Offline Thewolf
#1 Posted : 12 December 2022 02:50:23(UTC)
Thewolf
Hi everyone,
I have a question but sometimes I miss the transformation of a simple track into a contact track.
It doesn't work for the feedback.
My question: can I use it as a simple track in the layout?
Thank you
Thewolf
#2 Posted : 12 December 2022 16:38:25(UTC)
You can, but the correct terminals must be used, and the correct track section cut, or they don't work. Then you must replace that track or section because current may not flow through it at all. You must do this even when using the Marklin contact track set if you lengthen the section between them. You want the section to be long enough for long cars. Guy at AJC kids has a youtube tutorial on how to make your own.
Offline Thewolf
#3 Posted : 12 December 2022 17:16:13(UTC)
Thewolf
Thank you for your comment
I won't take a chance.
Tracks for s88 that don't work will go in the garbages
Question about contact tracks (General MRR)
by Chris6382chris 09/09/2023 00:04:09(UTC)
Marklin Circuit and contact tracks (Digital)
by Luna 25/07/2023 05:37:21(UTC)
contact tracks in hidden yards (Digital)
by Don Morris 24/03/2023 01:56:40(UTC)
Pre connecting contact tracks on MS2 before changing to CS3 (Model railroad wiring)
by einotuominen 19/09/2022 06:14:46(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
M contact tracks (H0-scale)
by BenP 27/04/2022 15:47:03(UTC)
Contact Tracks for K track (H0-scale)
by Harvey 14/03/2021 01:34:22(UTC)
16 Contact tracks and I don't know what to do with them (Digital)
by oranda 18/08/2020 15:08:55(UTC)
Dead spots on C contact tracks (General MRR)
by obb_taurus 12/01/2020 19:41:32(UTC)
Placement of contact tracks with windigipet software (Model railroad software)
by marklin61 30/01/2016 23:28:11(UTC)
Circuit and contact tracks C purposes? (Digital)
by federicofreundt 17/10/2015 02:10:25(UTC)
Modules for K track contact tracks (Digital)
by PeFu 03/04/2015 20:52:06(UTC)
Contact Tracks - Question (H0-scale)
by SteamNut 16/12/2014 17:26:46(UTC)
how to use track blocks and contact tracks (Digital)
by Laxman 20/02/2014 07:22:59(UTC)
Automatic Station with Contact Tracks (Track plans)
by Laxman 11/02/2014 01:03:02(UTC)
C-Track "blocks" / contact tracks (Digital)
by pmgsr 13/02/2013 23:46:12(UTC)
Contact tracks, S88, Memory on CS2 (Digital)
by fhp2 29/02/2012 22:11:33(UTC)
Nielsenr - Contact tracks in Braking Area (Digital)
by Nielsenr 30/08/2011 05:37:02(UTC)
Contact tracks problem/questions (Digital)
by WelshMatt 29/01/2009 12:48:53(UTC)
Homemade contact tracks: M and C? (H0-scale)
by mascagni 15/10/2007 16:27:19(UTC)
by Xav 17/10/2004 16:02:44(UTC)
DIY Contact Tracks (General MRR)
by Dick 29/02/2004 21:36:00(UTC)
M Track Contact Tracks (Digital)
by xxup 29/01/2004 23:45:33(UTC)
Old contact tracks (H0-scale)
by coloradopatton 14/03/2003 00:33:41(UTC)
This page was generated in 0.242 seconds.
