Offline alonso231gery
#1 Posted : 27 February 2006 20:33:27(UTC)
alonso231gery
I have a 3-pole motor and i want to upgrade it,i have never before a serious experience with changing decoders and 5-pole motors.
Can i upgrade the loco only by myself with the 5-pole kit?
Or it is complicated,so is better my dealer to do it.
I am willing to learn.biggrin
An outsider.
Offline rschaffr
#2 Posted : 27 February 2006 20:36:51(UTC)
rschaffr
Nikos: It is not hard, but you will need to do some soldering. If you have some soldering skills you should be ok. The mechanical part of the installation is easy if it is one of the loks on the approved conversion list. If not, it may need some modification to the lok, the field magnet or the motorshield, in which case I wouldn't recommend trying it yourself for a first installation.
-Ron
#3 Posted : 27 February 2006 21:01:21(UTC)
alonso231gery
The loco that i want to upgrade is the one at the 29815 set with the rotary crane.
An outsider.
Offline rschaffr
#4 Posted : 27 February 2006 21:13:41(UTC)
rschaffr
I don't know that lok, but I beleive it is a DCM (drum commutator motor) so should be rather straightforward to do.
-Ron
Offline ola.w
#5 Posted : 27 February 2006 21:40:04(UTC)
ola.w
I have recently upgraded my loco from the same set with the 60760 kit and the decoder and motor was not any problem but I assembled it again it was to tight so I had to make some more space with a dremel. I got some soldering skills and it took me about one hour to remove the old parts, clean it and fit the new parts. However it took between one and two hours to mill out more space in the body of the loco.
Anyway I can recommend the 60760 kit, much easier than a analog to delta conversion I did about a year ago. Made two conversions with the kit and its cheap to.
Märklin | HO | K Track | Digital | III+IV
Offline franciscohg
#6 Posted : 27 February 2006 21:40:06(UTC)
franciscohg
Chile
Just put the xx901 kit and......
#7 Posted : 28 February 2006 09:47:23(UTC)
I am allready confussed.It is very difficult for me to realize how
some members of the forum can make all these changes to the locos.
I am impressed.[:I]confusedbiggrin
Offline pa-pauls
#8 Posted : 28 February 2006 11:01:13(UTC)
pa-pauls
Hello Nikos,
As you have the CS I would recomend the
kit 60921 with 5-pol motor and Mfx decoder.
Greetings
Pål Paulsen
Offline franciscohg
#9 Posted : 28 February 2006 15:37:19(UTC)
franciscohg
Chile
But it would be nice to put a LS mfx, more if there is one specific for the loco, in that case it will be better to buy the kit as spare parts.
Offline Hemmerich
#10 Posted : 28 February 2006 20:21:23(UTC)
Hemmerich
ESU #62425. In addition to the DCM (drum commutator motor) parts, You'll also need a NEM pocket cable.
Lutz
#11 Posted : 28 February 2006 22:47:58(UTC)
<br />I am already confused. It is very difficult for me to realize how some members of the forum can make all these changes to the locos. I am impressed [:I]confusedbiggrin
Panayotis: With our Guru Jorge's excellent advice [:p] it was a walk in the park. Even for me ... [xx(]
Just do it,
Offline franciscohg
#12 Posted : 01 March 2006 00:41:05(UTC)
franciscohg
Chile
Here you can check the parts that you need:
http://www.x-train.de/grund/motorel.htm
Offline al_pignolo
#13 Posted : 01 March 2006 12:30:24(UTC)
al_pignolo
When you change the rotor from 3 to 5 poles, do you need to change the field inductors? (That is, re-wrap that thin copper wire?)[xx(]
Bye
Offline franciscohg
#14 Posted : 01 March 2006 18:18:27(UTC)
franciscohg
Chile
Nop, you use a permanent magnet, you transform the motor into a DC one.
Offline Mikael
#15 Posted : 05 March 2006 02:29:24(UTC)
Mikael
I have just installed a decoder in one of my loks today. No big deal for me, but I remembered this discussion, and I decided to take a few pictures along the way. Enjoy:
http://www.ejberg.dk/gallery/trains/decoder/index.html
Offline Guus
#16 Posted : 05 March 2006 10:46:32(UTC)
Guus
Hi Mikael,
Very nice pictures[:p].
What kind of soldering iron do you use?
I've digitized my old BR44 and must say that the mechanical part of the conversion wasn't difficult.
Soldering,although succesful,was a different story.
Any advise will be appreciated.
Kind regards
Guus
Kind regards,
Guus
#17 Posted : 05 March 2006 11:29:55(UTC)
I have the Marklin 70910 which is great - price was comparable to other units I can buy down here...
Offline Mikael
#18 Posted : 05 March 2006 16:08:11(UTC)
Mikael
I use an old Ersa 24V 60W soldering iron. Nothing special, but way better than a standard cheap iron, that plugs directly into the wall.
BTW, I've updated the gallery with some more pictures, as I have finished the installation of my homemade head- and taillights. And what a task. I'm not going to do that again anytime soon. But I am very pleased with the final result.
Decoder installation 60976 on 37903 (Digital)
by Antonis_Gr 09/01/2022 18:22:34(UTC)
Decoder installation (Digital)
by GLI 16/09/2021 05:31:53(UTC)
decoder installation help please (Digital)
by Chad0x78 24/12/2014 14:05:15(UTC)
TCS (T1) Decoder Installation on Marklin Lok (Digital)
by bronco 28/05/2014 19:59:22(UTC)
ESU Decoder installation question (Digital)
by Chris6382chris 13/07/2012 16:20:09(UTC)
60945 locsound decoder installation. (Digital)
by bulenty 16/03/2012 22:03:17(UTC)
New EASY FIT decoder installation guide (H0-scale)
by AshleyH 27/01/2012 19:51:11(UTC)
My First Märklin "mld" Decoder Installation (Digital)
by Frankenbahner 07/12/2011 22:15:08(UTC)
decoder installation video (Digital)
by Gregzim 05/09/2011 13:22:28(UTC)
Solid Wire for Decoder Installation (Conversion) (Model railroad wiring)
by Caplin 11/01/2010 18:02:43(UTC)
Trix 22706 decoder installation (Digital)
by marklinologos 26/01/2009 11:29:27(UTC)
UHLENBROCK DECODER INSTALLATION (Digital)
by Bahn-an-arama 14/11/2008 14:30:03(UTC)
6080 c80 decoder installation instructions? (Digital)
by Lucky1028 16/06/2003 17:12:31(UTC)
Decoder installation Uhlenbrock 75100 (Digital)
by kgsjoqvist 30/05/2003 12:01:18(UTC)
This page was generated in 0.417 seconds.
