Offline anthpao
#1 Posted : 18 June 2015 12:40:07(UTC)
anthpao
I want to convert the locomotive from starter set 29529 to have LED lights white/red and an ESU loksound decoder. Fitting the sound decoder was easy, I also open small holes where the red lights should be, but I cannot find the plastic defusers and the white/red led pcb that Marklin already is using in a few locos like the loco from starter set 29255 and the 37260 loco. In the manual of these loco's there is the old design and not the newer with the LED's. Does anybody know the part numbers of the newer spare parts I need (both optical defusers and led pcb of loco 37260 or 29255)?
#2 Posted : 18 June 2015 19:22:07(UTC)
I am not sure that you can simply install the more modern LED lighting from the 37260 in the earlier 29529. You will have to check to see whether the LED panel can be inserted into the chassis of the 29529 or whether Maerklin has changed the design of the chassis and the interior of the shell to accommodate the new design. On the 3460/3760 Re 460, there were modified light channels, cab interior (bottom) and other details changed when Maerklin changed from bulbs to LEDs.
What you may be able to do is to buy a 37260, swap shells and then sell the loco with the "En Voyage" livery at a discount.
Here is a 37260 on ebay for 179 EUR http://www.ebay.de/itm/M...EU-in-OVP-/231067126348?
If you buy that, swap the shells, you can then sell it for 99-129 EUR on ebay to get most of your money back.
Offline anthpao
#3 Posted : 19 June 2015 16:54:21(UTC)
anthpao
I switched the chassis and there was a perfect match. So in order to keep all of the locomotives I need to find the optical defusers and the LED PCB. Does anybody knows the spare part codes of the defusers and the led pcb of 29255 or 37260. The manuals does not provide any help.
#4 Posted : 20 June 2015 01:51:58(UTC)
LED panel: E186453 Beleuchtungseinheit 15,00 €
Light Channel: 248320 LICHTKOERPER (Shows as Not Available)
The instructions and exploded view diagram and list do not provide any details about how the LED panel is connected and whether it requires a special decoder or circuit on a PC board that the earlier model with bulbs might not have.
I would recommend looking into finding one of the other models on special and swapping shells and then selling the unwanted one on ebay at a discount.
I upgraded a couple of Swiss locos by doing this and swapped out the white LEDs, grey pantographs and mfx against older models with Delta or 6090 and yellow LEDs. I got the new ones for under 200 EUR and sold the older ones for 99 EUR, so it cost me 101 EUR for the two grey pantos, the white LEDs and mfx. The two pantos alone were listed at 60 EUR.
There is no part for a second diffuser for the red lights in the instructions of the two newer locos.
I would send an email to service(at)maerklin to get this information.
Spare Parts and paperwork for Marklin 54563 (Big scale)
by mjamz 03/12/2023 06:16:35(UTC)
Marklin Z Scale (Older Model) Spare Parts in US (General MRR)
by NewToThis 26/09/2023 02:18:09(UTC)
26600 California Zephyr - User manual, spare parts (H0-scale)
by Kaspar 05/06/2023 19:10:17(UTC)
Spare parts for 5707 locomotive? (Big scale)
by artfull dodger 21/08/2022 01:23:44(UTC)
M 83341 Spare Parts Diagram, Horn Assembly Number? (General MRR)
by Roman 23/02/2022 03:41:50(UTC)
spare parts list on Marklin site (H0-scale)
by marklinist5999 05/09/2021 15:59:18(UTC)
Marklin online spare parts lists NOK (General MRR)
by Bryan 27/08/2021 23:31:51(UTC)
spare parts MTH Trains (Digital)
by joseluisvalde 21/08/2021 13:06:10(UTC)
BR86 telex coupler spare parts (H0-scale)
by DasBert33 05/06/2021 13:57:04(UTC)
ROCO older spare parts - 50% off sale ;-) (H0-scale)
by Purellum 08/02/2021 22:54:23(UTC)
Spare parts in the USA (H0-scale)
by randallchin 06/01/2021 03:21:22(UTC)
Loco 3005 spare parts (Steam engines)
by Sokratis 27/12/2020 20:03:00(UTC)
Source for Lilliput spare Parts (H0-scale)
by frickwg 11/04/2020 23:44:36(UTC)
E91 Marklin 55171, spare parts required. (Big scale)
by twmarklinfan 18/11/2019 23:40:09(UTC)
Frustration with Spare Parts/Repairs to Damaged Items (H0-scale)
by mike c 16/05/2019 17:49:11(UTC)
Starter set 29529 and 29255 spare parts (H0-scale)
by anthpao 11/11/2018 18:53:43(UTC)
CS2 spare parts (Digital)
by applor 08/05/2018 01:50:00(UTC)
Spare parts uk/eu (General MRR)
by oranda 01/02/2018 14:01:08(UTC)
Spare parts - gangway connection (General MRR)
by camcath 14/11/2016 11:44:32(UTC)
Spare parts for older locomotives (Collector's Corner general)
by twmarklinfan 04/10/2016 10:33:57(UTC)
Spare parts (General MRR)
by Drongo 08/09/2016 15:20:05(UTC)
ordering spare parts (General MRR)
by river6109 09/08/2016 09:40:50(UTC)
spare parts lists (H0-scale)
by dominator 26/04/2016 03:07:20(UTC)
Spare Parts (General MRR)
by PMPeter 09/04/2016 17:02:09(UTC)
Marklin spare parts (H0-scale)
by Cabegye 22/12/2015 13:33:41(UTC)
3352 spare parts source (H0-scale)
by sedgar2 14/06/2015 11:21:03(UTC)
Spare Parts for early locs (3352) (H0-scale)
by sedgar2 14/06/2015 03:53:22(UTC)
Spare parts needed (Small scale)
by Timmy2Tone 11/05/2015 22:14:17(UTC)
Spare Parts Needed 262980 (F7B Gear Box) and E102623 (Condenser Tender Front Truck/Pin) (Small scale)
by zscalehobo 11/11/2014 20:24:41(UTC)
Marklin 37990 Spare Parts (Collector's Corner general)
by Fergs 21/07/2014 11:41:44(UTC)
Spare parts 579110 and 579120 (Collector's Corner general)
by Tiki734 10/05/2014 14:19:20(UTC)
Lack of help with spare parts (General MRR)
by biedmatt 21/11/2013 22:27:35(UTC)
Spare parts for C-track switches (H0-scale)
by sjlauritsen 06/09/2013 09:51:46(UTC)
The problems with spare parts... (H0-scale)
Belarus Dimi194 24/01/2013 04:23:31(UTC)
Spare parts being reduced (General MRR)
by mbarreto 21/12/2012 19:33:26(UTC)
Rolling stock coach/wagon spare parts reference? (H0-scale)
by BrandonVA 22/06/2012 16:52:44(UTC)
How do you order spare parts? (General MRR)
by biedmatt 14/05/2012 20:37:11(UTC)
Help with spare parts (H0-scale)
by ferniz 15/04/2012 08:55:51(UTC)
Help with spare parts please !!! (H0-scale)
by Armando 05/01/2012 21:08:59(UTC)
Spare parts for Marklin 7288, 72881 and 72883 roundhouses (lokschuppen) (Model kits & layout details, kitbashing and such)
by Renato 05/10/2011 14:59:28(UTC)
Changing wheels on a loco...spare parts... (H0-scale)
by French_Fabrice 25/09/2011 21:57:29(UTC)
SPARE PARTS (News from Märklin and others)
by kbvrod 27/05/2011 12:39:06(UTC)
List of Spare Parts for m-track turnouts & other Märklin Products (H0-scale)
by river6109 29/11/2010 00:45:54(UTC)
Märklin spare parts (H0-scale)
by dragos 14/07/2010 01:22:39(UTC)
7186 spare parts (H0-scale)
by Rocca 18/12/2009 13:20:47(UTC)
Mehano spare parts (General MRR)
by gachar001 24/02/2009 20:10:19(UTC)
by pyxa69 22/02/2009 20:27:52(UTC)
Online spare parts (H0-scale)
by Seetal 09/11/2008 20:07:49(UTC)
marklin gauge 1 spare parts and battery rc (Big scale)
by timit 30/06/2008 01:27:46(UTC)
TRIX Spare Parts / Rubber Tyre on 2-rail (H0-scale)
by Roger E 17/05/2008 03:57:36(UTC)
This page was generated in 0.460 seconds.
