Offline alonso231gery
#1 Posted : 26 July 2006 01:31:07(UTC)
alonso231gery
I have heard that the scale of every loco is 1:87
and wagon's (or freight wagons) scale is 1:100 is that true?
An outsider.
Offline Sander van Wijk
#2 Posted : 26 July 2006 02:10:41(UTC)
Sander van Wijk
It's true that most (not all) coaches are not really 1:87. This due to the increased playability of shorter coaches compared to longer ones. The scale of most Märklin coaches (except some new models announced this year) is 1:87, but the length is shortened to a 1:100 scale. Fleischmann does the same thing, usually 1:92.5 length scale. Roco has both 1:100 length scale and "true" 1:87 length scale coaches in their catalogue.
Loco's are usually (almost) precisely 1:87 scale. (Exception: Adler, that train is 1:92 scale completely)
Sander
#3 Posted : 26 July 2006 02:54:27(UTC)
Coaches that are 26,4 m long are available as 24 cm M* models (scale 1:110), as 26,4 cm models (scale 1:100).
New M* coaches announced this year will be closer to 1:87, but still are too short.
Offline McLae
#4 Posted : 26 July 2006 04:15:35(UTC)
McLae
Items over about 200cm have trouble making it past R1 curves. (Especially if you have catenary![:0])
Most Loks are less than 200cm even in full 1:87 scale.
Coaches, long heavy flat cars, railway guns[}:)] could be too long if in correct scale length.
Marklin large steam Loks have a hinge im the middle of the frame to let the Loks handle 360mm curves. Patented, so no other maker can have a hinge.[xx(]
Most Marklin coaches are 1:100 length. Other makers are starting to have shorter coaches too. (Roco, Klein M., etcbiggrin)
The McLae
Offline viragoLDR
#5 Posted : 26 July 2006 12:03:22(UTC)
viragoLDR
You have been a member since:: 12/01/2005(UTC)
200cm loco's? What are you running, scale 1 big boys? ;)
- Martijn
Offline Basil
#6 Posted : 26 July 2006 15:08:14(UTC)
Basil
As I am new in the forum and in modelling I`m not sure in saying that Marklin made coaches in 1:110 scale (24 cm.)up to 2003 because as stated by others 24cm was more practical for curves. Since 2003 Marklin started in 1:100 {27cm )These coaches are not shortened to scale. This is done by omitting compartments or windows. If a coach has 12 compartments the Marklin model has 10. Fleisccmann has 1:93,5 scale . True 1:87 scale are made by Roco nad Lima .Generaly speaking
1:110....24cm
1:100....27cm
1:93,5...28,2cm
1:87.....30,3cm
Please correct me if i`m wrong
#7 Posted : 26 July 2006 16:39:18(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Basil
Right... ;-)
1:100 has been produced by Märklin for more than 30 years. (Not sure about the exact year though)
You are very right about the way Märklin has shortened the wagons; omitting entire compartments. This makes mixing 1:100 wagons from Fleischmann and Roco almost impossible, as these manufacturers did NOT omit compartments.
The 1:100 wagons from Roco are (were?) in fact Ade-wagons which they got when they bought out Röwa. Ade wagons can still be bought en kit-form.
Apart from the new 1:93 which Fleischmann "discovered" some 6 years ago, there are also other scales like 1:88,5, 1:90 etc... liberally used by the manufacturers today. (Go check the scale of some ICE-3 ;-)
The new Insider VT08 is actually 1:93, like the new wagons announced this year from Märklin.
Why 1:93; supposedly that is the max. size (length) for trains going round a R1 curve without picking up each and every caternary masts, signals, tunnels and rolling stock on parallel tracks.
Offline MHauge
#8 Posted : 26 July 2006 21:10:05(UTC)
MHauge
My longest wagon is a Märklin 48037 DSB "Habbins", it measures close to 27 cm from buffer to buffer, it has problems with my tunnels, didn't have anything this long when i installed the tunnels, it has the option to move the wheel-boogies, so i can make it run fine, but it looks strange when they get close enough.
My point is:
Long wagons+tunnels in R1 curves is not a good idea...
Michael
Märklin C-tracks, Mobile Station, Danish Ep 4
#9 Posted : 27 July 2006 14:17:45(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MHauge
<br />My longest wagon is a Märklin 48037 DSB "Habbins", it measures close to 27 cm from buffer to buffer, it has problems with my tunnels, didn't have anything this long when i installed the tunnels, it has the option to move the wheel-boogies, so i can make it run fine, but it looks strange when they get close enough.
I agree! I have the same wagon, and on my previous layout, it didnt go through all tunnels.
That´s why I have used this particular wagon as test-vehicle this time, when building my layout!
Alas it hit a spike in the rail (a provisional spike not nailed all the way down)
RIP+++
BTW; Kibri makes a tunnel-portal fit for M and C track geometry. (Sorry, dont remember the ref#)
Offline Munich 1860
#10 Posted : 27 July 2006 18:36:45(UTC)
Munich 1860
<br />I have heard that the scale of every loco is 1:87
Where have you heard this ??? Not true for MANY locos from Märklin !!!!
Hans
#11 Posted : 27 July 2006 23:21:40(UTC)
alonso231gery
A little bird told me thatbiggrin.(kidding)
A friend of mine told me that,who has many locomotives and knows many things.
I decided to open this topic so as to know if he is correct.wink
An outsider.
Offline Munich 1860
#12 Posted : 28 July 2006 15:23:10(UTC)
Munich 1860
<br />A little bird told me thatbiggrin.(kidding)
Go ask your friend whether he thinks that 3015 the old crocodile, 3053 / 3054 the E03 / 103, in fact ALL Märklin E 03's, and especially the series 218, because they are much newer, are in fact in scale 1:87 .....
I wonder how many things he knows and will tell you ....
Hans
#13 Posted : 28 July 2006 19:11:08(UTC)
alonso231gery
I said he knows many things not everything like you.
B.t.w. i sense that you are right.
There are always exceptions Hans, but the basic rule is 1:87 for the locomotives and shorter wagons...
He said me that that applies for the new locomotives...
So maybe you are both right.wink
An outsider.
Offline verheyen
#14 Posted : 28 July 2006 19:49:45(UTC)
verheyen
An not for all wagons. The shorter coaches (2 axle, 4 axle Umbauwagen and many others) are 1:87
Offline jonquinn
#15 Posted : 28 July 2006 21:06:54(UTC)
jonquinn
what is the scale (or maybe scales) of the old 3016 crocodile, and the older E03's?
the old crocodile looks larger than 1/87. (I don't have one of the old ones.)
Offline verheyen
#16 Posted : 29 July 2006 00:24:59(UTC)
verheyen
As far as I know, the 3016, and also the SE(T)800 /E44... are closer to 00 than H0. The older E03 is shorter than 1:87. I believe the E41 and some others are too.
p.
[size=1" face="Verdana" id="quote]quote:Originally posted by jonquinn
<br />what is the scale (or maybe scales) of the old 3016 crocodile, and the older E03's?
#17 Posted : 29 July 2006 03:18:13(UTC)
Up to 2005 M* produced class 110 that are too short (Kastenlok) and class 110 that are too long (Bügelfalte, trucks and frame are actually taken from class 111).
The new E 10.3 should be 1:87!
Don't expect class 218 to be 1:87 ...
And even if they write 1:87 in the catalog, you may get something different (ICE is 1:88.x or 1:89.x, not 1:87). That's why the sued Piko - they ICE 3 is exactly as long as M*, so this none is not 1:87 either ...
Edit: according to MIBA the scale of the ICE 3 is 1:88.8.
#18 Posted : 29 July 2006 09:22:58(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by verheyen
<br />and also the SE(T)800 /E44 are closer to 00 than H0
Thanks, Peter. I always wondered why my old P#2702 E44 is standing that tall ... [:0]
Offline Hemmerich
#19 Posted : 30 July 2006 20:10:09(UTC)
Hemmerich
To be specific - 1973. It was the so called "Popwagen" #4091 thru #4094 with a scale of 1:98 for the 26,4m cars and 1:102 for the 27,5m cars. Here's a picture of three of them. As you might see, I've converted them in the meantime to short coupling which makes a much nicer train with other new cars, especially those from the sets #26512 and #42943.
[size=1" face="Verdana" id="quote]quote:You are very right about the way Märklin has shortened the wagons; omitting entire compartments. This makes mixing 1:100 wagons from Fleischmann and Roco almost impossible, as these manufacturers did NOT omit compartments.
Not really. Mixing them is not really an issue. The only (wellknown) problem is proper coupling with the ROCO cars due to their lower buffers. Bottom to top: Märklin #4292, #4092 (as well converted to short coupling), GFN #5199, ROCO #44390.
[size=1" face="Verdana" id="quote]quote: The 1:100 wagons from Roco are (were?) in fact Ade-wagons which they got when they bought out Röwa. Ade wagons can still be bought en kit-form.
The ROCO cars are actually former RÖWA cars. The ADE cars were offered in scale 1:87 by Mr. Ade from his small own company that was left for him from the RÖWA crash.
[size=1" face="Verdana" id="quote]quote:Apart from the new 1:93 which Fleischmann "discovered" some 6 years ago, there are also other scales like 1:88,5, 1:90 etc... liberally used by the manufacturers today. (Go check the scale of some ICE-3 ;-)
Correct!
Even more/better - the GFN cars will fit almost ideal to the new Märklin cars, even though they already fit quite well to the 1:100 Märklin cars! (second car from top on following pic).
Fleischmann actually offers their 282mm cars already since 1989 with the announcement of their IR models. Due to the relative long delay of Märklin to offer their IR Bistro, I had purchased the 282mm GFN model and it was just perfect! (again second car from top).
In summary, the difference between the current Märklin 1:100 and the new 1:93,5 cars is much less harming than the real large step from 1:100 to 1:87.
Offline Hemmerich
#20 Posted : 30 July 2006 20:13:57(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
The same scale is not one of the real reasons for the plagiat sue (which is actually dealt about on 30.10.2006 at the court in Köln).
#21 Posted : 30 July 2006 20:35:30(UTC)
First of all I thank you for your additional comments.
But I must disaggree about the above quote; When I say that it is "almost impossible" to mix the waggons, I am not talking about a technical couplings problem, but about the HUUUGE estethic problem in mixing SAME cars from different manufactores, when some has 8 and other 9(?) compartments (1st class), or 10 and 11(?) compartments (2nd class); Thereby making a Roco 1st class car almost EQUAL to a Märklin 2nd class!!!
#22 Posted : 30 July 2006 20:43:46(UTC)
One question;
I have a couple of these vintage waggons, especially a bordeaux/grey dining car which I am very fond of, BUT they are so old that the they are capable of negotiating the big lanterns on the old M-track switches! I would like to change that, to a bogie similar to later versions of the same coaches (about 5mm shorter bogie)
Do you know what is needed? Just the two bogies, or must the whole bottom of the car be changes (or will it suffice to drill new holes for the bogies in the bottom?)
Anybody in the know?
Thanks.
Offline Hemmerich
#23 Posted : 31 July 2006 01:02:18(UTC)
Hemmerich
Unfortunately, these "vintage" models have a bottom construction including the bogies and the way how they are mounted which IMHO cannot be converted to a short coupling version (maybe oly with a special kit from Symoba). Even worse, if you try to open the coupling holder to only replace the coupling with a new one it usually just breaks.
Therefor I simply replaced the complete bottom section by ordering the spare parts for the new cars. Now I not only have the advantage of the short coupling but also the electric connection for the interior lighting without the need for a contact shoe at every car.
I cannot tell you if this will solve your M-Switch lantern problem since I sold all my M-Track stuff to a friend in Boise, ID already many years ago. Lucky enough, Märklin came up with their Alpha tracks right in time again for my kids! Smile
Offline Hemmerich
#24 Posted : 31 July 2006 01:29:56(UTC)
Hemmerich
Henrik,
I did and do understand your issue, but I never encountered or felt this myself as "huge". It's simply a fact or the evel of acceptance for certain compromises that each manufacturer has to make with his models.
And honestly, in most cases my so called "Wagenumlaufpläne" (car usage plans) just by mystery Cool have cars from only one supplier in a specific order or even train.
If someone isn't willing to make certain compromises then Märklin as little as any other model manufacturer is probably able to fulfil the user expections - the only answer can then be "go prototypical"! biggrin
In comparison of the 1:100 - 1:93,5 vs. 1:100 - 1:87 cars, the new 282mm Märklin cars are a much better fit, especially in an "esthetic" view. The following picture also shows how well even certain cars from different manufacturers (here Märklin & ROCO Eurofima) can fit together. The ROCO dining car is just perfect for the EC 65/66 "Mozart", one of my favorite trains.
From top to bottom:
1:100 ROCO dining car WRmoz #44312 orn
1:100 ROCO 2. class car Bmoz #44309 orn
1:100 Märklin 2. class car Bmoz #4167 (converted to short coupling) orn
1:87 ROCO 1./2. class car ABmz #44640 orn
1:87 ROCO 1. class car Amz #44665 dark red
1:100 Märklin 1. class car Amz #4272 dark red
1:100 ROCO dining car WRmz #44234 dark red
Offline Spoetnik
#25 Posted : 31 July 2006 15:14:10(UTC)
Spoetnik
Useful pictures Lutz!
#26 Posted : 01 August 2006 18:39:26(UTC)
alonso231gery
Yes,thanks to Lutz i understood perfectly what i did not know.
Ps:"bring back the flag".
An outsider.
Offline Vardex
#27 Posted : 05 August 2006 22:21:47(UTC)
Vardex
[size=1" face="Verdana" id="quote]quote:[i]
Sorry to say this;but M doesn't have a class 218.
They make only class 216 that are pretty close to 1:87.
Sure,they print 218 on it,but it still is a 216.
Bart
#28 Posted : 06 August 2006 11:56:42(UTC)
Nice collection of coaches.
Marklin z scale (Digital)
by Allen Lee 08/06/2025 01:53:52(UTC)
Z-scale, 8914 Tower mast (Small scale)
by Manga 16/04/2025 12:28:05(UTC)
Z scale newbie with questions about powering the system (Small scale)
by moenegj 09/04/2025 08:11:16(UTC)
Marklin Z-Scale Signals Part 2 (Small scale)
by Fluegelmeister 07/04/2025 01:07:03(UTC)
New Toporama Video - Z-scale Signals! (Small scale)
by Fluegelmeister 10/03/2025 04:36:10(UTC)
New Z Scale Track Planning Link (Small scale)
by Zme 11/02/2025 03:08:51(UTC)
HELP! Setting up Z scale track to transformer (Small scale)
by mjdd11 07/12/2024 18:42:35(UTC)
Mobile Station 2 with N-scale digi locos (Small scale)
by einotuominen 23/10/2024 15:50:03(UTC)
Z-scale worm-gear for Steam loco (Small scale)
by Manga 29/09/2024 10:27:05(UTC)
N-scale: Red & white track bumper (Small scale)
by Manga 15/09/2024 08:13:17(UTC)
British HO scale coaches (H0-scale)
by Normmeister 15/09/2024 07:00:22(UTC)
Using Snail Controller with Miniclub Marklin z scale engines (Small scale)
by Mary 24/07/2024 20:05:11(UTC)
A Z Scale Source (Small scale)
by Zme 24/06/2024 17:24:40(UTC)
My Z-scale layout (Small scale)
by einotuominen 15/06/2024 08:16:03(UTC)
Z Scale Vehicles (News from Märklin and others)
by kiwiAlan 24/04/2024 16:27:47(UTC)
Curved Lh Manual turnout.....Zscale (Small scale)
by spinnerguy 09/04/2024 22:34:36(UTC)
Disposal of Z scale collection in Australia (Small scale)
by kimballthurlow 04/04/2024 00:35:03(UTC)
Flying Scotsman for Z scale (Small scale)
by Carim 01/04/2024 09:20:34(UTC)
Z scale backdrops (Small scale)
by ProductionMgr 14/03/2024 01:22:24(UTC)
z scale risers (Small scale)
by ProductionMgr 14/02/2024 02:57:50(UTC)
Rock molds for Z scale (Small scale)
by einotuominen 12/02/2024 15:49:12(UTC)
Marklin Z Scale (Older Model) Spare Parts in US (General MRR)
by NewToThis 26/09/2023 02:18:09(UTC)
Un-scale coaches. (H0-scale)
by dave55uk 18/09/2023 21:11:38(UTC)
Making older z scale motors look better (Small scale)
by Artologic 18/09/2023 16:57:56(UTC)
Marklin 0 6 0 Mini Club Steam Locomotive Z Scale bushings (Small scale)
by TLS 01/09/2023 02:38:47(UTC)
Z Scale Electric Locomotive Pantograph (Small scale)
by Bahner 31/07/2023 00:43:57(UTC)
N scale Mois from Ukraine (Small scale)
by timon220 14/07/2023 20:07:13(UTC)
Z scale collection for sale at Reynaulds (Small scale)
by husafreak 30/06/2023 22:11:46(UTC)
An unusual Z-scale video (Small scale)
by RobMacK 12/06/2023 12:13:44(UTC)
New Colorado Z-Scale Model Railroading Group (Events, forum member meets, exhibitions & TV shows)
by veloboldie 01/04/2023 21:09:02(UTC)
Layout Room Sizing in HO Scale - Experienced Feedback Needed (H0-scale)
by 5HorizonsRR 09/03/2023 00:15:23(UTC)
Is there a Colorado Z-scale fun club, group etc.? (Events, forum member meets, exhibitions & TV shows)
by veloboldie 12/02/2023 18:16:58(UTC)
Big scale - WLAN MS2 - dead rail idea ;-) (Big scale)
by Purellum 28/01/2023 22:00:38(UTC)
Trackbed for Z scale (Small scale)
by swedishmike 08/01/2023 17:56:49(UTC)
Train Shops or 1:1 Scale Train things in Copenhagen? (H0-scale)
by 5HorizonsRR 08/10/2022 19:22:04(UTC)
Z scale 8589 wiring instructions (Model railroad wiring)
by hennabm 18/09/2022 14:54:35(UTC)
Z scale “Swtichman’s Nightmare” switching layout. (Small scale)
by michelvr 01/09/2022 19:46:55(UTC)
Z Scale "Wunderrad" (Small scale)
by kiwiAlan 11/08/2022 17:01:47(UTC)
Z scale winter back-scenes (Small scale)
by georgi UK 26/07/2022 19:21:12(UTC)
Calculating a scale for using MARKLIN HO track (General MRR)
by nzrabbitty 20/05/2022 05:24:09(UTC)
Scale Trains has acquired the HO scale moulds from MTH (General MRR)
by I_love_Marklin_37538 14/05/2022 09:03:03(UTC)
Cars and trucks in HO scale (H0-scale)
by Mr. Ron 07/05/2022 07:26:42(UTC)
Z scale locomotive user manuals (Small scale)
by thomas buckley 28/03/2022 04:44:43(UTC)
3-axle Marklin 1-scale coaches: Any lighting suggestions? (Big scale)
by cramcke 01/02/2022 17:47:53(UTC)
HO Scale Automotive tunnel Portals (H0-scale)
by frickwg 21/01/2022 01:21:26(UTC)
DB BR80 scale z (Collector's Corner general)
by Karl K. 06/01/2022 21:48:45(UTC)
My start in Z scale... (Small scale)
by Donb 18/12/2021 20:12:19(UTC)
A German hotel model using a HO scale Kibri kit (Model kits & layout details, kitbashing and such)
by kimballthurlow 18/12/2021 11:32:10(UTC)
Faller Scale and Model Numbers (Faller collectibles and other vintage accessories)
by Saulo35 18/12/2021 01:35:59(UTC)
N scale Folkstone channel tunnel layout (Great layouts I have seen...)
by marklinist5999 08/12/2021 16:47:59(UTC)
This page was generated in 1.011 seconds.
