Offline Mjn2ts
#1 Posted : 07 June 2022 12:55:49(UTC)
Mjn2ts
Is there a way to use non Marklin bridges with Marklin track?
I’m in the planning stages of a vintage layout using m-track. I’m thinking of building the layout found in the 1971 catalog that calls for a lot of bridges both straight and curved (5100 and 5200 radius). I have a fair number of the metal bridges but not enough for the whole layout and they’re not in great shape. I’m also not a huge fan of the generic looking Marklin bridges. I’ve found a ton of really nice bridges online but I’m not sure how to use them with any of the Marklin track types.
#2 Posted : 07 June 2022 13:45:54(UTC)
The item descritions tell if the C track bridges abd ramps can be used for M track. Not sure about Faller, Vollmer, etc.
#3 Posted : 07 June 2022 14:46:26(UTC)
Hi Jeff
As you know there are things to consider for a bridge
- track bed width: the C track width is 40 mm and M track is 37.5mm
- track radius for curves. R1 is the same for C track and M track (R=360mm) for R2 both tracks have a R2= 437.5mm
If I mention C track, this is because a large assortment of bridges fit for C track exist by Faller
-120471 complete ramp using R2 (5200)
- 2 track viaduct 120466
- 1 track curved bridge R1 120475
- 1 track curved bridge R2 120476
- 1 track straight bridge 188mm 120474 (M Track is 180mm so a small 8 mm track (5208) might be needed
This is just Faller but I am sure you may find more.
Attention
- the M track bed is narrower so you may have to use shims to keep it in place
- straight track length is different (M track is 180 mm while C Track is either 188mm or 172 mm)
I hope this helps
Offline PeFu
#4 Posted : 07 June 2022 18:22:31(UTC)
PeFu
I agree, they look great, and it’s nice to exclude the standard ballast tracks on bridges. Did you check eBay.com, for e.g Märklin items 7161, 7162, 7163, 7167 or 7168?
Smile
Curved bridges for R2-R5 (News from Märklin and others)
by PeFu 13/12/2024 08:27:19(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
Alternatives to Marklin Piers for Old Metal Bridges - Ideas? (H0-scale)
by 5HorizonsRR 10/01/2021 19:04:38(UTC)
Bridges (General MRR)
by Rohit279 13/09/2019 15:43:16(UTC)
Electric current on a rail amputated from its bridges (General MRR)
by Thewolf 14/02/2018 23:56:09(UTC)
Pillars for Märklin metal-bridges (7161, 7162, 7163 and ramps) (H0-scale)
by Markus Schild 21/01/2018 23:00:13(UTC)
R3 bridges (H0-scale)
by Leitner 11/01/2018 08:19:08(UTC)
HO bridges (H0-scale)
by Twisterdodger 11/05/2017 00:48:37(UTC)
Train travel through 100 years bridges of New Zealand. (Prototype)
by waorb 29/06/2015 20:48:52(UTC)
C-Track and Bridges (H0-scale)
by Hoffmann 03/10/2013 02:28:02(UTC)
Trestle Bridges (Big scale)
by Jeremy Palmer 06/09/2013 02:04:29(UTC)
Bridge Piers, Bridges, Approach Ramps (Collector's Corner general)
by kumarvartak 26/09/2012 09:09:16(UTC)
"half length" bridges?? (General MRR)
by Joseph Meiring 27/11/2011 22:05:10(UTC)
Hack Brucken - Metal Bridges for Marklin (News from Märklin and others)
by GlennM 04/10/2011 18:01:03(UTC)
Stone bridges to chose (Model kits & layout details, kitbashing and such)
by ac jacko 28/06/2010 15:07:24(UTC)
Correct height for bridges in HO layout (General MRR)
by gachar001 22/07/2008 19:59:19(UTC)
Stone arch bridges the lazy way (Model kits & layout details, kitbashing and such)
by perz 01/07/2007 01:12:30(UTC)
Stone arch bridges and walls (Model kits & layout details, kitbashing and such)
by hxmiesa 16/10/2006 02:41:00(UTC)
Faller Bridges (Model kits & layout details, kitbashing and such)
by mattillini 09/06/2006 22:09:17(UTC)
Weathering RR bridges (Painting & Weathering)
by jselter 09/12/2005 16:47:25(UTC)
Weathering steel bridges (Painting & Weathering)
by Lloyd 17/03/2003 21:48:04(UTC)
This page was generated in 0.436 seconds.
