Offline JudyHR
#1 Posted : 27 February 2015 12:52:31(UTC)
JudyHR
I have just purchased Marklin passenger cars. Some are metal and some are plastic. How do I, or can I, take the tops off to add seats and people to the inside?
Thanks for any help.
Judy
Mobile, AL
#2 Posted : 27 February 2015 14:15:49(UTC)
Hi Judy,
As far as I know all the metal ones have a seperate roof which just clips on. You should be able to pull it off easily.
The plastic ones sometimes have a seperate roof, but also sometimes the roof is moulded together with the coach sides and ends. If this is the case you should be able to remove the whole body from the chassis. Sometmes you have to pull off the black end pieces to allow this to happen. Sometimes you have to slide something sharp along the gap between body and chassis to release the clips.
Can you post the catalogue numbers of these coaches? If you don't have them you could post a photo.
#3 Posted : 27 February 2015 18:56:04(UTC)
Views messages in topic : 2,881
Hi Judy,
.....and some of them, you may have to unscrew a couple of fasteners...etc.
There are many variations... We 'll be happy to give you specifics once we have a look at the pictures.
Jacques
#4 Posted : 28 February 2015 02:16:30(UTC)
Most metal coaches have roofs that are held in place by little clips (at the coach ends) or by little indents that serve as clips along the edges. Most plastic coaches have unipiece bodies with a few exceptions. Those coaches are either fixed to the chassis by a pair of screws or clips usually near the couplers or have two little pins which are attached to the gangway connector that require that part to be removed before the shell can be separated from the chassis.
We can give you precise information if you provide model numbers, photos for the models.
Adding digital passenger cars to a Marklin digital engine (Digital)
by Zeeboo04 25/01/2024 17:06:37(UTC)
Identifying Marklin Locomotives and Passenger Cars (H0-scale)
by Alex H 20/08/2023 18:25:50(UTC)
Proper passenger cars behind the red E19? (General MRR)
by artfull dodger 23/01/2023 20:44:36(UTC)
PIKO BLS EWI passenger cars length? 96086/87/88 (H0-scale)
by egonzinc 02/01/2023 21:03:55(UTC)
Roco passenger cars derailing on double slip switch (H0-scale)
by MarcelV 02/11/2022 23:14:57(UTC)
3-axle passenger cars (General MRR)
by Mr. Ron 16/08/2022 00:47:11(UTC)
Non Marklin American Prototype Freight and Passenger cars (H0-scale)
by bgemski 28/05/2022 17:19:04(UTC)
Self making End lights for passenger cars (H0-scale)
by JohnjeanB 12/05/2022 18:28:13(UTC)
6/Amtrak HO passenger cars? (H0-scale)
by cantanks 24/09/2021 00:59:31(UTC)
Märklin 4067 / 4079 / 4080 "umbau" passenger cars (H0-scale)
by Ranjit 29/07/2021 20:15:12(UTC)
Directional lights on Passenger Cars (General MRR)
by xpsensation 04/02/2021 21:30:00(UTC)
Just acquired prewar loco, passenger cars and freight cars. Help! (Collector's Corner general)
by Prewar steve1966 24/12/2019 21:35:16(UTC)
Appropriate loco for passenger cars? (H0-scale)
by LA2019 15/11/2019 00:31:04(UTC)
V200 passenger cars (H0-scale)
by QQQ1970 11/07/2019 05:24:49(UTC)
Resource for Finding Spare Part Numbers for Freight/Passenger Cars? (H0-scale)
by 5HorizonsRR 20/02/2019 17:08:30(UTC)
Tinplate Passenger cars with seating? (H0-scale)
by Elsleuth1 23/01/2019 00:28:00(UTC)
Spontaneously derailing tin plate passenger cars (H0-scale)
by sjbartels 10/01/2019 23:22:26(UTC)
Spring Part number, passenger cars (H0-scale)
by frickwg 25/11/2018 21:40:00(UTC)
Marklin HO Vintage Passenger Cars (H0-scale)
by rhschulz2000 15/07/2018 00:34:37(UTC)
What passenger cars match DB class 23? (H0-scale)
by QQQ1970 15/02/2018 04:31:08(UTC)
lighted passenger cars (H0-scale)
by Tex 06/06/2017 20:49:42(UTC)
Fitting AC axles for Walthers Mainline passenger cars (H0-scale)
by 610 08/05/2017 01:59:31(UTC)
Has Anyone Experimented with Cheap Wholesale LEDs in Passenger Cars? (H0-scale)
by 5HorizonsRR 31/12/2016 19:25:47(UTC)
What is the Story with the Scale of the Passenger Cars? (H0-scale)
by Collector 20/08/2016 15:48:43(UTC)
Looking for advice about passenger cars (H0-scale)
by Chris Dunn 20/06/2016 02:13:57(UTC)
Is the styrofoam safe storage for passenger cars? (H0-scale)
by vnangli 12/06/2016 17:42:40(UTC)
Changing couplers for ICE passenger cars... (General MRR)
by vnangli 07/03/2016 02:12:49(UTC)
Goldilocks Range for Number of Passenger Cars (General MRR)
by AJH4 16/12/2015 06:27:08(UTC)
Metal wheelsets for large scale passenger cars (General MRR)
by tommycox 04/12/2015 22:07:48(UTC)
Marklin Passenger Cars Query (H0-scale)
by madhu.gn.71 11/08/2015 07:13:54(UTC)
Compatibility between locos and passenger cars.. (General MRR)
by vnangli 16/03/2015 03:49:45(UTC)
Needed Less Expensive 1:87 passenger cars and trucks (H0-scale)
by madhu.gn.71 06/03/2015 12:01:33(UTC)
Marklin passenger cars (H0-scale)
by arjkmbc 28/02/2015 20:20:33(UTC)
Which loco to pull these blue passenger cars in 1955? (General MRR)
by Mark5 10/12/2014 23:40:09(UTC)
Recommendations for DB era IIIa passenger cars? (H0-scale)
by Janne75 16/05/2014 16:59:51(UTC)
Locomotive and passenger cars maximum permissible speeds (Prototype)
by Janne75 29/04/2014 10:57:04(UTC)
Bavarian D XII and passenger cars? (H0-scale)
by LA2019 03/04/2014 02:03:28(UTC)
LED Lighting for the Plastic Passenger Cars (H0-scale)
by Hoffmann 07/02/2014 23:26:22(UTC)
LED Lighting for Tin Plate Passenger Cars (H0-scale)
by Hoffmann 07/02/2014 14:44:07(UTC)
What CFL loco of these should pull these CFL passenger cars? (H0-scale)
by Janne75 20/12/2013 10:29:18(UTC)
How many passenger cars of these types you have? (General MRR)
by Janne75 16/12/2013 18:53:16(UTC)
Replacing incondescent light strips with LEDs on Passenger Cars (General MRR)
by drbob01 06/09/2013 17:19:33(UTC)
ACME locomotives and passenger cars - R1/R2 curves (General MRR)
by pn 05/08/2013 00:32:53(UTC)
WTK: OK Engines Passenger Cars? (H0-scale)
by Roman 28/02/2013 20:49:27(UTC)
Supplying power to Maxi/gauge 1 passenger cars/caboose (Big scale)
by Thewhip1970 23/02/2013 16:19:42(UTC)
Do It Yourself Digital LED Strip Lighting in Marklin passenger Cars (Digital)
by SCWHIPPLE 23/02/2013 02:56:17(UTC)
SJ Classic Replicas of Da and passenger cars 30301 & 40301 (H0-scale)
by Armando 17/01/2013 06:33:18(UTC)
passenger cars lighting kits? (H0-scale)
by Joseph Meiring 14/12/2011 20:30:16(UTC)
Which passenger cars go with 39014, BR01? (General MRR)
by sebastian 08/10/2011 21:30:47(UTC)
29854 Premium Starter Set Passenger Cars (H0-scale)
by Maurice 03/05/2011 07:44:24(UTC)
This page was generated in 0.551 seconds.
