Offline Mjn2ts
#1 Posted : 07 June 2022 12:55:49(UTC)
Mjn2ts
Is there a way to use non Marklin bridges with Marklin track?
I’m in the planning stages of a vintage layout using m-track. I’m thinking of building the layout found in the 1971 catalog that calls for a lot of bridges both straight and curved (5100 and 5200 radius). I have a fair number of the metal bridges but not enough for the whole layout and they’re not in great shape. I’m also not a huge fan of the generic looking Marklin bridges. I’ve found a ton of really nice bridges online but I’m not sure how to use them with any of the Marklin track types.
#2 Posted : 07 June 2022 13:45:54(UTC)
The item descritions tell if the C track bridges abd ramps can be used for M track. Not sure about Faller, Vollmer, etc.
#3 Posted : 07 June 2022 14:46:26(UTC)
Hi Jeff
As you know there are things to consider for a bridge
- track bed width: the C track width is 40 mm and M track is 37.5mm
- track radius for curves. R1 is the same for C track and M track (R=360mm) for R2 both tracks have a R2= 437.5mm
If I mention C track, this is because a large assortment of bridges fit for C track exist by Faller
-120471 complete ramp using R2 (5200)
- 2 track viaduct 120466
- 1 track curved bridge R1 120475
- 1 track curved bridge R2 120476
- 1 track straight bridge 188mm 120474 (M Track is 180mm so a small 8 mm track (5208) might be needed
This is just Faller but I am sure you may find more.
Attention
- the M track bed is narrower so you may have to use shims to keep it in place
- straight track length is different (M track is 180 mm while C Track is either 188mm or 172 mm)
I hope this helps
Offline PeFu
#4 Posted : 07 June 2022 18:22:31(UTC)
PeFu
I agree, they look great, and it’s nice to exclude the standard ballast tracks on bridges. Did you check eBay.com, for e.g Märklin items 7161, 7162, 7163, 7167 or 7168?
Smile
M-Track bridges made into living room diorama (H0-scale)
by DaleSchultz 14/08/2025 04:05:07(UTC)
Curved bridges for R2-R5 (News from Märklin and others)
by PeFu 13/12/2024 08:27:19(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
Alternatives to Marklin Piers for Old Metal Bridges - Ideas? (H0-scale)
by 5HorizonsRR 10/01/2021 19:04:38(UTC)
Bridges (General MRR)
by Rohit279 13/09/2019 15:43:16(UTC)
Electric current on a rail amputated from its bridges (General MRR)
by Thewolf 14/02/2018 23:56:09(UTC)
Pillars for Märklin metal-bridges (7161, 7162, 7163 and ramps) (H0-scale)
by Markus Schild 21/01/2018 23:00:13(UTC)
R3 bridges (H0-scale)
by Leitner 11/01/2018 08:19:08(UTC)
HO bridges (H0-scale)
by Twisterdodger 11/05/2017 00:48:37(UTC)
Train travel through 100 years bridges of New Zealand. (Prototype)
by waorb 29/06/2015 20:48:52(UTC)
C-Track and Bridges (H0-scale)
by Hoffmann 03/10/2013 02:28:02(UTC)
Trestle Bridges (Big scale)
by Jeremy Palmer 06/09/2013 02:04:29(UTC)
Bridge Piers, Bridges, Approach Ramps (Collector's Corner general)
by kumarvartak 26/09/2012 09:09:16(UTC)
"half length" bridges?? (General MRR)
by Joseph Meiring 27/11/2011 22:05:10(UTC)
Hack Brucken - Metal Bridges for Marklin (News from Märklin and others)
by GlennM 04/10/2011 18:01:03(UTC)
Stone bridges to chose (Model kits & layout details, kitbashing and such)
by ac jacko 28/06/2010 15:07:24(UTC)
Correct height for bridges in HO layout (General MRR)
by gachar001 22/07/2008 19:59:19(UTC)
Stone arch bridges the lazy way (Model kits & layout details, kitbashing and such)
by perz 01/07/2007 01:12:30(UTC)
Stone arch bridges and walls (Model kits & layout details, kitbashing and such)
by hxmiesa 16/10/2006 02:41:00(UTC)
Faller Bridges (Model kits & layout details, kitbashing and such)
by mattillini 09/06/2006 22:09:17(UTC)
Weathering RR bridges (Painting & Weathering)
by jselter 09/12/2005 16:47:25(UTC)
Weathering steel bridges (Painting & Weathering)
by Lloyd 17/03/2003 21:48:04(UTC)
This page was generated in 0.271 seconds.
