Offline Giovanni Carboni
#1 Posted : 16 November 2023 15:55:51(UTC)
Giovanni Carboni
Hello everybody.
It is now several years that I joined this forum but this is my second post!
My request is pretty peculiar!
In 2015 I converted an old Marklin DM800 to a 5-pole DC motor using Marklin kit 60943.
I also added an electronic reverser (see below). All went OK. However I never tried it in digital mode.
Then I stored away the locomotive until yesterday, when I powered it again.
The problem is that I don't remember anymore what reverser/decoder model I used. I don't even know if
it is simply a reverser or if it also a digital decoder. I believe it's Uhlenbrock.
I would like to remember the type so I could get another one to convert a second loco.
The circuit board has 7 wires, with the gray and orange going to the motor brushes.
I went through the old Uhlenbrock manuals but I couldn't figure out what type it is.
Maybe some expert could suggest what type could be. It shoud have been a popular type in 2015.
The only way I have to test it for digital operation is a Delta control 6604, but it does not respond in
any position.
Thanks in advance
Giovanni
thanks 1 user liked this useful post by Giovanni Carboni
#2 Posted : 17 November 2023 11:34:56(UTC)
Can you post a photo of the reverse unit?
#3 Posted : 17 November 2023 19:04:58(UTC)
Originally Posted by: Giovanni Carboni Go to Quoted Post
Hello everybody.
any position.
Thanks in advance
Giovanni
I have never ever used Delta control 6604 but if i think right this works only with ac power?
I don´t think Uhlenbrock does works with the Delta control either too because you must use Märklins delta decoder?
#4 Posted : 18 November 2023 10:49:47(UTC)
Giovanni Carboni
Thanks for your reply. Here is the picture
After a lot of Googlin' I think that my decoder corresponds to Uhlenbrock 74120 (same board layout, same tiny connector, same color coding of wires).
I could find only a copy of the 74120 manual in German, and it seems that the decoder has a lot of functions. But I can't understand if it can be used simply as a reverser with standard AC power, as mine does.
#5 Posted : 18 November 2023 11:13:02(UTC)
If this is 74120 you have multiprotocol decoder.
It works with analog too but not with the Delta control.
If i think right Delta control 6604 you must coding decoder adress in the multiprotocol decoder.
Then in case you must use digital system because Uhlenbrock does not have coding switches.
Offline bph
#6 Posted : 18 November 2023 13:35:40(UTC)
If it is a 74120, it should work with your 6604, if you change the Motorola address to one of the four addresses that the 6604 supports. However, note the 6604 is quite old so nothing is guaranteed. But it's worth a try, If you know someone nearby with a more advanced controller, that can program the decoder.
#7 Posted : 18 November 2023 15:14:15(UTC)
Yet more disinformation from Goofy. If set up at one of the four Marklin addresses that the Delta decoder will control there is no reason for it to not work.
It could be a DCC only controller, although Goofy has reason to think it is a multiprotocol one, so it should be settable to Marklin Motorola. The biggest problem will be that a 6604 will not be able to change the address or any other features of the decoder.
Secondly as this decoder is 15 years old you are unlikely to find a new one anywhere (although you may get lucky and fine some very old unsold stock somewhere). You might find an old one on eBay or similar site. Decoder technology has moved on considerably in the last 15 years.
#8 Posted : 18 November 2023 19:53:01(UTC)
In fact no!
Delta control works only with ac trafo and there is limited function.
You can only set 4 different adress via coding switches.
If you have electronic decoder you must use digital system by program adress on the programming track.
Offline bph
#9 Posted : 18 November 2023 22:50:54(UTC)
In fact no!
Any digital decoder that supports the MM (Marklin Motorola) format should work with the 6604, as long as you set the MM address to 78,72,60 or 24. (or 80 if you use the Delta pilot).
According to uhlenbrock, the 74120 suport Mortorola. So if the decoder is correctly programmed to one of the 4 "Delta" addresses, it should work on the 6604.
the address change can not be done with the 6604, but needs to be done on a more advanced controller.
#10 Posted : 19 November 2023 07:36:29(UTC)
As i did wrote TS need digital system to program correct adress because Uhlenbrock decoder does not have coding switches.
Delta control 6604 support only four fixed adress.
And you must set MM protocol.
#11 Posted : 19 November 2023 10:50:55(UTC)
It can, if it is a 74120; but it has to be configured correctly, CV29 must be set to 4 to automatically understand analog.
Tip: When looking at the PDF manual, press "Ctrl + F" on your PC, and then type in "Analog", then you find all the 22 entries in the PDF
that describes how to use and configure the decoder in analog mode BigGrin
https://www.uhlenbrock.d...ndbook/de/Bes74120_3.pdf
Of course, if you only have a 6604 and a trafo, you need someone to help you configure the decoder.
#12 Posted : 19 November 2023 20:02:31(UTC)
Giovanni Carboni
Many thanks to all of you for the very complete answers. I find the group very informative and useful.
To summarize:
I understand that the 74120 was an overkill for me, since at the time I purchased it (2015) I only wanted a reversing module. But
if I plan to go to digital it's a good decoder, albeit a bit old. So I can keep it.
I also understand from your replies that the 6604 is not working because the 74120 has by default the loco address 3, but perhaps it won't work in any case even with a Delta-compatible address. I think a dealer nearby could re-program the address, just to try.
However I was just curious about trying the 6604: if I will really go digital I thought getting a Roco Multi Maus controller, since I understand that
the 74120 could work with that. Is it a valid choice?
For the other loco I plan to digitize (a vintage CE800) I ordered a Uhlenbrock 76200 so I don't need to modify the motor.
Hope it is a good choice.
BigGrin
Point motor wiring help needed (General MRR)
by Model Railway shed D 07/11/2023 15:39:34(UTC)
HELP needed - MS2 reset (UK) (Digital)
by rugauger 29/01/2023 16:42:57(UTC)
Help needed on motor replacement selection (Digital)
by einotuominen 29/09/2022 18:47:42(UTC)
Help needed on Marklin 34551 decoder (H0-scale)
by sikardon 29/01/2022 02:56:53(UTC)
Marklin Br81 stuck ....help needed (H0-scale)
by fossie 02/10/2021 19:30:46(UTC)
Help needed 60215 and mfx problem (Big scale)
by WHB 22/07/2021 18:06:35(UTC)
Help needed with slider removal on a 4103 baggage car. (General MRR)
by analogmike 30/06/2021 02:48:10(UTC)
Decoder Modification - Translation Help Needed (Digital)
by DTaylor91 01/05/2021 02:43:15(UTC)
BRAWA Trolleybus help needed (Collector's Corner general)
by Rocca 14/06/2020 11:32:05(UTC)
3015 Identification Help Needed (General MRR)
by jeffd 16/04/2020 18:46:10(UTC)
Help needed with station announcement (Digital)
by kkumar29 12/04/2020 16:07:15(UTC)
help needed with installation of signals on analogue layout with signals on either side of the track (H0-scale)
by Primo -23K 14/03/2020 08:28:34(UTC)
Help needed with HAG 157 (Re4/4 Südostbahn) (General MRR)
by thing fish 03/02/2020 20:31:18(UTC)
Help Needed to locate or Id a model train manufacturer and a train (H0-scale)
by ShannonN 18/01/2020 08:42:13(UTC)
Marlin 3147 Loco help needed (Digital)
by BombasPC 23/12/2019 19:43:51(UTC)
help needed to classify this carriage (H0-scale)
by ShannonN 05/12/2019 14:27:23(UTC)
Help Needed for battery powered train set 29210 (H0-scale)
by ShannonN 18/10/2019 11:28:33(UTC)
Trix Crocodile help needed (H0-scale)
by maico 11/09/2019 15:35:39(UTC)
Help Needed: Identify model of Passenger train by name (H0-scale)
by ShannonN 18/08/2019 17:02:00(UTC)
Help needed to rejuvenate Marklin delta 2960 damplok (H0-scale)
by DrYogi 16/02/2019 06:36:29(UTC)
Help needed in identifying a blue TEN passenger wagon model number. (General MRR)
by GaryTrooper 06/10/2018 19:45:26(UTC)
[answered][Urgent]: Help needed on 3301's (Delta) compatibility with Marklin Digital (H0-scale)
by madhu.gn.71 02/09/2018 08:11:33(UTC)
Solved ! Help needed on Black MS2 - Free Loco - Remove Loco ??? (Digital)
by TrainIride 13/04/2018 13:54:12(UTC)
Help Needed -Want to run 2 MFX locos from 1 MS2 controller (Digital)
by ShannonN 10/01/2018 07:44:58(UTC)
by alan 12/12/2017 13:56:43(UTC)
Help needed - Märklin 55900 (Big scale)
by johnmarklin 28/10/2017 19:12:57(UTC)
TEE 3071 - Help needed (H0-scale)
by hvc 30/09/2017 16:26:42(UTC)
Z Scale Layout Help Needed Suggestions (Small scale)
by darticus 11/08/2017 22:08:53(UTC)
Help needed findng correct digital address for henschel diesel (Digital)
by ShannonN 27/04/2017 05:05:36(UTC)
Help needed for a funny track plan (Track plans)
by Mattawa 20/03/2017 12:34:24(UTC)
Help needed with SBB (Prototype)
by alistairiancampbell 06/12/2016 04:25:23(UTC)
Bay Area Help Needed for Loco Address (Digital)
by Paul24 30/10/2016 21:44:46(UTC)
help needed with Marklin parts (Small scale)
by pctrainman1 12/10/2016 11:20:52(UTC)
Help needed from electronics wis kid re Fitting LED's to analogue Locos.e (H0-scale)
by dominator 25/09/2016 10:39:17(UTC)
Help needed 76491 and 76493 (Digital)
by Harvey 28/06/2016 03:37:38(UTC)
Marklin part number help needed (H0-scale)
by skeeterbuck 29/12/2015 00:28:25(UTC)
Newbie here, Help needed! (Small scale)
by GiannisK 23/10/2015 00:11:51(UTC)
New signals (764xx) and operational help needed (Model railroad wiring)
by jblackwell 12/08/2015 16:00:58(UTC)
help needed to find a video (General MRR)
by analogmike 30/07/2015 16:15:58(UTC)
by johnmarklin 10/03/2015 19:55:24(UTC)
Avanti Marklinisti help needed (H0-scale)
by danmarklinman 16/06/2014 21:42:11(UTC)
Märklin 6080 old "mouse piano" decoder wiring help needed (Digital)
by Janne75 14/06/2014 18:22:34(UTC)
Croc help needed - set 26730 (H0-scale)
by hvc 27/05/2014 13:41:43(UTC)
Motor CV probz loco 36242. HELP needed! (Digital)
by Martin T 06/01/2014 20:26:25(UTC)
Trix "Mobiloel" DB Tanker Car - Identification help needed (Collector's Corner general)
by BrandonVA 09/10/2013 16:43:52(UTC)
3084 help needed. (H0-scale)
by Iamnotthecrazyone 22/07/2013 08:59:21(UTC)
Linguistics help needed (H0-scale)
by mike c 17/06/2013 21:25:07(UTC)
Applying Stripes. Help Needed. (Painting & Weathering)
by Roman 29/04/2013 06:09:17(UTC)
Help needed with a first project (Digital)
by Mattonides 21/11/2012 09:02:10(UTC)
Help needed in how to program an address for Marklin 37535 (Digital)
by michelvr 08/07/2012 20:25:54(UTC)
This page was generated in 0.714 seconds.
