Offline garben
#1 Posted : 29 January 2019 18:12:40(UTC)
garben
I'm trying to determine if I have enough room to add a turntable, depth wise. I have a hidden area under where I would like the turntable to go and I want to make sure that it would not interfere when countersunk into the baseboard. And is it heavy? The baseboard in this area is 1 inch foam.
Thanks.
Offline mbarreto
#2 Posted : 29 January 2019 23:26:36(UTC)
mbarreto
The turntable is not very heavy, but I would go to 12mm plywood.
The turntable usually also have an roundhouse where you store locomotives. Several locomotives close together maybe very heavy.
I wouldn't go to foam, but this is just my opinion and others here have more experience in layout buiilding (although I already have a small layout with a turntable).
Miguel
Mostly Märklin H0.
Offline garben
#3 Posted : 30 January 2019 05:39:41(UTC)
garben
Thanks. What is the approximate depth of your turntable?
thanks 1 user liked this useful post by garben
Offline Br502362
#4 Posted : 30 January 2019 08:36:37(UTC)
Br502362
The old turntable 7186 isn't sunken so it stays on the table.
The new one 7286 is sunken.
Åke
Offline garben
#5 Posted : 31 January 2019 03:16:45(UTC)
garben
Perfect. Thank you!
#6 Posted : 31 January 2019 22:16:32(UTC)
The C-Track one coming out late 2019 74861 doesn't have the metrics for its dimensions posted yet.
Just that the diameter of the recess is 278 mm, though not if that is the inside diameter or the outside diameter (size of hole you'd need to cut out).
Nothing on the depth of the recess.
Offline mbarreto
#7 Posted : 31 January 2019 23:19:25(UTC)
mbarreto
I was expecting to see a photo of the turntable from the toy fair but until now didn't see. Don't know if Märklin has a pre-production sample there.
Miguel
Mostly Märklin H0.
Offline rbonet
#8 Posted : 15 March 2020 12:00:11(UTC)
rbonet
Are we still without any information relating the dimensions of the 74861? I don't see them on the maerklin.de page.
Also, the layouts on pages 261-262 of the 2019/2020 general catalogue are completely unuseful. There is a components list but the drawings doesn't show where to place them.
Does anybody have more info?
Rafael
Collecting Era I, II & III, mainly German, French & Spanish RR, some USA
Offline rbonet
#9 Posted : 23 December 2020 19:25:15(UTC)
rbonet
Märklin has released the manual for the 74861: https://static.maerklin....82dd00a6331606733281.pdf
Rafael
#10 Posted : 23 December 2020 23:48:20(UTC)
Thanks.
Definitely the TT is not heavy and a 10 mm plywood is good enough. It must be very plane (not warped)
To use foam as a base is not very good for resistance to weight (not the TT weight but the force you apply when you work nearby).
Ideally is plywood the best and a thin foam cover 1 mm thick maximum reduce any noise the mechanism may make in resonance with the wooden frame.
Attention: if there is thin foam it must be on all access tracks and on the TT as well.
The tracks are supposed to be aligned perfectly both horizontally and vertically (no grades)
Marklin Turntable 89983 (Small scale)
by jacklr1 06/11/2025 01:09:48(UTC)
Marklin turntable 74861 (Model railroad software)
by sanjiv 11/04/2025 09:49:35(UTC)
Marklin Turntable, DSD2010 & TC (Digital)
by Kiko 21/11/2024 17:06:30(UTC)
Marklin Turntable 74862 (Digital)
by Carlos 11/05/2023 23:48:18(UTC)
new Marklin turntable 74862 (H0-scale)
by Normmeister 14/04/2023 07:20:25(UTC)
Decoder for Marklin Turntable 7186 (H0-scale)
by ChrisBu 07/04/2023 17:19:25(UTC)
marklin turntable 74861 (Digital)
by greatrocks 28/11/2022 02:35:09(UTC)
Faller 120281 engine shed for new Marklin turntable (H0-scale)
by Normmeister 29/04/2022 09:42:44(UTC)
Marklin turntable 6651C internal wiring (H0-scale)
by mnusair 21/07/2020 00:23:55(UTC)
Marklin Turntable 7186 (Track plans)
by Philip McCracken 09/04/2020 14:55:58(UTC)
Marklin turntable running characteristics (H0-scale)
by obb_taurus 21/03/2020 20:03:27(UTC)
Marklin turntable doesn't seem to have enough power (H0-scale)
by obb_taurus 15/03/2020 18:55:43(UTC)
Wiring for Marklin Turntable (Digital)
by Drongo 07/02/2020 05:13:32(UTC)
Marklin Turntable & 60175 Booster (Digital)
by chrisisrang 05/04/2018 10:33:05(UTC)
Marklin Turntable project (H0-scale)
by Timnomads 30/05/2017 12:45:57(UTC)
Marklin Turntable (Digital components and Software reviews)
by Mike M 13/07/2016 05:50:42(UTC)
7168 marklin turntable help (H0-scale)
by thomas buckley 07/04/2016 17:40:01(UTC)
Marklin turntable project (H0-scale)
by ixldoc 19/02/2016 01:34:39(UTC)
Signals on Marklin Turntables (Digital)
by Oscar0645 21/08/2012 23:58:21(UTC)
Marklin turntable - unable to enter programming mode from Ecos (Digital)
by obb_taurus 04/03/2012 19:18:59(UTC)
Part numbers for Marklin turntable 7286 (H0-scale)
by Bryan 26/03/2011 05:24:45(UTC)
I have got the Marklin turntable 7286 (H0-scale)
by sebastian 23/10/2007 04:22:26(UTC)
Marklin Turntable Noise (H0-scale)
by Dick 01/05/2007 03:02:32(UTC)
by tnx jake 07/10/2003 18:02:19(UTC)
This page was generated in 0.460 seconds.
