Offline Bogenschütze
#1 Posted : 11 September 2019 11:08:40(UTC)
Bogenschütze
I'm a newbie and have been using a C-track digital starter set with two turnouts. Both are now digitally controlled with 74491 motors and 74461 decoders using my MS2 and work absolutely fine. I'm developing my track plan from the basic oval and am using the two turnouts as a double track crossover. My question is that instead of assigning each decoder a separate address and switching them independently, can I set the DIP switches to the same address and switch both turnouts simultaneously? I think it should be possible but am concerned that the extra current draw may damage the equipment or be insufficient to efficiently operate the motors. Does anyone have any experience of this? I would be pleased to learn if it's possible.
Marklin - "The train set I never had as a child."
Keith Bowman
Offline Danlake
#2 Posted : 11 September 2019 12:04:07(UTC)
Danlake
Hi there,
And welcome to the forumThumpUp
Yes you can have 2 turnouts with same address. Unless you are planning to switch a lot of turnouts at the exact same time I don’t think you need to worry about in rush current. It would be no different than e.g. a solenoid signal and turnout switching at the same time.
See also link here:
https://model-railroad-hobbyist.com/node/32845
Best Regards
Lasse
#3 Posted : 11 September 2019 12:25:50(UTC)
Bogenschütze
Hi there,
See also link here:
Best Regards
Lasse
Many thanks for your warm welcome and prompt answer with the link. I would only be switching turnouts individually or in pairs so your answer is very useful and reassuring. ThumpUp
Keith Bowman
Guest (4)
3 Rails DCC/Digital layout - AC/DC wheels (H0-scale)
by Rhode 18/12/2025 09:30:53(UTC)
important questions mfx delta digital analog (Digital)
by Adrian666 24/11/2025 10:43:47(UTC)
Digital verification of loco 3608 (Digital)
by DV 11/11/2025 07:28:21(UTC)
Silberlinge 4160 – Digital Directional Lighting with ESU LokPilot (Digital)
by Jfve 27/10/2025 19:00:58(UTC)
Digital (Digital)
by John N 12/10/2025 05:02:15(UTC)
Digital Concersion Question - Marklin 3310 (H0-scale)
by Eddie7979 30/09/2025 01:57:33(UTC)
Upgrading to digital (Digital)
by JJ922 19/09/2025 23:10:41(UTC)
Marklin 3075: from digital to analog (H0-scale)
by philippe99 09/08/2025 17:55:09(UTC)
Hamo 8394 BR 03 Digital conversion (Collector's Corner general)
by Imagine 01/07/2025 21:46:50(UTC)
Marklin 55035 Problem with digital commands (Big scale)
by Fabionino 03/06/2025 13:57:21(UTC)
How many digital decoders for C Track can you use? (Digital)
by michelvr 25/05/2025 23:29:05(UTC)
Digital Newsletter Back Issue link (Digital)
by BwanaJoe 11/05/2025 14:31:01(UTC)
Old Digital Gear and old Magazines (General MRR)
by BwanaJoe 05/05/2025 19:54:43(UTC)
Digital upgrade questions for the experts (Big scale)
by roundsaturn31 26/04/2025 16:49:44(UTC)
Old passenger cars with interior lighting on digital layouts (Digital)
by Evergreen 21/04/2025 15:47:07(UTC)
Digital Cameras-Nothing Works (Model railroad photography)
by analogmike 16/04/2025 14:11:57(UTC)
Trafo 6646 and Digital Loco (Digital)
by mb300e4m 26/03/2025 01:32:15(UTC)
incandescent bulbs in digital conversion (Digital)
by einotuominen 18/03/2025 18:14:34(UTC)
Loco digital conversion led light question (Digital)
by Mjn2ts 17/03/2025 20:11:49(UTC)
Digital Operation of the classic Marklin Crane 6051 (Digital)
by Johnvr 16/03/2025 17:07:42(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Toughts in this Roco Ac digital (Digital)
by Adrian666 14/03/2025 03:01:05(UTC)
Issue with digital wagon (Digital)
by Adrian666 10/03/2025 19:14:54(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
Problemer med digital dekoder på CS3 (Digital)
by tgj 03/03/2025 19:03:18(UTC)
Analog to digital Marklin 2862 (H0-scale)
by rickjames84 28/02/2025 22:28:20(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
Roco digital crane magnet instructions wanted (Digital)
by patnaik 22/01/2025 21:16:55(UTC)
Help with digital upgrade (Digital)
by artvegas 19/01/2025 06:05:44(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
Building my a digital Layout - Finally (Digital)
by White Buffalo 05/01/2025 22:03:21(UTC)
Anybody converting analog to digital in the US? (Digital)
by fynrfin 04/01/2025 22:02:16(UTC)
SEH800 Digital Conversion 60760 (H0-scale)
by johnhendry 04/01/2025 17:24:23(UTC)
A digital "Kranwagen" (#46715) controlled by the computer (Model railroad software)
by PeFu 31/12/2024 00:44:20(UTC)
Digital blocking (Digital)
by Paul Hedge 29/12/2024 04:09:36(UTC)
Reversing a digital loco on an analog setup (General MRR)
by rdn0609 15/12/2024 20:00:05(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Digitalizzare Re 4/4 34341 marklin (Digital)
by maxgand 23/11/2024 20:14:55(UTC)
Frogs - Digital/Analouge (General MRR)
by HO Collector 25/10/2024 22:55:13(UTC)
Digital loco, analogue transformer? (H0-scale)
by ChrisKenna 14/10/2024 09:41:20(UTC)
Return Digital Conversion back to Analogue (Digital)
by AjayTele 10/10/2024 06:24:06(UTC)
Digitalizzare Marklin 3155 (Digital)
by maxgand 07/10/2024 21:47:38(UTC)
Marklin 7651 digital crane (General MRR)
by 3864jk 06/08/2024 19:01:34(UTC)
Retrofit legacy Marklin M series with a digital controller. (Digital)
by Blisterexe 27/07/2024 20:12:03(UTC)
Marklin 60116 Digital Controler -- Electrical Requirements (Digital)
by WetterauSüd 13/07/2024 00:26:10(UTC)
Question about delta decoder on digital system (H0-scale)
by alevas 08/07/2024 19:19:45(UTC)
Brake module programming with CS3, M83, and digital signal 76496 (Digital)
by marklinist5999 19/05/2024 17:12:03(UTC)
3054 digital conversion and magnet mount problem (Digital)
by lpesce 05/05/2024 00:30:07(UTC)
This page was generated in 0.364 seconds.
