Offline Lin Stiles
#1 Posted : 04 January 2015 21:02:35(UTC)
Lin Stiles
I have set up a route in the memory section. All solenoid devices in the route have been conformed and are in the Keyboard section. A green dot appears in the route box in memory indicating the route is active. But nothing happens. Is there a step I missed? I did not put my diagram my layout in the Layout section.
#2 Posted : 04 January 2015 21:48:19(UTC)
Just trying to clarify the question - the turnouts & such work with the keyboard controller but when used with the memory controller routes, the automatic switching does not work - right ?
I have never set up this stuff, but more knowledgeable members have so I hope you will get some good answers to this question.
Offline Nielsenr
#3 Posted : 05 January 2015 20:30:41(UTC)
Nielsenr
Have you set up and defined a contact track thru an S88 board to initiate the route?
Offline amartinezv
#4 Posted : 07 January 2015 05:23:52(UTC)
amartinezv
Hello
I haven't use a memory but I have read about how it works...
First, you have to configure a route, to do so, you have to select the route, let me say A1, and then push in the keyboard the realted devices, for example, device 5 green and device 6 red, now you have to save your route (I don't remember how it is done)
I think that you have done that, didn't it?
You can use you keyb to operate the devices and these works ok?
Now if you push the green button of the A1 route, the devices of that route should change to the position programed (dev 5 green and 6 red) besides of this the leds in the keyb must also changes. Please note that the devices must be in other positions that selected, because if not, nothing happens.
If you push the red button from A1 route, you release the route, but this doen't mean that the devices change, only mean that the route A1 is not triggered.
The memory is a little bit complicated, I hope this helps
Antonio Martínez
www.raildigital.es/davidruso
MS2 WLAN memory are limited? (Digital)
by Goofy 11/06/2023 10:38:17(UTC)
8108, a memory (Small scale)
by wildstix 09/06/2023 14:30:09(UTC)
Looking for an English instruction manual for Marklin Memory 6043 (Digital)
by Fireguy911 16/12/2020 19:59:22(UTC)
CS2 -Memory (Digital)
by Rwill 27/09/2020 12:47:39(UTC)
Memory 6043 disables Keyboard (Digital)
by iainp 06/03/2020 10:39:09(UTC)
Märklin Memory 6043 (H0-scale)
by Rocca 07/11/2018 18:20:31(UTC)
Memory workpages (Digital)
by Robert Davies 18/07/2018 22:32:04(UTC)
6043-Memory (Digital)
by Rwill 05/01/2017 12:12:54(UTC)
CS2 Memory and locomotive sounds (Digital)
by minirail 27/11/2016 12:54:04(UTC)
60653 memory lose (Digital)
by thomas buckley 28/03/2016 20:39:22(UTC)
CS2 Memory page - Advanced settings (Digital)
by Robert Davies 16/11/2015 21:39:35(UTC)
CS2 - Memory - Route (Digital)
by MSanches 16/08/2015 13:04:36(UTC)
Programming routes with the CS2 memory (Digital)
by Bob 15/04/2015 10:20:53(UTC)
memory program CS2 (Digital)
by siroljuk 10/02/2015 17:13:43(UTC)
CS2-Memory (Digital)
by MSanches 26/06/2014 10:38:53(UTC)
CS2 Memory board and signals (Digital)
by sjlauritsen 24/05/2014 00:08:29(UTC)
What was your BEST Christmas memory from Marklin HO or other model railroads (H0-scale)
by Larry 23/12/2013 07:40:19(UTC)
CS 2 Memory set-up (Digital)
by Graham HO 12/05/2013 02:22:16(UTC)
CS2 Memory Route Conditioning Feature (Accessories reviews)
by clapcott 24/04/2013 11:20:38(UTC)
6043 Memory Manual (Digital)
by PMPeter 04/04/2013 17:28:09(UTC)
Memory Route Numbering Conventions (Digital)
by midwestbls 08/07/2012 19:54:49(UTC)
Intellibox Memory (Digital)
by midwestbls 08/07/2012 04:48:41(UTC)
Connecting s88 to Memory 6043 (Digital)
by Johnvr 03/06/2012 00:08:34(UTC)
Contact tracks, S88, Memory on CS2 (Digital)
by fhp2 29/02/2012 22:11:33(UTC)
Total Reset of CS2 incloding memory (Digital)
by jonas_sthlm 29/12/2010 15:03:44(UTC)
Marklin 6043 memory directions in English? (Digital)
by elsleuth 09/05/2010 05:16:35(UTC)
Marklin 6043 memory (Digital)
by elsleuth 16/04/2010 18:21:34(UTC)
Memory 6043 Manual download (Digital)
by elsleuth 12/03/2010 04:29:27(UTC)
by elsleuth 12/02/2010 21:48:32(UTC)
6043 memory - instruction in english (Digital)
by luckas 23/01/2010 15:35:34(UTC)
6043 memory unit (Digital)
by Tex 14/09/2007 18:51:54(UTC)
S88 & Memory (Digital)
by 2ndChancer 30/04/2007 19:22:51(UTC)
Repairing a collection & a memory (Collector's Corner general)
by Diggum 24/03/2006 18:17:17(UTC)
Marklin memory 6043 manual (Digital)
by yannos 13/11/2005 20:01:51(UTC)
memory (Digital)
by alonso231gery 09/08/2005 19:23:32(UTC)
by Chris Vella 14/07/2005 10:26:53(UTC)
Memory Wire Actuators (General MRR)
by justin182 19/10/2004 08:18:46(UTC)
A question about the Memory (Digital)
by Nuno 31/10/2003 13:47:55(UTC)
This page was generated in 0.430 seconds.
