Offline Tie
#1 Posted : 27 March 2023 20:48:25(UTC)
Tie
Little dramatic heading.. probably this will provide a good laugh or smile for many of You…. And perhaps teach some to think twice…
I have a permanent layout with 3 levels. Run by a cs3, turnouts with decoders and a lot of S88 with feed back contact. Automation built up to run 5 trains.. and I was happy with it. Now i wanted to install some homemade(3d printed) signals for decoration only. Trains ar fully controlled by events. I installed a M83 to control signal colors(red/green and orange) AND in installation process happen to tell cs3 to define new adresses… and it did for the whole thing. Trying to restore from old saved settings makes it a little bit better, but adresses for turnouts are not working… for most. I cannot find my handwritten list with adresses and turnouts are screwed down and access for som difficult. Assume I have used all 3 types of decoders but think I defined adresses with dip switches. When you are finished laughing… any idea how to rectify? My best proposal is to define a long list of turnouts in cs3 (in available adresses) an see what triggers the various turnouts.
Stupid TIE in Norway
Only soothing… I made the thing and I can do it again😂
thanks 1 user liked this useful post by Tie
#2 Posted : 27 March 2023 23:41:26(UTC)
Current turnout decoders are mfx. If you have set yours with dip switches how would the CS3 change the address. If the signals you made are just for decoration how can the CS3 control them. If you delete a turnout and then instal it again will the Cs3 not pick up the address. If a turnout is part of a route would that not give the address.
Offline Tie
#3 Posted : 28 March 2023 00:22:10(UTC)
Tie
Good qustions but no answers. I intended to let the cs3 via event set the m83s outputs one for each LEDs as you would with illumination in a building or street lights. And yes I might have all three types of turnout decoders but as said I think adresses where set with dip switches. Meaning adress in decoder is locked…. But then the adress used in CS3 for the various turnout are changed. 4 is still working the orhers not
#4 Posted : 28 March 2023 01:47:30(UTC)
Hello Tie🙂 I am quite baffled myself by your problem. Do your M83 decoders control any turnouts or do they all have individual decoders in them? Is the signal M83 powered by track current or external supply? What is it's address? Can it possibly be confusing the turnouts or the CS3?
I know events are complex. I don't have but a few active, and only 7 turnouts. I have had one digita mfxl 7600 series signal change with no action or selection upon a loco function button touch. I had to change the loco's address to stop it. No explanation.
Offline Tie
#5 Posted : 28 March 2023 11:23:25(UTC)
Tie
The turnouts are all equipped with local decoders(inside the turnouts) in addition to that i have some s88 for feed back from contact tracks. The mentioned M83 was first of many to be installed to control LEDs in my signals. Home made with 3d printer. I assume I can configure the M83(black type) to set current on or off based on signals from cs3.
The whole mess startet when I tried to register one of the M83s to the cs3 and pressed the button to obtain new mfx adresses for the whole system.
Offline Tie
#6 Posted : 28 March 2023 12:38:07(UTC)
Tie
Online rhfil
#7 Posted : 28 March 2023 14:22:52(UTC)
rhfil
Do you have a mobile station? If you do you can then do one switch at a time and have someone go around the layout to identify which switch is being activated. In the future I recommend, as I have done many times in here, that you save the layout in the CS3 and in a thumb drive. You should do it before any changes to the layout so you can get back to the status before the change if it goes to hell.
Offline Tie
#8 Posted : 29 March 2023 07:00:12(UTC)
Tie
I do have a mobile station, not much used, but assume this will be same as set up a turnout in cs3, change adress and activate it to se where and if a turnout reacts. Then do the same several times and increasing adress by one each time. The funny thing is I did a back up ( have several stored by date) and it seened to fix the most. But not the turnouts.
#9 Posted : 29 March 2023 09:31:37(UTC)
No, with the MS2 you just flip through the solenoid address range and can activate each address as you go. This can save a lot of time if you try the trial-and-error approach.
Note that tests may have to be made for both DCC and MM protocols unless your DIP settings allow one protocol only.
Offline Tie
#10 Posted : 29 March 2023 13:14:58(UTC)
Tie
I have only tried the mobile station once connected via cs3. Never used it. This may have worked. Howeer, I found another solution: looking in cs3 I found that the turnouts( allocated name P1, P2(pens norwegian for turnout) had the old adress set and I had used adress 1 for P1 etc. possibly my naming made the discover new mfx made cs3 allocate new names (w1 etc for german weiche)
I dis the same discover new mfx and this time ticked existing adress. Now I got a list of w1, w2 etc. thei all worked so I clicked through and found the turnout by sound/sight. Then wrote down the corresponding adresses. Finally I deleted all the new W1, w2….. turnouts and inserted the relevant adresses in my «old» P1,P2 turnouts. Discover new mfx does not delete the old ones.
Thanks for help.
Thor Inge
PS I might get the same problem with The S88 feedback but assume I can run a loco over them and check which item in list turns yellow
Online rhfil
#11 Posted : 29 March 2023 14:22:57(UTC)
rhfil
There are at least two types of switch decoders. The older ones could only set the address manually. The newer mfx ones can set the address electronically. I still set the address of the mfx ones manually. It sounds like you have both and the computer reset the mfx ones, a problem I thought might happen.
Offline Tie
#12 Posted : 29 March 2023 15:09:17(UTC)
Tie
Assume you are right. 5 of my 18 decoders worked as normal. I have user manuals for all three… 74460 74461 and 74462.
Hamo 8394 BR 03 Digital conversion (Collector's Corner general)
by Imagine 01/07/2025 21:46:50(UTC)
Marklin 55035 Problem with digital commands (Big scale)
by Fabionino 03/06/2025 13:57:21(UTC)
How many digital decoders for C Track can you use? (Digital)
by michelvr 25/05/2025 23:29:05(UTC)
Digital Newsletter Back Issue link (Digital)
by BwanaJoe 11/05/2025 14:31:01(UTC)
Old Digital Gear and old Magazines (General MRR)
by BwanaJoe 05/05/2025 19:54:43(UTC)
Digital upgrade questions for the experts (Big scale)
by roundsaturn31 26/04/2025 16:49:44(UTC)
Old passenger cars with interior lighting on digital layouts (Digital)
by Evergreen 21/04/2025 15:47:07(UTC)
Digital Cameras-Nothing Works (Model railroad photography)
by analogmike 16/04/2025 14:11:57(UTC)
Trafo 6646 and Digital Loco (Digital)
by mb300e4m 26/03/2025 01:32:15(UTC)
incandescent bulbs in digital conversion (Digital)
by einotuominen 18/03/2025 18:14:34(UTC)
Loco digital conversion led light question (Digital)
by Mjn2ts 17/03/2025 20:11:49(UTC)
Digital Operation of the classic Marklin Crane 6051 (Digital)
by Johnvr 16/03/2025 17:07:42(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Toughts in this Roco Ac digital (Digital)
by Adrian666 14/03/2025 03:01:05(UTC)
Issue with digital wagon (Digital)
by Adrian666 10/03/2025 19:14:54(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
Problemer med digital dekoder på CS3 (Digital)
by tgj 03/03/2025 19:03:18(UTC)
Analog to digital Marklin 2862 (H0-scale)
by rickjames84 28/02/2025 22:28:20(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
Roco digital crane magnet instructions wanted (Digital)
by patnaik 22/01/2025 21:16:55(UTC)
Help with digital upgrade (Digital)
by artvegas 19/01/2025 06:05:44(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
Building my a digital Layout - Finally (Digital)
by White Buffalo 05/01/2025 22:03:21(UTC)
Anybody converting analog to digital in the US? (Digital)
by fynrfin 04/01/2025 22:02:16(UTC)
SEH800 Digital Conversion 60760 (H0-scale)
by johnhendry 04/01/2025 17:24:23(UTC)
A digital "Kranwagen" (#46715) controlled by the computer (Model railroad software)
by PeFu 31/12/2024 00:44:20(UTC)
Digital blocking (Digital)
by Paul Hedge 29/12/2024 04:09:36(UTC)
Reversing a digital loco on an analog setup (General MRR)
by rdn0609 15/12/2024 20:00:05(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Digitalizzare Re 4/4 34341 marklin (Digital)
by maxgand 23/11/2024 20:14:55(UTC)
Frogs - Digital/Analouge (General MRR)
by HO Collector 25/10/2024 22:55:13(UTC)
Digital loco, analogue transformer? (H0-scale)
by ChrisKenna 14/10/2024 09:41:20(UTC)
Return Digital Conversion back to Analogue (Digital)
by AjayTele 10/10/2024 06:24:06(UTC)
Digitalizzare Marklin 3155 (Digital)
by maxgand 07/10/2024 21:47:38(UTC)
Marklin 7651 digital crane (General MRR)
by 3864jk 06/08/2024 19:01:34(UTC)
Retrofit legacy Marklin M series with a digital controller. (Digital)
by Blisterexe 27/07/2024 20:12:03(UTC)
Marklin 60116 Digital Controler -- Electrical Requirements (Digital)
by WetterauSüd 13/07/2024 00:26:10(UTC)
Question about delta decoder on digital system (H0-scale)
by alevas 08/07/2024 19:19:45(UTC)
Brake module programming with CS3, M83, and digital signal 76496 (Digital)
by marklinist5999 19/05/2024 17:12:03(UTC)
3054 digital conversion and magnet mount problem (Digital)
by lpesce 05/05/2024 00:30:07(UTC)
Convert analogue locomotive to digital (Digital)
by Alex222 27/04/2024 11:30:20(UTC)
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Converting digital to analog (!) (H0-scale)
by Jay Zvolanek 28/03/2024 05:15:04(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
70412 and 70421 digital light signal equipments (Digital)
by biswasg 14/03/2024 14:58:20(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Custom smoke generator for digital use (Digital)
by einotuominen 17/02/2024 11:44:17(UTC)
Digital Conversion of a Delta Ae 8/14 - PC Board Part #? (Digital)
by 5HorizonsRR 06/02/2024 20:39:15(UTC)
This page was generated in 0.456 seconds.
