Offline Puttputtmaru
#1 Posted : 21 March 2021 14:57:45(UTC)
Puttputtmaru
I ordered a digital starter kit to get my feet wet with Rocrail. It comes with the No. 66955 command station which should work with Rockrail from what I can see on the site ( https://wiki.rocrail.net/doku.php?id=mbus:mbus-en )
My question now.
In the futur as I use Rocrail for my big layout is the CS3 needed or will the 66955 be enough as the interface between my computer and Rocrail to control everything?
Will I be missing out on some functions?
#2 Posted : 21 March 2021 16:08:14(UTC)
What start set did you get? I don't recognise that 66955 command station, and cannot see it on the page you linked.
Offline michelvr
#3 Posted : 21 March 2021 17:06:41(UTC)
michelvr
I just checked out the number and it’s the Trix mobile station.
The most important component is going to be a computer and the related equipment needed to make it operate from the computer. Best is to plan what you want to achieve and then source out which manufacturer you want to use. If I was going to use Rocrail I would seriously consider;
Dijikeiks: Digicentral The first central with all imaginable connectors combined in one device. Clear LED displays and integrated USB, LAN and WIFI
https://www.digikeijs.co...c-multi-bus-central.html
I’ve been dabbling with DCC for a long time and for my money Dijikeiks seem to be doing it the right way, component by component. I don’t have any of their products but if I was starting that’s where my money would go.
#4 Posted : 21 March 2021 18:20:30(UTC)
Puttputtmaru
This is the set I got: Märklin 29000 (HO) Digital Starter Pack and Märklin 24902 (HO) C Track C2 Extension Set. May be I got the wrong number for the command station, I did not get it yet. The page I linked has a picture of it on the right hand side.
I am going to go the K-Track way, I have plenty of them but this will be my >experimental layout<
Offline Martti Mäntylä
#5 Posted : 21 March 2021 21:35:52(UTC)
Martti Mäntylä
In your situation, I chose to buy bits and pieces from CAN Digital Bahn, and I have been quite satisfied with the result. In this setup, the Märklin TrackBox 60116 or 60113 has the central role; a MS2 is strictly optional. I hardly ever touch the one I have.
I'm sure similar solutions from other manufacturers work as well. I preferred CAN Digital as their architecture uses the CAN bus for all messaging.
In any case, if one uses Rocrail to run trains, I personally find that a full-blown standalone command station is an overkill.
- Martti M.
Offline franciscohg
#6 Posted : 22 March 2021 04:43:53(UTC)
franciscohg
Chile
Absolutely agreed, if you are going for PC control you dont need a fully functional command station, just the interface. On the other hand i think thst the digikeijs system is still very far away from maturity, as for i was told by several people who bought the station. I bought myself some other components and sadly i must ssy that they are happily lying in their boxes now.
Offline PeFu
#7 Posted : 22 March 2021 07:10:36(UTC)
PeFu
I agree in general, however IMHO there could be at least two reasons:
(1) Access to Mfx protocol: Myself, I only run engines on DCC and MM protocols, so this feature is not a valid argument for me.
(2) Booster control: I have two 60175 boosters connected via a terminal to the CS2, and I’m impressed by the operational quality and overview this setup provides. No more ”sparks” when trains move between booster sections. I need to add, my only benchmark is the old 6021 booster management, I have no experience from other modern boosters.
Smile
#8 Posted : 22 March 2021 14:34:02(UTC)
Puttputtmaru
Smile
Your point ( 1) is also important to me. So am I to understand that if I don’t have a Marklin CS (CS2 or CS3) I will not have access to the mfx protocol.Crying
Sorry for the newbie questions guys but although I have plenty of k-tracks and very old Markilin locos all analog, I am for now starting from zero going all digital. And will only use the latest product that is available. I will retrofit if possible later.
#9 Posted : 22 March 2021 14:49:39(UTC)
Using the track box should give you access to the mfx protocol - but I don't know how much of the mfx processing is done in the track box and how much is in the ms2. I suspect the library of locos is maintained in the ms2, so if you don't have that connected then you will probably have problems.
Offline Kiko
#10 Posted : 22 March 2021 15:36:35(UTC)
Kiko
Just to clarify one point -- You are not forced to use the Marklin CS family of controllers. For example, the ESU ECoS does recognize multi-protocol decoders. I personally use the ECoS and run Marklin MM, mfx, mfx+, ESU Lokpilots and Loksound decoders. The ECoS can handle all of them at the same time. Some of my locos run under DCC, others under Marklin, some use 14 steps (the old 6090 digital decoders), some use 28 steps. As far as I know, the ECoS can't take advantage of the extra capabilities of the mfx+, i.e., the Word of Operations features. However, the mfx and mfx+ only differ in that respect. If World of Operations is an important play factor for you, then you will have no choice but to use a Marklin controller.
I hope this adds some value and does not muddy the waters even further.
Andry
Andry
thanks 1 user liked this useful post by Kiko
#11 Posted : 22 March 2021 17:24:18(UTC)
Very true, but does the mfx+ world of operation feature work with Ecos? You must also manually enter some locomotives, also true with Roco dcc decoder fitted models om the CS3.
The Zimo decoders are/were using Railcom II for sound. The CS3 does not support railcom.
I am also wondering if the Roco Z21 cab driver function can work on a CS3.
#12 Posted : 22 March 2021 17:29:54(UTC)
Martti Mäntylä
As kiwiAlan said, the track box handles the Mfx protocol matters. Rocrail can handle Mfx registration.
I use two Märklin 6604 Delta Controls with 6647 transformers as boosters, and I don't get sparks either. Of course, they are not visible to Rocrail's booster management functions. CAN Digital offers a more advanced booster unit, but I preferred the low-fi approach (I had one 6604 handy, and bought the second for a pittance).
So a command station is not absolutely necessary for these two points, although of course it can simplify the management of the setup.
- Martti M.
#13 Posted : 22 March 2021 17:31:59(UTC)
No, of course not.
The ECoS supports RailCom and RailCom+, so DCC locos can register automatically with all their icons. Not supported by CS 2 or CS 3.
The Z21 app only works with the Z21. But it works with any loco.
The CS3 cab drive also works with any loco and is no longer limited to mfx+.
If I needed a new controller these days, I probably would order an ECoS II. I don't give a damn about mfx+ or any cab control mode.
I always say get your hands on the controller before making a purchase decision. My fingers are way too thick for the touch screen of the CS3. How often did I move a windows when I tried to stop a train. Severe accidents can be the result.
I particularly like the Multi-Mode of the ECoS and the CS1R.
Offline Kiko
#14 Posted : 22 March 2021 17:37:01(UTC)
Kiko
As I stated previously, unfortunately, the Marklin proprietary WoO protocol can't be accessed by other controllers. However, all other mfx features are supported by ECoS. As far as I understand, the "+" only means that the protocol supports WoO -- all other features are exactly the same as in a regular mfx decoder. Hence, if WoO is important to you, then your only choice is to go with a Marklin controller.
Another note regarding Railcom -- the ECoS supports Railcom as well as Railcom Plus. This is basically a capability for locomotives running under DCC to "self-register" -- similar to mfx.
Andry
#15 Posted : 22 March 2021 19:04:40(UTC)
Not only that, but for WoO the controller HAS to be a cs2 or cs3. WoO is NOT a feature that works with ms2 and trackbox.
ESU Command Station vs Marklin CS 3. Early 60th B-day gift. (Digital)
by Hoover007 03/04/2024 06:58:00(UTC)
ECOS Command Station - is it running hot? (Digital)
by Chris6382chris 12/12/2021 03:30:05(UTC)
JMRI and the ESU COMMAND station (Digital)
by White Buffalo 21/08/2021 15:41:10(UTC)
ESU command Station software Upgrade (Digital)
by White Buffalo 21/08/2021 14:43:03(UTC)
Wi-Fi standalone command station (Digital)
by Yaasan 20/09/2018 23:32:19(UTC)
ESU digital Command Station (Digital)
by White Buffalo 09/03/2018 19:09:07(UTC)
CS 3 or ESU command station (Digital)
by Wasp 16/06/2017 17:40:24(UTC)
What digital command stations are available? (Digital)
by White Buffalo 27/05/2017 16:49:38(UTC)
Using L88(60883) with ECoS command station (Digital)
by drbob01 19/07/2016 20:17:30(UTC)
M Central Station or ESU 50200 ECos2 Command Station? (Digital)
by Joseph Meiring 27/03/2015 18:30:48(UTC)
Marklin CS2 Vs ESU ECos Command Station (Digital)
by chrisisrang 16/03/2015 07:32:54(UTC)
Marklin Decoders with ESU Command Station (Digital)
by drbob01 21/11/2013 16:24:18(UTC)
Electric Turnout 74491/Digital Decoder 74461/ECoS ESC Command Station (Digital)
by Richard_Pymble 14/07/2013 06:31:17(UTC)
An alternative command station: Railuino (Digital)
by Yaasan 01/06/2013 08:45:54(UTC)
ECoS Command Station 50200 (Digital components and Software reviews)
by river6109 21/01/2011 06:02:21(UTC)
ESU ECOS 50200 COMMAND STATION (Digital)
by lvfocus 07/03/2010 15:11:31(UTC)
Your opinion about esu command station 50200 (Digital)
by dodos 23/01/2010 00:58:19(UTC)
Ecos new Command station 50200 auto-repeat (M4 and (Digital)
by Goofy 07/09/2009 21:35:39(UTC)
Digital Command Stations Comparison Sheet (Digital)
by sjlauritsen 06/09/2009 21:28:49(UTC)
Different command stations (Digital)
by countrylink 09/09/2007 04:43:34(UTC)
This page was generated in 0.754 seconds.
