Offline Xav
#1 Posted : 17 October 2004 16:02:44(UTC)
Xav
hello to all
looking at the wonderful site of Peter Funck I found his page about contact tracks
I have a problem understanding however how the 5146 tracks in comparison to the homemade track (which is not hard to make)
as I understand the 5146 uses brown and the yellow wire of the equipment to be switched as opposed to the homemade which uses the red wire (center track contact)?
how do you use the homemade track then to switch equipment?
thank you all foe time and effort
best regards
Xavier
ps.gone working for a couple of days
Offline Lars Westerlind
#2 Posted : 17 October 2004 21:54:03(UTC)
Lars Westerlind
Some misunderstanding, either from me or from you it seems.
Normal different kind of contact tracks follow the same principle: when the train passes, a contact is closed to ground (brown). 5146 and the like do it by the slider pushing a lever, which makes it direction dependendant (different contact are closed in differenct directions. Home made tracks (which NOT are easy to make with M-track) close this circuit by the axles, meaning that there is no detection of the trains diretion of travel.
Contact C track (with lever) are normally connected to ground in the same way, however, this may easily be changed to close any circuit, direction dependence. Reed contacts may also be use diretion dependent (if placed assymetrically), and close any circuit.
/Lars
Question about contact tracks (General MRR)
by Chris6382chris 09/09/2023 00:04:09(UTC)
Marklin Circuit and contact tracks (Digital)
by Luna 25/07/2023 05:37:21(UTC)
contact tracks in hidden yards (Digital)
by Don Morris 24/03/2023 01:56:40(UTC)
by Thewolf 12/12/2022 02:50:23(UTC)
Pre connecting contact tracks on MS2 before changing to CS3 (Model railroad wiring)
by einotuominen 19/09/2022 06:14:46(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
M contact tracks (H0-scale)
by BenP 27/04/2022 15:47:03(UTC)
Contact Tracks for K track (H0-scale)
by Harvey 14/03/2021 01:34:22(UTC)
16 Contact tracks and I don't know what to do with them (Digital)
by oranda 18/08/2020 15:08:55(UTC)
Dead spots on C contact tracks (General MRR)
by obb_taurus 12/01/2020 19:41:32(UTC)
Placement of contact tracks with windigipet software (Model railroad software)
by marklin61 30/01/2016 23:28:11(UTC)
Circuit and contact tracks C purposes? (Digital)
by federicofreundt 17/10/2015 02:10:25(UTC)
Modules for K track contact tracks (Digital)
by PeFu 03/04/2015 20:52:06(UTC)
Contact Tracks - Question (H0-scale)
by SteamNut 16/12/2014 17:26:46(UTC)
how to use track blocks and contact tracks (Digital)
by Laxman 20/02/2014 07:22:59(UTC)
Automatic Station with Contact Tracks (Track plans)
by Laxman 11/02/2014 01:03:02(UTC)
C-Track "blocks" / contact tracks (Digital)
by pmgsr 13/02/2013 23:46:12(UTC)
Contact tracks, S88, Memory on CS2 (Digital)
by fhp2 29/02/2012 22:11:33(UTC)
Nielsenr - Contact tracks in Braking Area (Digital)
by Nielsenr 30/08/2011 05:37:02(UTC)
Contact tracks problem/questions (Digital)
by WelshMatt 29/01/2009 12:48:53(UTC)
Homemade contact tracks: M and C? (H0-scale)
by mascagni 15/10/2007 16:27:19(UTC)
DIY Contact Tracks (General MRR)
by Dick 29/02/2004 21:36:00(UTC)
M Track Contact Tracks (Digital)
by xxup 29/01/2004 23:45:33(UTC)
Old contact tracks (H0-scale)
by coloradopatton 14/03/2003 00:33:41(UTC)
This page was generated in 0.371 seconds.
