Offline Drongo
#1 Posted : 05 June 2011 12:03:17(UTC)
Drongo
One of the most used parts of a train set are the couplings, however, they seem to have very little detailed information about them.
Firstly, what are the different types of couplings available from Marklin and how are they used? Confused
Secondly, I've found it is sometimes difficult to couple carriages together, AND, impossible to couple together on a curve. Bored
Can you please assist me with some details.
Greg
Offline kbvrod
#2 Posted : 05 June 2011 14:47:48(UTC)
kbvrod
Hi Greg,all,
What Märklin coaches?Older ones had what I call 'hook&loop' and are frame mounted.
Coupling on curves is difficult as MR track has a much tighten radius than real railroads.
Dr D
Offline Yumgui
#3 Posted : 05 June 2011 15:29:39(UTC)
Yumgui
@ youngagain,
Most every Märklin catalog has a list of coupler parts ... see attached (from 94-95 catalog).
The "hook & loop" coupler kbvrod spoke about are pictured upper right on the first page ...
You will hopefully find your happiness in there. ThumpUp
Yum Wink
Offline hennabm
#4 Posted : 05 June 2011 15:31:12(UTC)
hennabm
Kolls full book if you have access will show you all the various couplings issued by M*.
I have models from the 50s to the close clouplers and all do fit together. A reason for them not doing is is that they are not aligned or bent.
As for coupling on a curve - this is very difficlt as Dr D mentioned because of the radii.
1957 - 1985 era
What's digital?
#5 Posted : 05 June 2011 20:31:55(UTC)
Hi, Greg!
Close couplers won't couple in curves. But I prefer them as trains look better.
Roco's universal couplers are compatible with Märklin and couple more easy (for cars and coaches with NEM pockets).
#6 Posted : 05 June 2011 21:35:42(UTC)
Marklin has basically three types of wagon coupling in use over the last 50 years.
The oldest is the metal type Relex coupler, which is on the older 46xx and 45xx series of freight wagons. It is also used on the 40xx passenger coaches with metal bodies.
The next development from Marklin was the plastic type relex coupler. This is found on 44xx freight wagons, and on most earler plastic bodied passenger coaches. It is currently only found on hobby wagons.
The most recent type is the close coupler. This is found on all modern wagons except hobby wagons.
Although they are all meant to work together, my experience is that the metal relex work well with the plastic relex, and the plastic relex work well with the close couplers, but the metal relex and close couplers are harder to couple and uncouple together.
Couplers from other makes tend to work better with the relex couplers than with the close couplers.
Some cheap Marklin locos have just a simple hook. These work well with both types of relex, but are really difficult to couple with close couplers.
Offline Joseph Meiring
#7 Posted : 05 June 2011 22:19:37(UTC)
Joseph Meiring
I agree Ray, the plastic and metal relex are quite compatible. I do prefer the older metal relex; the newer plastic ones "bend" away from each other quite easily even on a "slight" curve - you need to be a fair distance away from a reverse curve in the shunting bays for the plastic couplers to align in the straight position, bit of a pain if space is at a premium!! I have invested in a coupling gauge, and am slowly sorting out all my damaged couplers!
I also invested in a pack of relex couplers to change the close couplers for easier coupling the metal to plastic relex......Joe
#8 Posted : 05 June 2011 22:52:02(UTC)
The reliability of the so called Relex coupler is legendary. It couples easily.
All my Marklin rolling stock is post 1995, so all have the new style 7203 coupler, so called close coupler "with guide" which is the little plastic tongue that guides two couplers together.
In my experience, these do not couple easily. And never on curves. It actually annoys me mildly.
I am thinking one day I could switch all my couplers to Kadee. You can purchase Kadee for the modern NEM coupler pockets. Kadee are the only prototypical action/look couplers in the world, and are widely used, especially in the US. I will have to test first if they couple Marklin stock on curves.
The club I belong to uses all Kadees on American models, and they work beautifully. I think it will be quite an expensive to change all my couplers. I will weigh up the cost v the intended benefits before I commit.
As I said earlier, I am only mildly annoyed with the coupler issue, as I am a hands on sort of modeller anyway.
Offline ricky
#9 Posted : 09 June 2011 00:17:38(UTC)
ricky
Hi Kimball,
thanks for the tip about Kadee. I looked at their web site; the NEM 362 coupler (the one to be used with Märklin cars with NEM pocket) has 4 shank "options": short, medium, long, and extra long. Do you know or anybody knows which one will be the best for Märklin cars? Could it be different for different lengths of cars?
They are not cheap, but I guess you could start replacing them either by era (if you do not mix eras) or first for passenger cars, and later for freight cars or vice versa.
I am also wondering if the lower part of the coupler is just to "look like" the braking pipe between cars, or something else? Unsure
If it is, it seems more american than european, as the braking pipe(s) in Europe are on the side of the cars, not in the middle.
Ricky. Smile
Offline ricky
#10 Posted : 09 June 2011 00:21:19(UTC)
ricky
Hi Tom,
just curious about the Roco and Märklin couplers compatibility. Does this work well with 27 cm cars? Do the cars touch each other in straight line, or not?
Ricky. Smile
#11 Posted : 09 June 2011 01:06:08(UTC)
Hi Kimball,
thanks for the tip about Kadee. .......
Ricky. Smile
Hi Ricky,
Yes, I think the lower curved pin which is used as an uncoupling swivel under the influence of a track mounted magnet, is marginally designed to look like a brake hose. Quite clever. It certainly looks OK on American or Australian stuff, would not be sure for European, as I have never studied that.
While the short kinematic couplers have certainly added some perceptive advantage to model trains, I do question their practical effectiveness. They do of course considerably shorten a long goods train.
#12 Posted : 09 June 2011 01:08:57(UTC)
I for one am quite interested in the coupler question. On my Marklin layout, I use two lots of couplers. One is the latest Marklin 7203, and I also use the older Fleischmann hook coupler. I do this because I am enamoured of the older Fleischmann rolling stock that comes with this coupler riveted on.
It is easy for me to change the NEM coupler on the tender of an engine, just for a running session to use these older wagons. They couple well on curves, and I really like the Fleischmann construction method on these old wagons, because I easily change the wheels for AC running.
#13 Posted : 09 June 2011 09:53:41(UTC)
I'd say they have the same length as the M* close couplers, so distance will be the same.
I use them for all my non-Märklin rolling stock, so I don't have 27 cm coaches with this type.
Only exception are some Piko Hobby locos, but that is the fault of the loco (some work with the height adjustable Roco universal coupler (shaft is slightly longer), some still have hook and loop coupler).
The distance will be slightly shorter with the Roco close coupler (which is not compatible with M* coupler or Roco universal coupler).
My train of 30 cm coaches uses them between the coaches with universal couplers on the outside.
AFAIK the Roco universal coupler is M* compatible without restrictions. And it's smaller (not so high) so it can be used where M*'s close coupler touches the buffers.
I'll try to post some pictures (if I find the time).
Offline kariosls37
#14 Posted : 09 June 2011 12:41:09(UTC)
kariosls37
Hi Kimball,
Ricky. Smile
Hi Ricky,
I am experimenting a bit with Kadees at the moment, after deciding to go with them for my scratchbuilt stuff. I still have to figure out quite a bit of their ins and outs, but I don't have the time at the moment.
They couple very well, it should not move the wagon from it's spot if you do it carefully. They are a bit harder to uncouple manually, but they uncouple really well with magnets, provided that the couplers are adjusted correctly(the tolerances are a bit smaller than the usual couplers) Just like Marklin's Relex couplers, they have a way to uncouple and then push the wagon off the uncoupling magnet allowing you to leave the wagon there.
I hope this sheds a little more light onto the Yankee side of this subject
Rick
Replacing couplings on 37618 (General MRR)
by Drongo 28/01/2025 07:22:42(UTC)
Shorter couplings for older autotransportwagen - Solved (H0-scale)
by PeFu 01/02/2024 23:06:41(UTC)
BR216 couplings (H0-scale)
by revmox 19/10/2023 07:41:42(UTC)
Couplings used in the UK (Prototype)
by Mr. Ron 06/01/2023 09:07:30(UTC)
Locomotive couplings (H0-scale)
by Scharnhorst 10/03/2022 21:57:26(UTC)
Relex couplings and Short ones (H0-scale)
by 220 18/10/2021 18:22:46(UTC)
Relex couplings and NEM 360 ones (H0-scale)
by 220 18/10/2021 13:34:39(UTC)
Various short couplings from different brand names (General MRR)
by river6109 10/03/2021 11:37:14(UTC)
Unusual Couplings (Small scale)
Belarus Ricinport 25/01/2021 16:49:13(UTC)
Couplings (H0-scale)
by mikemasey 06/11/2020 11:33:29(UTC)
Different types of couplings on 3072.1 ? (H0-scale)
by Himmelstrup 23/05/2020 02:04:16(UTC)
Magnetic short couplings (H0-scale)
by river6109 28/01/2020 03:10:51(UTC)
Roco coaches and short couplings (General MRR)
by ocram63_uk 12/08/2019 18:57:12(UTC)
instructions for installing the couplings marklin 2681 (H0-scale)
by Hank1027 05/03/2019 19:11:27(UTC)
Conducting couplings for 42755 Orient Express set (H0-scale)
by kiwiAlan 25/08/2016 11:03:22(UTC)
Change couplings (H0-scale)
by gunado 22/01/2016 01:07:31(UTC)
newly constructed symmetric 4 pin electrical couplings (H0-scale)
by river6109 13/04/2015 18:19:04(UTC)
Maxi realistic couplings? (Big scale)
by NS1200 07/11/2014 20:35:49(UTC)
NOHAB Couplings? (H0-scale)
by Marcus01 18/04/2014 12:17:07(UTC)
New Digital Telex Couplings BR 150 [Märklin item 37851] (H0-scale)
by GlennM 05/01/2014 15:25:49(UTC)
Conversion of relex Couplings to Nem pockets (General MRR)
by nevw 26/01/2013 01:04:06(UTC)
Servicing of couplings (H0-scale)
by Rdsmarklin 04/05/2011 20:48:12(UTC)
(Z SCALE) Henschel-Wegmann couplings (Small scale)
by Breitenfurt 03/12/2010 09:53:26(UTC)
ICE 2 train electrical couplings (H0-scale)
by river6109 16/09/2010 18:19:25(UTC)
Changing Faulty Couplings (H0-scale)
by osilva 23/02/2010 19:55:16(UTC)
marklin couplings (H0-scale)
by fred freshney 26/11/2009 14:52:46(UTC)
shorter couplings for Märklin Hobby locos (H0-scale)
by Hemmerich 03/11/2009 12:43:48(UTC)
Märklin, Roco & Fleischmann electrical couplings (H0-scale)
by river6109 22/08/2009 05:22:50(UTC)
Old Fleischmann Couplings And Maerklin Relex (H0-scale)
by Roman 11/08/2008 22:07:45(UTC)
Märklincurrent conducting couplings on Rheingold (H0-scale)
by Hemmerich 23/07/2008 16:15:19(UTC)
ESU Current Conducting Couplings (General MRR)
by nevw 15/07/2008 14:12:55(UTC)
Alternative Couplings (H0-scale)
by Monique78 27/04/2004 16:29:57(UTC)
This page was generated in 0.781 seconds.
