Offline Rohit279
#1 Posted : 13 September 2019 15:43:16(UTC)
Rohit279
Bahrain
Hello Friends,
Is it possible to use arc and truss bridges meant for M tracks to be used on a C track layout ? Confused
Marklin part # 7263 ( arc ) / 7268 ( truss ) & 7269 ( curve )
Rohit
Offline TEEWolf
#2 Posted : 13 September 2019 17:20:11(UTC)
Originally Posted by: Rohit279 Go to Quoted Post
Hello Friends,
Rohit
I do not have these bridges, but it looks like they are only for K and M tracks. For C tracks Märklin offers bridges under different article numbers.
https://static.maerklin....f12a9e29941551080009.pdf
M says these are for C-track. M published a technical tipp #412 for bridges. But as usual only in German. So you might take the hardship to translate parts of it.
https://www.maerklin.de/...fahrten_Br%C3%BCcken.pdf
https://www.deepl.com/translator
Offline aos
#3 Posted : 14 September 2019 12:39:13(UTC)
aos
Hi Rohit, I have the old bridges designed for M track. When I replaced my M track with new C track, I encountered the problem that the track would not sit correctly in the M track bridges. The base of the C track is just that wee bit too wide. I found a way around that. Place the C track horizontally in a cushioned vice so not too damage the track. Take a Surform (rasp file) and slowly shave off the sides of the C track. Do it slowly, checking after each rasp. Once you have removed what looks like a flat amount of about 1/10 inch on each side, you should find that the track fits in the bridge. It is not brilliant, but is effective enough. It is also a lot cheaper than new bridges. Alan
thanks 5 users liked this useful post by aos
Offline Rohit279
#4 Posted : 14 September 2019 18:23:51(UTC)
Rohit279
Bahrain
Hi AOS, Gr8 idea !!... Thanks !
Offline GaryTrooper
#5 Posted : 14 September 2019 21:41:54(UTC)
GaryTrooper
I agree.
AOS don't sell yourself short. Its brilliant. Isn't "trying to make it work" what model railroading is all about?
G - LGB
HO - Marklin
N - Mix of manufacturers mostly Kato
thanks 2 users liked this useful post by GaryTrooper
Offline Rohit279
#6 Posted : 25 September 2019 21:34:20(UTC)
Rohit279
Bahrain
Hi Friends,
At the outset I want to thank for everyone again for their suggestions and guidance. I just wanted to inform that I ended up buying a NOCH 21320 HO bridge. It is the same size as MARKLIN 74636 in length which is about 360mm. At 17 EUR It costs less than MARKLIN and is a perfect fit for MARKLIN 'C' track system.
Attaching a few photographs for reference.
Cheers !
thanks 4 users liked this useful post by Rohit279
M-Track bridges made into living room diorama (H0-scale)
by DaleSchultz 14/08/2025 04:05:07(UTC)
Curved bridges for R2-R5 (News from Märklin and others)
by PeFu 13/12/2024 08:27:19(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
Bridges (H0-scale)
by Mjn2ts 07/06/2022 12:55:49(UTC)
Alternatives to Marklin Piers for Old Metal Bridges - Ideas? (H0-scale)
by 5HorizonsRR 10/01/2021 19:04:38(UTC)
Electric current on a rail amputated from its bridges (General MRR)
by Thewolf 14/02/2018 23:56:09(UTC)
Pillars for Märklin metal-bridges (7161, 7162, 7163 and ramps) (H0-scale)
by Markus Schild 21/01/2018 23:00:13(UTC)
R3 bridges (H0-scale)
by Leitner 11/01/2018 08:19:08(UTC)
HO bridges (H0-scale)
Belarus Twisterdodger 11/05/2017 00:48:37(UTC)
Train travel through 100 years bridges of New Zealand. (Prototype)
by waorb 29/06/2015 20:48:52(UTC)
C-Track and Bridges (H0-scale)
by Hoffmann 03/10/2013 02:28:02(UTC)
Trestle Bridges (Big scale)
by Jeremy Palmer 06/09/2013 02:04:29(UTC)
Bridge Piers, Bridges, Approach Ramps (Collector's Corner general)
by kumarvartak 26/09/2012 09:09:16(UTC)
"half length" bridges?? (General MRR)
by Joseph Meiring 27/11/2011 22:05:10(UTC)
Hack Brucken - Metal Bridges for Marklin (News from Märklin and others)
by GlennM 04/10/2011 18:01:03(UTC)
Stone bridges to chose (Model kits & layout details, kitbashing and such)
by ac jacko 28/06/2010 15:07:24(UTC)
Correct height for bridges in HO layout (General MRR)
by gachar001 22/07/2008 19:59:19(UTC)
Stone arch bridges the lazy way (Model kits & layout details, kitbashing and such)
by perz 01/07/2007 01:12:30(UTC)
Stone arch bridges and walls (Model kits & layout details, kitbashing and such)
by hxmiesa 16/10/2006 02:41:00(UTC)
Faller Bridges (Model kits & layout details, kitbashing and such)
by mattillini 09/06/2006 22:09:17(UTC)
Weathering RR bridges (Painting & Weathering)
by jselter 09/12/2005 16:47:25(UTC)
Weathering steel bridges (Painting & Weathering)
by Lloyd 17/03/2003 21:48:04(UTC)
This page was generated in 0.633 seconds.
