Offline John N
#1 Posted : 12 October 2025 05:02:15(UTC)
John N
I did a 2.5 update on my CS3 plus this morning which is working well. I then plugged my MS2 into the CS3 to do an update. Update showed as read on the scroll bar but MS now shows a continual STOP while still plugged into CS3. I then did a factory reset on the MS2 with the intention to start reloading the MS2 from the start and reload all engines from the update on the MS2. MS2 is Still stuck in STOP and now wont change to English. What do I need to do to clear the STOP and get the MS2 to read English. I terms of the change of language, I went to Spranche, highlighted English but Keine Lok at the top and STOP are the only items that show. Any guidance would be appreciated.
#2 Posted : 12 October 2025 12:31:56(UTC)
Hello John
I suppose your update is 2.5.2 (6).
As you know, the normal behaviour of an MS2 connected to a CS3+ is to be a slave to the CS3 and its stop button reflects the status of the CS3 stop button
If it does not, one possibility is that one of the pins on the MS2 connector is bent or broken.
In this case you need to straigten it or replace the MS2 cable Its article number is E146781 and its cost is 20€ or so.
Question: does your MS2 works when connected to a Gleisbox 60116?
Offline John N
#3 Posted : 12 October 2025 21:50:46(UTC)
John N
Hello Johnjean You were correct about the pins. One bent, one broke. A replacement cable is ordered and should correct the problem. Thanks for your advice. Cheers
thanks 2 users liked this useful post by John N
Online rhfil
#4 Posted : 12 October 2025 22:46:27(UTC)
rhfil
The male connectors on Marklin cables are a pain and you need to be very careful connecting them. The female plug is invariably in an awkward location. I try to get aa much light on the female plug so I can align the male plug properly and then am very gentle until I feel a proper connection. It is ver easy to bend pins and they are a bit unforgiving. Removing the cables can also be an issue. Marklin should have spent a bit more on the plugs.
#5 Posted : 13 October 2025 00:16:48(UTC)
Well, the plugs and sockets are larger versions of the DIN plugs used on PS/2 PC keyboards.
Online rhfil
#6 Posted : 14 October 2025 23:42:20(UTC)
rhfil
The plugs are fine for one time use but for clubs and people who are clumsy they lack substance.
Offline John N
#7 Posted : 15 October 2025 02:27:29(UTC)
John N
Agreed it's a club layout and used for public display therefore it's a common thing to have devs person use the plugs . Are more robust plus available?
thanks 1 user liked this useful post by John N
Online rhfil
#8 Posted : 16 October 2025 01:16:02(UTC)
rhfil
Yes but installing them would be an issue. Our club discovered that the ethernet connection in the bottom of the CS3+ eventually broke the female socket connection in the bottom that connects to our S88 AC. And it is directly attached to the motherboard so the CS3+ is back to Marklin. Also one of the rear female sockets is loose. The only solution would be to cut the cables and rewire heavy duty male and female plugs for the cut ends. That way you could leave the Marklin cables attached and just disconnect and connect the better plugs. But that would be a real challenge.
Marklin 74043 signal wiring on digital layout (Model railroad wiring)
by kaybee6 18/01/2026 07:15:51(UTC)
Decoderwerk 80203 motorized digital switch for K track (Digital)
by diesel 02/01/2026 06:40:08(UTC)
Yellow feed wire for digital decoders (Digital)
by Darren 31/12/2025 04:00:38(UTC)
3 Rails DCC/Digital layout - AC/DC wheels (H0-scale)
by Rhode 18/12/2025 09:30:53(UTC)
important questions mfx delta digital analog (Digital)
by Adrian666 24/11/2025 10:43:47(UTC)
Digital verification of loco 3608 (Digital)
by DV 11/11/2025 07:28:21(UTC)
Silberlinge 4160 – Digital Directional Lighting with ESU LokPilot (Digital)
by Jfve 27/10/2025 19:00:58(UTC)
Digital Concersion Question - Marklin 3310 (H0-scale)
by Eddie7979 30/09/2025 01:57:33(UTC)
Upgrading to digital (Digital)
by JJ922 19/09/2025 23:10:41(UTC)
Marklin 3075: from digital to analog (H0-scale)
by philippe99 09/08/2025 17:55:09(UTC)
Hamo 8394 BR 03 Digital conversion (Collector's Corner general)
by Imagine 01/07/2025 21:46:50(UTC)
Marklin 55035 Problem with digital commands (Big scale)
by Fabionino 03/06/2025 13:57:21(UTC)
How many digital decoders for C Track can you use? (Digital)
by michelvr 25/05/2025 23:29:05(UTC)
Digital Newsletter Back Issue link (Digital)
by BwanaJoe 11/05/2025 14:31:01(UTC)
Old Digital Gear and old Magazines (General MRR)
by BwanaJoe 05/05/2025 19:54:43(UTC)
Digital upgrade questions for the experts (Big scale)
by roundsaturn31 26/04/2025 16:49:44(UTC)
Old passenger cars with interior lighting on digital layouts (Digital)
by Evergreen 21/04/2025 15:47:07(UTC)
Digital Cameras-Nothing Works (Model railroad photography)
by analogmike 16/04/2025 14:11:57(UTC)
Trafo 6646 and Digital Loco (Digital)
by mb300e4m 26/03/2025 01:32:15(UTC)
incandescent bulbs in digital conversion (Digital)
by einotuominen 18/03/2025 18:14:34(UTC)
Loco digital conversion led light question (Digital)
by Mjn2ts 17/03/2025 20:11:49(UTC)
Digital Operation of the classic Marklin Crane 6051 (Digital)
by Johnvr 16/03/2025 17:07:42(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Toughts in this Roco Ac digital (Digital)
by Adrian666 14/03/2025 03:01:05(UTC)
Issue with digital wagon (Digital)
by Adrian666 10/03/2025 19:14:54(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
Problemer med digital dekoder på CS3 (Digital)
by tgj 03/03/2025 19:03:18(UTC)
Analog to digital Marklin 2862 (H0-scale)
by rickjames84 28/02/2025 22:28:20(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
Roco digital crane magnet instructions wanted (Digital)
by patnaik 22/01/2025 21:16:55(UTC)
Help with digital upgrade (Digital)
by artvegas 19/01/2025 06:05:44(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
Building my a digital Layout - Finally (Digital)
by White Buffalo 05/01/2025 22:03:21(UTC)
Anybody converting analog to digital in the US? (Digital)
by fynrfin 04/01/2025 22:02:16(UTC)
SEH800 Digital Conversion 60760 (H0-scale)
by johnhendry 04/01/2025 17:24:23(UTC)
A digital "Kranwagen" (#46715) controlled by the computer (Model railroad software)
by PeFu 31/12/2024 00:44:20(UTC)
Digital blocking (Digital)
by Paul Hedge 29/12/2024 04:09:36(UTC)
Reversing a digital loco on an analog setup (General MRR)
by rdn0609 15/12/2024 20:00:05(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Digitalizzare Re 4/4 34341 marklin (Digital)
by maxgand 23/11/2024 20:14:55(UTC)
Frogs - Digital/Analouge (General MRR)
by HO Collector 25/10/2024 22:55:13(UTC)
Digital loco, analogue transformer? (H0-scale)
by ChrisKenna 14/10/2024 09:41:20(UTC)
Return Digital Conversion back to Analogue (Digital)
by AjayTele 10/10/2024 06:24:06(UTC)
Digitalizzare Marklin 3155 (Digital)
by maxgand 07/10/2024 21:47:38(UTC)
Marklin 7651 digital crane (General MRR)
by 3864jk 06/08/2024 19:01:34(UTC)
Retrofit legacy Marklin M series with a digital controller. (Digital)
by Blisterexe 27/07/2024 20:12:03(UTC)
Marklin 60116 Digital Controler -- Electrical Requirements (Digital)
by WetterauSüd 13/07/2024 00:26:10(UTC)
Question about delta decoder on digital system (H0-scale)
by alevas 08/07/2024 19:19:45(UTC)
This page was generated in 0.492 seconds.
