Offline monster134
#1 Posted : 17 June 2009 22:44:54(UTC)
monster134
So,where i want to shove a "locked" Marklin decoder is of little relevance here hehehehe,but i have a Lokprogrammer from ESU here for a trial and i like it.
I have altered sounds and perfected driving charasteristics and so forth.I have 4 ESU decoders now.That 18 201 i bought from Roco lets me in and let me play,but it wont read any Marklin decoder.It recognizes the MFX stuff,but doesnt want me to alter stuff.
So the question is......who has cracked the Marklin decoder?Surely some wizzkid somewhere has done it.
You can tell me,i wont tell anyonebiggrin
Offline Caplin
#2 Posted : 17 June 2009 22:55:25(UTC)
Caplin
You can also tell me, my lips will be sealed.biggrin
Benny - Outsider and MFDWPL
Offline cgarlati
#3 Posted : 17 June 2009 22:55:43(UTC)
cgarlati
Here is how I managed to use the Lokprogrammer with the new Marklin BR 64 (39640) to read, change, and write any CVs - sound cannot be changed.
1) open the loco and extract the ESU loksound decoder - note the 21
pole connector - the built-in electronics is to control the brush less
motor.
2) connect pin 21 and 22 of the decoder to the programming track -
the polarity does not matter
3) connect a 1K resistor between pin 18 and 19 to simulate the
presence of the motor.
4) read the full CV set with the Lokprogrammer software on your PC
5) put back the decoder into the loco.
6) change and write any CVs as you like
Note: step 1 to 5 are required only the first time. As long as you
save any changes to a file on your pc you do not need to repeat these
steps ever.
It worked great for me. Among others, I changed the intensity of the
the lights, activated the smoke mode for AUX1, reduced the intensity
of the smoke unit, reassigned various functions and adjusted various
sound parameters here and there.
Have fun
Cesare
Offline monster134
#4 Posted : 17 June 2009 23:33:27(UTC)
monster134
But if the Lokprogrammer reads the decoder....what stops one from loading a completely new sound project?
#5 Posted : 18 June 2009 00:28:46(UTC)
Monster, Marklin mfx decoders are locked from the user being able to change any sounds.
See http://www.esu.eu/en/support/faq/lokprogrammer/
"I can not overwrite the sound files of my Märklin mfx-Sounddecoder?
This was done for a reason. All Märklin mfx sound decoders are protected against any changes, deletion or overwriting of the original sound files.
All the parameters of the CV's like maximum speed, acceleration and deceleration can be changed at any time."
However, as you suggest, I'm sure someone with the right skills could 'crack' the restrictions. The trick is to find that someone.
#6 Posted : 18 June 2009 00:54:31(UTC)
WANTED - ONE BORED HACKER.
Tried of breaking into military installations and banks? Are you bored by the tediousness of cracking serial numbers on software and mobile phones? Do you want a great challenge? Then look no further than the unhackable sound code of the Marklin mFx chip. Crack the code for the elite group of enthusiasts and get absolutely nothing for your efforts but the smug satisfaction that you are the first to achieve something that no one else cared about!
To apply, post your application here - along with the procedure for updating sounds on the mFx chips for which we paid good money...biggrinbiggrinbiggrin
#7 Posted : 18 June 2009 01:00:58(UTC)
#8 Posted : 18 June 2009 01:21:46(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by cgarlati
<br />Here is how I managed to use the Lokprogrammer with the new Marklin BR 64 (39640) to read, change, and write any CVs - sound cannot be changed.
Another way: pull the decoder out of the CCS/SDS loco and plug it into any "normal" loco (with five-pole motor). Lokprogrammer should be able to read it there.
Offline pa-pauls
#9 Posted : 18 June 2009 02:04:29(UTC)
pa-pauls
[size=1" face="Verdana" id="quote]quote:Originally posted by H0
Indeed Smile Or use the ESU test stand 51900 wink
Pål Paulsen
Offline frankie
#10 Posted : 18 June 2009 14:02:17(UTC)
frankie
<br />WANTED - ONE BORED HACKER.
May I add CS1 root password?wink
Alessandro
I have a CS1 Reloaded!
Offline Caplin
#11 Posted : 18 June 2009 14:07:00(UTC)
Caplin
Probably you may suffer from plenty of appreciation from members here. [:p]biggrinbiggrin
Lenz LS150 address change not responding - CS2 vs lokprogrammer (Digital)
by applor 26/10/2022 01:12:52(UTC)
LokProgrammer on Ubuntu with Wine software (Digital)
by ocram63_uk 17/02/2022 10:32:40(UTC)
by Ausipeet 20/08/2021 05:40:25(UTC)
LokPilot 4 decoder OK in LokProgrammer but not with CS2 (Digital)
by PeFu 28/12/2020 17:46:56(UTC)
CS2 and ESU LokProgrammer on one programming track (Digital)
by PeFu 14/05/2019 00:05:05(UTC)
lokprogrammer 60971 (Digital)
by 3gleise 02/04/2018 19:37:28(UTC)
Handy instruction list for ESU Lokprogrammer (Digital)
by river6109 05/03/2018 01:42:46(UTC)
New from ESU: version 4.1.0 for ECoS/CS1R, version 4.4.20 for LokProgrammer (News from Märklin and others)
by H0 30/09/2015 19:48:59(UTC)
Various questions on DCC with ECOS 2/Lokprogrammer... (Digital)
by Cargodog 03/07/2015 12:29:41(UTC)
LokProgrammer software (Model railroad software)
by biedmatt 28/02/2015 16:28:54(UTC)
ESU Lokprogrammer upate-now Ver 4.4.4 (Digital)
by Lollo 25/06/2013 22:08:36(UTC)
Share Lokprogrammer files? (Digital)
by biedmatt 27/05/2013 06:21:41(UTC)
LokProgrammer V4.4.2 bugs? (Digital)
by biedmatt 06/04/2013 15:44:44(UTC)
Fail to connect lokprogrammer (Digital)
by akv2002 22/01/2013 05:41:12(UTC)
Lokprogrammer Seuthe smoke settings (Digital)
by biedmatt 27/12/2012 22:31:04(UTC)
ESU Lokprogrammer new Prolific driver. (Digital)
by Lollo 23/07/2012 13:10:57(UTC)
ESU has released new update for ESU Lokprogrammer 4.3.3 (Digital)
by river6109 26/06/2012 15:02:28(UTC)
ESU Lokprogrammer (General MRR)
by river6109 15/09/2011 09:12:31(UTC)
Do not download ESU Lokprogrammer 4.2.2 (General MRR)
by river6109 14/09/2011 17:09:49(UTC)
Help with Lokprogrammer (Digital)
by Drongo 18/01/2011 12:02:00(UTC)
ESU LokProgrammer sw on a PC with Windows 7 Pro ? (Digital)
by pa-pauls 06/03/2010 22:50:59(UTC)
ESU Lokprogrammer - Sound Update Issue (Digital)
by chrisisrang 24/09/2009 13:58:00(UTC)
Can't read decoder in 39984 using LokProgrammer (Digital)
by Hobbit 17/09/2009 07:31:09(UTC)
Setting symbols using lokprogrammer (Digital)
by gachar001 27/06/2008 17:40:51(UTC)
Lokprogrammer and Windows Vista (Digital)
by gachar001 09/06/2008 23:35:32(UTC)
Lokprogrammer software 2.6.7 (Digital)
by mmervine 05/04/2008 22:33:32(UTC)
Lokprogrammer Problem (Digital)
by mike c 14/02/2008 23:02:05(UTC)
New Lokprogrammer User Help Needed (Digital)
by Frostie 04/02/2008 00:22:20(UTC)
LokProgrammer 2.6.6 (Digital)
by DamonKelly 03/02/2008 13:42:42(UTC)
MFX and ESU LokProgrammer Compatibility (Digital)
by Hobbit 04/12/2007 15:52:53(UTC)
Lokprogrammer Update V2.6.5 problem (Digital)
by Dave Banks 20/11/2007 07:48:39(UTC)
ESU Lokprogrammer problem with LS MFX and LP MFX (Digital)
Belarus Sander van Wijk 03/11/2007 23:11:11(UTC)
ESU LokProgrammer software in slow-motion. (Digital)
by Gert-Jan 05/03/2007 13:20:15(UTC)
ESU Lokprogrammer software with small error? (Digital)
by Gert-Jan 29/11/2005 21:54:57(UTC)
LokProgrammer version 2.5.1 (Digital)
by prc 21/04/2005 04:37:17(UTC)
This page was generated in 0.578 seconds.
