked up two boosters to the same section and there does not appear to be any problem, arcing, etc. All of the power supplies to the IB and the boosters are in phase.
Has anyone had any experience with this?
Jack
Offline nico van zon
#2 Posted : 26 April 2005 10:04:14(UTC)
nico van zon
Of course both supplies are in phase, and in normal operation there is no problem.
The real problem comes when you get a short somewhere on the layout. Then the combined power of both boosters gets to the track. You wlll have a short circuit current of 6 amps instead of 3 amps.
That's the only reason why you should isolate sections.
Offline tnx jake
#3 Posted : 26 April 2005 10:19:02(UTC)
tnx jake
Nico,
Of course, thank you. I have isolated all booster sections.
Jack
Offline perz
#4 Posted : 26 April 2005 10:40:29(UTC)
perz
There may also be a bit of unnecessary power consumption if two boosters are hooked up to the same segment. The boosters may have slightly different delay and they will "fight against eachother" each time the voltage changes direction. If boosters are identical and cabling is reasonably short the problem shouldn't be too big though.
#5 Posted : 26 April 2005 11:41:30(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by tnx jake
<br />hooked up two boosters
[:p] Running several boosters yours must be one big nice layout. Please give us some pics, Jack !
Offline rschaffr
#6 Posted : 26 April 2005 15:55:35(UTC)
rschaffr
Jack: I had a bad (or incorrectly installed) insulator between two section for some time (I don't know how long). I found it when I was trying to identify all the wires and their destinations. (All right...I know I should have done that when I installed them, but I didn't [:(]). I don't know how long the situation existed but it caused no apparent problems. I am using a mix of IB, 2 LDT boosters, and two 6604's configured as boosters. The short was between an LDT and a 6604. After I found that, I decided to remove all the annoying pickup shoe lifters between segments. I don't like them and I figure if I ran for some time with two segments hardwired together, a momentary connection can't hurt.
-Ron
Offline tnx jake
#7 Posted : 26 April 2005 19:31:02(UTC)
tnx jake
John,
I am running five boosters and an IB which gives me plenty of power for car lighting, etc. My last layout was underpowered so this time I am not taking any chances. Unfortunately, I do not own a camera so no pictures will be forthcoming.
Jack
Offline tnx jake
#8 Posted : 26 April 2005 19:34:13(UTC)
tnx jake
Ron,
Thanks for the imput. I have now insulated all sections by the center rail. I have never used the pick up shoe lifters as I don't think they are necessary with digital. The momentary crossing of the booster sections by the shoe should not be a problem unless maybe you got a giant short at that very moment. Even on their big layout at the Toy Fair, Marklin does not use them.
Jack
#9 Posted : 01 May 2005 18:46:59(UTC)
<br />Nico,
Jack
Thats correct,same as mine.
DIY Boosters for CS3?? (Digital)
by BenPerr Today at 04:37:38(UTC)
Recall of Märklin boosters 60175 (Digital)
by Unholz 29/07/2022 15:08:29(UTC)
Using boosters with MS2 (General MRR)
by Sean McClaymore 08/04/2022 11:32:08(UTC)
How to connect boosters please (Model railroad wiring)
by DV 25/11/2021 04:07:24(UTC)
CS3 with multiple boosters (Digital)
by Klarsyn 17/09/2020 17:01:47(UTC)
Old Transformers and boosters (Digital)
by Drjoe11 25/08/2018 19:59:56(UTC)
Connecting CS2, L88, Boosters (Digital)
by Harvey 20/02/2017 16:32:03(UTC)
Boosters and free booster recall/upgrade (General MRR)
by baggio 24/01/2017 05:37:59(UTC)
Boosters, power supplies and overload situations (Digital)
by sjlauritsen 15/11/2014 10:30:33(UTC)
Rocker insulator(s) needed for separate boosters (Model railroad wiring)
by michelvr 30/10/2014 15:51:44(UTC)
Boosters and emergency stop (Digital)
by sjlauritsen 10/09/2014 10:04:06(UTC)
60215 compatible Boosters (Digital)
by Hackcell 27/01/2014 00:00:01(UTC)
Connecting Mobile Station to non-mfx boosters (Digital)
by Gregor 05/08/2013 20:43:43(UTC)
"Large" layouts and boosters (Digital)
by PMPeter 20/04/2013 05:50:47(UTC)
Extra boosters with the CS2 (Digital)
by charles Sharpe 17/04/2013 05:50:54(UTC)
boosters and cs2 and electrical shorts (Digital)
by Andreas K 16/11/2012 12:34:27(UTC)
Power - Boosters? (Model railroad wiring)
by NewMB 19/06/2012 16:44:02(UTC)
Marklin CS1, 6017 Boosters & MFX loco (Digital)
by ycliew 27/12/2011 11:34:18(UTC)
Ecos 1 and power 3 boosters (Digital)
by pab 20/11/2011 10:57:05(UTC)
Layouts with boosters and MS2 and CS2 (Digital)
by Kodiak 28/04/2010 11:26:36(UTC)
CS, Boosters and ski-lifters (Digital)
by mjrallare 24/10/2009 20:27:05(UTC)
Homemade boosters (Digital)
by rschaffr 11/04/2009 01:30:22(UTC)
Grounding betw. transformers connected to boosters (Digital)
by svgeorgiad 28/03/2009 13:15:07(UTC)
Difference between 60173 and 6015/17 boosters? (Digital)
by mjrallare 09/01/2009 18:13:12(UTC)
CS/ New Boosters (Digital)
by charles Sharpe 27/11/2008 20:33:22(UTC)
CS & Boosters (Digital)
by David Dewar 28/06/2008 17:56:23(UTC)
Power/boosters (Digital)
by charles Sharpe 23/02/2008 21:59:27(UTC)
power/boosters (General MRR)
by charles Sharpe 01/06/2007 21:47:09(UTC)
Boosters (Digital)
by charles Sharpe 31/05/2007 21:19:34(UTC)
Boosters? (Digital)
by Dick 26/05/2007 02:31:58(UTC)
Marklin boosters 6015 and 6017 and ECOS (Digital)
by diesel 15/04/2007 01:52:52(UTC)
Reasonably Priced 6017 Boosters? (Digital)
by kerz 18/01/2007 07:58:35(UTC)
Power and Boosters (Digital)
by huttel 27/10/2006 21:14:26(UTC)
Boosters (Digital)
by Andy18 05/10/2006 04:15:23(UTC)
Boosters (Digital)
by sudibarba 02/08/2006 05:24:00(UTC)
Understanding boosters (Digital)
by tommyheadleycox 19/03/2006 18:12:49(UTC)
60129 Connect 6017 for old boosters. (Digital)
by steventrain 11/12/2005 11:15:22(UTC)
The new boosters and 6021 (Digital)
by Nuno 23/11/2005 21:06:30(UTC)
LDT Boosters (Digital)
by robertrt 11/10/2005 02:19:20(UTC)
Digital Help: CS/Intellibox/6021 w/ Boosters (Digital)
by 5HorizonsRR 14/09/2005 09:48:11(UTC)
Multiple boosters (Digital)
by Gregor 06/12/2004 21:35:51(UTC)
Boosters and s88 (Digital)
by xxup 05/11/2004 13:55:03(UTC)
Marklin Boosters (Digital)
by tnx jake 28/09/2003 21:56:10(UTC)
This page was generated in 0.656 seconds.
