Offline walters48
#1 Posted : 07 September 2009 23:30:13(UTC)
walters48
Well, I finally received my M#6646 analog transformer. Since I have no track yet, I have been looking on eBay for feeder track in the C series.
Alas, nothing yet. But the instruction manual from the transformer on p.19 states, "With C Track most of the track sections in conjunction with feeder wire sets can be used as feeder tracks." The next paragraph describes which Feeder Wire Sets are compatible with the various track series. My question is how are these wire sets connected to the track sections, and how many does one need for a basic 3-4'X7-8' oval?
Chas
#2 Posted : 07 September 2009 23:55:30(UTC)
The C-track feeder wires are easily connected to the tracks... The C-tracks have tounge connectors where the feeder wire spades fit.
For a simple oval, one is enough since the track-to-track connectivity is excellent. The possible electrical problem may you run into with second-hand track is dirt on the rails/studs if you don't run it so often...
Offline WelshMatt
#3 Posted : 07 September 2009 23:58:17(UTC)
WelshMatt
There are two types of C track feeder - one with a PCB that clips into the underside of the track (with anti-interference components) and one which is intended to be used with digital control. Both use spade connectors that are simply slid onto tabs under the track.
You might want to keep an eye out for people splitting up sets. I've seen bundles of C track that would make a good starter layout for very sensible money this side of the Atlantic.
Matt from Wales.
Offline davemr
#4 Posted : 08 September 2009 01:15:36(UTC)
davemr
You can solder the wires onto the tags under the roadbed if you wish. Any model rail wire will do there is no need to buy a feeder wire set (although it is more convenient)
I would advise buying your C track new. 12 sections of curve track make a circle and you can buy as many straight sections as you want to make the size of oval you have space for.
Could I suggest a Marklin book 07421 which will give you lots of info.
dave
davemr
#5 Posted : 08 September 2009 01:52:05(UTC)
Hi, Chas,
For a clean connection with anti-interference components you need a 74046 to connect transformer and track; you can use several 74042 to spread the power: connect one end near the 74046, the other one far away.
If you use a 74046, never bypass it with other connection to the transformer.
If you don't care about radio interference, just use a couple of 74040 to feed the power. One feed every 3' though 5' of track is recommended (but a layout of that size should work OK with one feed only).
You can use the spade connectors 74995 to make the wires yourself (I fix them with ordinary pliers, no need to buy the special M* tool).
Offline WelshMatt
#6 Posted : 08 September 2009 15:03:59(UTC)
WelshMatt
One more bit of advice - you need equal numbers of 24188 and 24172 straights, as Marklin didn't manage to settle on a standard straight track in C track.
It is definitely worth finding a chart of how all the various bits of track fit together, this will help you work out what you want to buy.
Matt from Wales.
Offline verbo
#7 Posted : 08 September 2009 22:16:42(UTC)
verbo
<br />One more bit of advice - you need equal numbers of 24188 and 24172 straights, as Marklin didn't manage to settle on a standard straight track in C track.
Very interesting, I didn't know that. Actually, I was wondering why two lengths of 'long' straight C-track are needed?
Do you happen to have any reference material that we could have a look at (e.g. the chart you are referring, or an older artical in M* Magazin)?
Thanks!
George, a Marklin fan
Offline WelshMatt
#8 Posted : 08 September 2009 22:31:44(UTC)
WelshMatt
I've been trying to work out why there need to be two standard lengths of straight since I got into Marklin. Nobody has ever managed to give a convincing answer why all other manufacturers get away with one standard straight length while Marklin need two...
If you can get hold of a Marklin catalogue you'll find a diagram of the C track geometry in there. I can't find one online although someone else may be able to?
Matt from Wales.
#9 Posted : 09 September 2009 00:31:09(UTC)
<br />I've been trying to work out why there need to be two standard lengths of straight since I got into Marklin.
By having different lengths they avoid the need for very short pieces of track.
The 188mm piece at an angle of 24.3° exactly matches the length of a 172mm piece at an angle of 0° - 24.3° is the angle of the turnouts.
With M track, you needed short pieces (about 10 mm) to compensate for the angle. Such short pieces probably can't be made for C track.
Offline Caplin
#10 Posted : 09 September 2009 01:17:01(UTC)
Caplin
<br />It is definitely worth finding a chart of how all the various bits of track fit together, this will help you work out what you want to buy.
Have a look at a track length calculator created and published here by member Dale Schultz:
http://layout.mixmox.com/1/calc
Benny - Outsider and MFDWPL
Newbie Question (General MRR)
by MarkMMKT 25/11/2024 16:44:56(UTC)
Some Newbie Questions about Analogue Control of Devices (H0-scale)
by AlanC 09/04/2022 16:25:33(UTC)
Spur 1 Märklin/Hübner track newbie questions (Big scale)
by hvc 04/01/2022 10:41:10(UTC)
Newbie Questions (H0-scale)
by berkgenc 13/12/2021 18:57:53(UTC)
Newbie question regarding the M-track (H0-scale)
by popsicle 06/09/2019 17:26:04(UTC)
Some newbie questions on how to connect feeder tracks and lighting (Digital)
by rhNOR 18/04/2019 01:12:19(UTC)
C-track newbie question (H0-scale)
by AshdownSteve 19/01/2017 13:26:17(UTC)
LED strip lighting newbie question (General MRR)
by DV 02/09/2016 06:06:55(UTC)
by Rkieser 06/12/2015 17:45:52(UTC)
Newbie question re coupler compatibility (H0-scale)
by arawata 21/06/2014 12:23:22(UTC)
Newbie questions...MS2 and K83, and 24624 decoder install (Digital)
by alexaqui 08/01/2013 22:11:13(UTC)
Absolute newbie questions from oldie! (H0-scale)
by marklinboy 23/10/2012 13:33:33(UTC)
Newbie question, loco 37071 (Digital)
by jdk998 06/12/2009 21:38:53(UTC)
by Mloughran 10/12/2007 05:32:36(UTC)
newbie question on coupling cars (H0-scale)
by Darren W 02/04/2007 21:31:30(UTC)
Newbie question on kadee couplers (General MRR)
by Pianne 30/12/2006 12:27:34(UTC)
Newbie Question: what bits can be upgraded? (General MRR)
by Minok 06/11/2006 07:43:19(UTC)
5 pole motor conversion newbie question (Digital)
by Pianne 31/10/2006 21:37:43(UTC)
Newbie Questions: Prices & FAQ ? (General MRR)
by Minok 15/10/2006 04:25:49(UTC)
Newbie question for Central Station and K83 / K84 (Digital)
by Gert-Jan 14/12/2005 09:25:39(UTC)
Newbie question regarding Circuit Track...solved! (H0-scale)
by ulf999 03/10/2005 13:47:21(UTC)
Newbie question on Delta Control 4f (Digital)
by LionelMPC 04/05/2005 00:28:10(UTC)
A few newbie questions, sorry if already covered.. (Digital)
by Sam 06/02/2005 17:48:42(UTC)
Another Newbie question:Delta decoders (H0-scale)
by Bill190D 26/11/2003 01:42:51(UTC)
Newbie Question (Digital)
by john 23/11/2002 15:21:31(UTC)
This page was generated in 0.688 seconds.
