CS2
Offline Don Morris
#1 Posted : 14 June 2016 07:16:04(UTC)
Don Morris
My cs2 informs me that the software version is 3.8.1.(11). Can any tell me if that is the latest?
The most recent version I can find is 3.6.2
Don
#2 Posted : 14 June 2016 07:58:40(UTC)
The latest is 4.1.2(3) or something like that.
See also:
https://www.marklin-user...elewelt-4-1-1#post518710
CS2 and catenary analogue (General MRR)
by Bryan 12/04/2024 23:50:12(UTC)
CS2 60215 with 6021 slave (Digital)
by Willr 09/03/2024 00:05:11(UTC)
CS2 upgrade to CS3 (Digital)
by rhfil 11/12/2023 00:39:07(UTC)
CS2/CS3 multiprotocol Wave form (Digital)
by peter_moulin 07/11/2023 12:43:12(UTC)
CS2 firmware update (Digital)
by gbel78 20/10/2023 17:45:06(UTC)
Central Station CS2 (General MRR)
by gbrendem 13/10/2023 19:52:37(UTC)
Marklin CS2 60213 (H0-scale)
by Kuhan 09/09/2023 14:41:33(UTC)
Setting up CS2 (General MRR)
by Drongo 25/08/2023 02:01:03(UTC)
CS3/CS2 - same loco different photos (Digital)
by twmarklinfan 26/07/2023 00:51:29(UTC)
CS2 and programmer programming decoder question (H0-scale)
by billyamy 18/07/2023 21:37:04(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Märklin MFX+ is not registering to CS2 after factory reset (Digital)
by applor 11/06/2023 23:12:15(UTC)
Mapping and adjusting functions on the Giruno using CS2 (Digital)
by PeFu 29/05/2023 06:46:31(UTC)
CS2 failure to start (Digital)
by gamolina 23/05/2023 01:08:52(UTC)
Does the CS2 have "events" like the CS3 (General MRR)
by Drongo 31/03/2023 08:40:57(UTC)
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
Which is latest software version for CS2 60213 ? (Digital)
by Johnvr 13/02/2023 19:58:43(UTC)
Voltage input for CS2 (Digital)
by Juan Carlos Carbonel 05/02/2023 04:28:02(UTC)
Märklin CS2.exe (Model railroad software)
by w4sepp 09/11/2022 10:44:12(UTC)
Little problem with my CS2 (Digital)
by Thewolf 07/11/2022 23:52:12(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
Lenz LS150 address change not responding - CS2 vs lokprogrammer (Digital)
by applor 26/10/2022 01:12:52(UTC)
CS2 compared to CS3 (Digital)
by mrunix 30/09/2022 23:44:03(UTC)
Märklin CS2 (Digital)
by Rolando 07/09/2022 13:08:56(UTC)
Central Station CS2 (Digital)
by Rolando 31/08/2022 13:19:36(UTC)
by Rolando 24/08/2022 10:11:46(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
Need help upgrading CS2 (Digital)
by nelson77 17/06/2022 18:06:58(UTC)
Computer software with Marklin CS2 (General MRR)
by Christo Swanepoel 25/04/2022 19:16:22(UTC)
New Updates for CS2 ( Software 4.3.0 ) and MS2 ( Software 3.148 ) (Digital)
by FrankF 23/03/2022 14:49:22(UTC)
cs2 back (Digital)
by Thewolf 11/12/2021 18:32:28(UTC)
Cable extension from S88Link (60883) to cs2 (60215) (Digital)
by Thewolf 06/12/2021 23:19:19(UTC)
Accessories/Cables for CS2? (Digital)
by Shay 16/09/2021 17:32:30(UTC)
CS2 update and Digital Switch recognition and action (Big scale)
by Inspectorate56 19/08/2021 15:55:07(UTC)
CS2 software upgrade. (Digital)
by Barby & Stan 16/08/2021 22:37:28(UTC)
Adding sounds to a Shuttle route using a CS2 (Digital)
by Elsleuth1 29/06/2021 21:56:13(UTC)
Loco Icons & CS2 (Digital)
by Timnomads 21/06/2021 08:37:42(UTC)
MUs in CS2 and CS3 (H0-scale)
by Timnomads 10/05/2021 10:07:53(UTC)
CS2 issues (H0-scale)
by Airfix05 20/04/2021 17:03:56(UTC)
CS2 60215 English manual (Digital)
by Donb 16/04/2021 17:36:40(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
New Software-Update for CS2 (60215/60214/60213) and MS2 (60653/60657) (Digital)
by FrankF 26/02/2021 22:23:59(UTC)
Copy data from CS2 to CS3 plus (Digital)
by gachar001 24/02/2021 07:15:23(UTC)
Märklin CS2 is loading, loading, loading but not starting? (Digital)
by jaakkomu 11/02/2021 19:27:06(UTC)
How to setup the turnout indication in Marklin CS2 (Digital)
by arniland 23/01/2021 17:20:23(UTC)
Mfx locomotives not found by CS2 - Solutions? (Digital)
by Martin T 21/01/2021 20:22:52(UTC)
bizarre problem CS2 / iPhone mobile station with turnout control (Digital)
by applor 03/01/2021 01:23:21(UTC)
7286 turntable with LDT TT-DEC - CS2 step turn doesn't work properly (Digital)
by applor 29/12/2020 22:56:15(UTC)
LokPilot 4 decoder OK in LokProgrammer but not with CS2 (Digital)
by PeFu 28/12/2020 17:46:56(UTC)
CS2 or PSU issue? (Digital)
by Borsig-Werke 08/12/2020 17:38:36(UTC)
This page was generated in 0.469 seconds.
