Offline Rwill
#1 Posted : 02 February 2019 19:00:02(UTC)
Rwill
One of my early purchases of Marklin was 3618 and the classic Rheingold 4228. Now thirty years on the 4228 is reserved for high days and holidays - the agony of getting it out of the box and the flickering lights & etc are well documented and its general fragility in my fudgy fingers. But the 3618 goes on and on built like a brick poop house making that familiar coffee grinding noise. I often simply run it solo but could you suggest what would be appropriate to run behind it. I am not strictly strict about authenticity. I guess it would sacrilege to suggest a rake of brown freight wagons wouldn't it !
#2 Posted : 02 February 2019 20:40:33(UTC)
One of my early purchases of Marklin was 3618 ... I guess it would sacrilege to suggest a rake of brown freight wagons wouldn't it !
Oh I don't know .....
Due to availability issues, engines like that were often used on lesser duties when the usual motive power might be a BR 55 or a BR 50.
We have all seen pictures of the LNER streamlined A4s hauling freight trains at one time or another.
Offline bph
#3 Posted : 03 February 2019 17:50:31(UTC)
Yes the 4228 is indeed a very nice train set. Have one myself, and have recently fitted Märklin current conducting short coupling, it makes handling a bit easier.
Regarding your 3618, you should run it what’s pleases you. A suggestion might be some 46802/3 ore some 46280/1/2/3 ore the set 46091
Offline rrf
#4 Posted : 03 February 2019 20:03:39(UTC)
rrf
I run my 3093 BR18-4 with a set of five tin plate D-Zug cars (4051 blue 1st class, 2 x 4052 green 2nd class, 4078 blue / dark red combined 1st class + dinning & 4026 green baggage). While not as visually striking as my 3318 and 4228 Rhiengold (BTW also a Christmas layout standard), my BR18 678 D-Zug is after 40 years still one of my favorite trains to run. So I think your lok will look just fine with some Era III DB passenger cars.
Rob
Mackenrode Wende Bahn
thanks 2 users liked this useful post by rrf
#5 Posted : 03 February 2019 20:27:26(UTC)
I use mine with Era III express coaches:
But I also sometimes run it with older Era II compartment coaches:
#6 Posted : 03 February 2019 21:53:04(UTC)
AFAIK the prototype of Märklin's BR 18.4, the one with the small wheels, was never used for the Rheingold in real life. So anybody running that combination is not strict about authenticity.
Other era II express train coaches will likely make a realistic train for the 3618.
S 3/6 BR 18.4 Locomotive Wont Run SOLVED! (H0-scale)
by HerrHeftig 28/06/2020 00:58:18(UTC)
BR 18.4, 33182, which coaches ? (H0-scale)
by ocram63_uk 07/07/2019 00:21:23(UTC)
BR 18.4 and BR 18.5 (Prototype)
by rrf 15/01/2015 20:47:58(UTC)
Br 18.4 (M3618) not running correctly (Digital)
by mancsaint 27/02/2013 13:15:09(UTC)
Where is TRIX 22041 S 3/6 (22039 BR 18.4) ? (General MRR)
by shannon 17/01/2013 16:34:49(UTC)
My BR 18.4 Loco hangs after few minutes operation (Digital)
by berdos 08/05/2011 17:32:17(UTC)
Converting BR 18.4 (3093) to Digital (Digital)
by Kepler 14/11/2010 19:17:49(UTC)
BR 18.4 Livesteam Loco 55005 (Big scale)
by wallew02 27/12/2007 02:34:05(UTC)
Livesteam BR 18.4 (55003) (Big scale)
by Sander van Wijk 19/07/2005 22:52:34(UTC)
Problem with new BR 18.4 (H0-scale)
by oz_train 18/05/2004 03:55:35(UTC)
BR 18.4 Remove body (Digital)
Belarus alpardo 20/03/2004 23:46:29(UTC)
This page was generated in 0.369 seconds.
