Offline tnx jake
#1 Posted : 07 October 2003 18:02:19(UTC)
tnx jake
I'm seeking advice on the digital Marklin Turntable. I have received advice from friends that tell me that they have had trouble with the digital memory on the turntable. Their advice is to use it without digital and that it is just as easy to operate and less frustrating.
I would appreciate hearing from anyone who has had experience both digital and non-digital with this item.
Jack
Offline psolero
#2 Posted : 08 October 2003 00:59:41(UTC)
psolero
I'm using the turntable in non digital mode, my layout is digital, however, and it works very well.
I found that the command consolle is too much "toy shaped" and you must very careful in using slide and knob.Smile
Paolo Solero
#3 Posted : 08 October 2003 01:32:52(UTC)
Jack, Kevin (KLB) has extensive experience if controlling this with the special digital decoder for it... And I think he agrees with what you have heard, but let's hear what Kevin has to say on the matter before making any final decision... Smile
I myself prefer to play with it manually (non-digital mode) but the manual control box is not a marvel of longterm reliability either...[:0]
Offline tnx jake
#4 Posted : 08 October 2003 06:07:02(UTC)
tnx jake
Thanks Paolo and Juhan,
You have both confirmed another thing I have heard. I'll wait for Kevin and any others with first hand experience before making a decision.
Jack
Offline KLB
#5 Posted : 09 October 2003 16:12:06(UTC)
KLB
Hi Jack,all,
I have gone thru two of these things(!) and I'm highly disappointed in their 'performance. For the first few days,they worked as advertised,easy to program.Then one day it refused to to work altogether.At first I thought it was the TT itself,but after I hooked up the conventional controller,I realized it was the decoder.I sent it back for replacement,installed the new one and the same thing happened,Grrr,....[:(!]
So I do not recommend it,...at ALL! Use the conventional controller and have fun playing in your Bw!biggrin
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline tnx jake
#6 Posted : 09 October 2003 17:05:47(UTC)
tnx jake
Hi Kevin,
Thank you for the advice. You have confirmed what many people have hinted at over the years. I will heed your advice.
Jack
Offline cos_man
#7 Posted : 09 October 2003 17:18:15(UTC)
cos_man
Hello Kevin, All
I read your reply and I would like to know how I can control the turntable by a PC, through IB and using Railroad&Co. Is this possible without using the specific digital decoder ?
Best Regards
Costas
Offline KLB
#8 Posted : 10 October 2003 16:38:35(UTC)
KLB
Hi Costas,all,
I read on the Railroad&Co. mailing list that some one is making a decoder for turntables and since you can run the IB in 'mixed' mode (MM/DCC) this just might be a solution.
http://groups.yahoo.com/group/railroadandco/
Kevin!
Offline Nuno
#9 Posted : 18 November 2003 21:00:06(UTC)
Nuno
I have installed my turntable, but I find that its motor seems not to have enough power, as it easily stops when it finds some resistance due to some of the tracks beeing slightly closer to the moving track than others [:(]. I realised that most of the problem was that the C-track has to be slightly inclined down to approach the turntable and that makes the track closer to the moving track. So I lifted up a bit the turntable, so that is more or less horizontal. But some times, the turntable still stops, or at least it slows down very much [:(!].
Any advices? Should I take it to my dealer?
Nuno Smile
Marklin Turntable 89983 (Small scale)
by jacklr1 06/11/2025 01:09:48(UTC)
Marklin turntable 74861 (Model railroad software)
by sanjiv 11/04/2025 09:49:35(UTC)
Marklin Turntable, DSD2010 & TC (Digital)
by Kiko 21/11/2024 17:06:30(UTC)
Marklin Turntable 74862 (Digital)
by Carlos 11/05/2023 23:48:18(UTC)
new Marklin turntable 74862 (H0-scale)
by Normmeister 14/04/2023 07:20:25(UTC)
Decoder for Marklin Turntable 7186 (H0-scale)
by ChrisBu 07/04/2023 17:19:25(UTC)
marklin turntable 74861 (Digital)
by greatrocks 28/11/2022 02:35:09(UTC)
Faller 120281 engine shed for new Marklin turntable (H0-scale)
by Normmeister 29/04/2022 09:42:44(UTC)
Marklin turntable 6651C internal wiring (H0-scale)
by mnusair 21/07/2020 00:23:55(UTC)
Marklin Turntable 7186 (Track plans)
by Philip McCracken 09/04/2020 14:55:58(UTC)
Marklin turntable running characteristics (H0-scale)
by obb_taurus 21/03/2020 20:03:27(UTC)
Marklin turntable doesn't seem to have enough power (H0-scale)
by obb_taurus 15/03/2020 18:55:43(UTC)
Wiring for Marklin Turntable (Digital)
by Drongo 07/02/2020 05:13:32(UTC)
Marklin Turntable (H0-scale)
by garben 29/01/2019 18:12:40(UTC)
Marklin Turntable & 60175 Booster (Digital)
by chrisisrang 05/04/2018 10:33:05(UTC)
Marklin Turntable project (H0-scale)
by Timnomads 30/05/2017 12:45:57(UTC)
Marklin Turntable (Digital components and Software reviews)
by Mike M 13/07/2016 05:50:42(UTC)
7168 marklin turntable help (H0-scale)
by thomas buckley 07/04/2016 17:40:01(UTC)
Marklin turntable project (H0-scale)
by ixldoc 19/02/2016 01:34:39(UTC)
Signals on Marklin Turntables (Digital)
by Oscar0645 21/08/2012 23:58:21(UTC)
Marklin turntable - unable to enter programming mode from Ecos (Digital)
by obb_taurus 04/03/2012 19:18:59(UTC)
Part numbers for Marklin turntable 7286 (H0-scale)
by Bryan 26/03/2011 05:24:45(UTC)
I have got the Marklin turntable 7286 (H0-scale)
by sebastian 23/10/2007 04:22:26(UTC)
Marklin Turntable Noise (H0-scale)
by Dick 01/05/2007 03:02:32(UTC)
This page was generated in 0.304 seconds.
