Offline Drongo
#1 Posted : 15 June 2024 08:06:59(UTC)
Drongo
I have a large layout using an EcoS with 2 boosters and suddenly I have a short circuit in the system which turns the EcoS off. I had a similar situation before and found that a track screw was placed too close to the end of the track piece which caused connection between the "O" and the "B". This time I can't find any screw causing this again. Does anyone have an ide4a how to detect where the short circuit is occurring using a multimeter ?
Greg
#2 Posted : 15 June 2024 10:31:40(UTC)
Hi Greg
Finding a short-circuit is sometimes long to find and depends on the type of rail you are using (M-Track, C-Track, K-Track)
Usually, you need to be given a clue so removing all power feeder and plugging them one by one while the power is on will give you a hint on to which zone to look for the short
I have made many mistakes on wiring my layout (approx.70 turnouts, 28 locos) and the best approach I think is:
- to use a thick (2.5 mm²) power feeder cabled in a star arrangement from the CS3 (5A) and all is welded
- at the end of each power feeder line there is a connector to the distribution plate
- from each distribution plate, on wire (0.5 mm²) brings power to a zone where the central conductor is insulated from others
- I used Viessmann distribution plates and this was a mistake because the plugs are popping out all the time. The Märklin ones are far better
- there is no need to insulate the ground distribution, nor to install connectors.
On M track, a simple metal (e.g. a thin wire ) near a metal stud can short. Also a derailing train on a turnout can cause the spring to become red and then totally useless, even cause shorts inside the turnout.
On C track (the best in my opinion) chances or a track-related short are very very small. Rather the risk is that the bridges to cut for creating occupancy zone can accidentally contact
On K Track, the B and O are very close together at the extremity so the risk of short is real and hard to find in concealed road bed.
A funny trick I used in the past is to use car brake lamps in series with each power feeder. Normally, it has a very low resistance but as soon as there is a short the lamp lights up showing which zone is causing trouble
#3 Posted : 15 June 2024 12:37:28(UTC)
Greg
Be systematical; Remove all rolling stock that has a slider.
If you have 2 boosters, your layout will already be divided into 2 or 3 sections. Disconnect all sections, and re-connect one section at a time, to see which one causes the problem.
I agree that often-times it is some small screw or metal-part that causes the short, but there can be other culprits too...
Offline bygger01
#4 Posted : 15 June 2024 20:24:54(UTC)
bygger01
You should tell which rails you using !
But otherwise my suggestion would be:
Think about what you changed before the short circuit happened, and then see if the problem lies there.
If not, you should find out which circuit is causing the short by removing two of them, and then find the one that is the problem.
Then your search starts, but if you have many connections to the underneath wires, then it is difficult, but there must be a the way.
My experience is, that if there is absolute calm in the room, that you can hear a faint ticking, the system shuts down, then find a partner and then look for that way!
Especially with K rails there are tabs that can tease ....
I also know about 24V truck bulbs ( Thanks for that Purellum ), but it is more in the construction phase !
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
#5 Posted : 15 June 2024 21:20:31(UTC)
Depending on the track and how it is attached to the base just remove it in sections until the fault is found in a small section. With C track I can break up parts of the layout and put back together again easily.
K track would be more difficult. My C track is held with spot of Copydex only every four feet and track can be lifted anywhere if required.
Offline Drongo
#6 Posted : 16 June 2024 08:39:54(UTC)
Drongo
Thanks Fellas for the help. I'm sorry I didn't mention that I'm using C track. I have isolated the problem to one section of the layout which of course is the largest section.
thanks 2 users liked this useful post by Drongo
Offline bygger01
#7 Posted : 16 June 2024 13:43:32(UTC)
bygger01
Good hunt .........
thanks 1 user liked this useful post by bygger01
#8 Posted : 16 June 2024 21:46:09(UTC)
The way to do this is to have a DC power supply that will current limit. Set it up to limit at a lowish current, say a 1/4 to 1/2 amp, and with a sensitive DVM look for the lowest voltage point on the track. You may well need a 4 or 5 digit DVM to find lowest voltage point, but a 3 digit one may get you close enough to find the problem by visual inspection.
You will need to disconnect the boosters and ECoS while you do this.
Offline Drongo
#9 Posted : 26 June 2024 12:11:44(UTC)
Drongo
Just a quick update. Trying to find the cause is proving too difficult, so I'm replacing the bus.
Greg
Offline Drongo
#10 Posted : 16 July 2024 14:55:29(UTC)
Drongo
Greg
I've replaced the bus and have connected the drop downs. In doing this exercise, I lifted some track pieces and I found a loose track screw under a track piece. I think the screw moved to one end of the track and this caused the short circuit, as now there's no short. Such a simple thing can cause so much trouble.
Anyway, I'm up and running again with a new bus and wiring system so when (and hopefully it won't happens) happens I can trace the short more easierly.
Greg
Offline bygger01
#11 Posted : 16 July 2024 16:30:30(UTC)
bygger01
You can advantageously equip one or more wagons with a with relatively strong magnet.
The magnet is placed inside and held in place with e.g. a thin iron disc on the outside under the carriage, and the disk or piece of iron should ideally be nearly the width of the wagon!.
In my case, it is a Lux cleaning wagon, and there are often catches and had also Märklin K rail screws had been seen.
Maybe I should equip a few more wagons.....
#12 Posted : 16 July 2024 18:09:55(UTC)
Hi Greg and everybody
When I was using M track often there were shorts as any tiny cable strand / screw / burnt springs inside points/turnouts would cause one and was hard to find.
In this case, the best is to divide your layout into individually powered zone and inserting a 5W car bulb (brake lamp) will turn on and show in which section the short C. is.
Since I am with C Track, the issue is much simpler for me as it is only one of the two:
- a derailled car / train so I look into Rocrail which trains were last running
- a short under the table caused by faulty insulation. Here I soldered all grounds together and protected the non-insulated areas with "Liquid Tape" (a sort of liquid insulator used in boats etc to protect electrical connections
The risk of having a short on the track caused by a metal part is much much smaller
Short Circuit AGAIN (Digital)
by Drongo 17/05/2025 14:51:26(UTC)
CS1 short circuit? (Digital)
by Jörgen P 27/04/2024 20:49:23(UTC)
Cv29 how to adjust for a speedy loco after short circuit (Digital)
by Puttputtmaru 31/01/2024 00:30:05(UTC)
DB 81010 Engine - Analog - Short Circuit (H0-scale)
by jekhokie 01/12/2023 21:10:21(UTC)
Railbus 3016 short circuit on switch 5140 / 5214 (H0-scale)
by Jfve 15/10/2023 14:16:36(UTC)
Concerning Possible Electrical short circuits? (General MRR)
by ShannonN 06/09/2023 01:20:42(UTC)
C-Track threeway turnout short circuit (Digital)
by einotuominen 30/03/2023 10:53:07(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
MS2 Short Circuit Protection (Digital)
by Yossi 28/12/2021 22:15:14(UTC)
Problems around a short circuit & mfx (Digital)
by bygger01 18/08/2021 19:30:43(UTC)
DCC decoders full speed reverse after short circuit of programming track (Digital)
Belarus Martin T 02/04/2020 22:55:07(UTC)
pickup shoe slider with hole short circuit on slender K switches (H0-scale)
by applor 23/10/2018 00:12:41(UTC)
m84 units short circuiting (Digital)
by Drongo 20/08/2018 12:50:09(UTC)
An electrical short circuit that I can't explain to myself. (General MRR)
by Thewolf 05/03/2018 10:53:24(UTC)
Short Circuiting? (Model railroad wiring)
by CanadianKid 06/11/2017 05:44:26(UTC)
Wiring or short circuit? (Model railroad wiring)
by FransHO 31/12/2016 21:06:08(UTC)
Marklin BR44 tender short circuits on wide turnouts (H0-scale)
by applor 19/11/2016 05:57:24(UTC)
A mysterious short circuit! (H0-scale)
by Akil Elewa 20/07/2015 19:37:19(UTC)
Marklin tinplate cars causing short circuit (H0-scale)
by jacqvw 19/07/2014 18:37:50(UTC)
Short Circuit Report Signal (Digital)
by billys7 20/07/2013 01:12:24(UTC)
short circuit on the track (Digital)
by amirlior 18/07/2012 17:19:22(UTC)
Coach Lighting Pickup Shoe Short Circuiting Under Digital Operation (Digital)
by aos 05/03/2011 18:19:00(UTC)
Short circuit issues (Digital)
by tom becker 06/08/2007 01:50:10(UTC)
Troubleshooting a short circuit (H0-scale)
by kimmo 23/07/2004 23:37:26(UTC)
BR78 short circuit on C-Rail crossing 24640 (Digital)
by Timaximus 19/06/2004 23:32:30(UTC)
Possible short circuit in 29855 lok. Please help (H0-scale)
by Tolis 06/02/2003 18:34:08(UTC)
This page was generated in 0.638 seconds.
