Offline Bates
#1 Posted : 08 October 2018 20:34:04(UTC)
Bates
Hello forum members,
Some advice please. I have successfully fitted warm white LED's in coaches and loco's with constant current devices on my analog trains. I am now trying to help a friend with LED installation in coaches on a digital layout. I am not very familiar with Marklin digital and have a few questions: 1. Can one simply connect a LED and current limiting resistor straight to the track (via the pick up shoe) 2. what is the constant track voltage? Forgive me if these topics have been covered before. Advice would be appreciated.
#2 Posted : 08 October 2018 20:42:29(UTC)
Basically it's the same setup as with analog, but maybe with a slighty larger resistor and preferably with 4-diode Waterstone bridge or a voltage regulator chip instead of 1-2 diodes...
The "digital voltage" varies up to between +/- 22V constantly, compared to the analog +/- 16V at full speed.
You could make it simple and calculate the brightness of the LED's in digital about as they would be when you do the reverse pulse in analog.
#3 Posted : 08 October 2018 22:47:16(UTC)
Nothing beats a good test.
I would do this:
Create a simple circuit with a bridge rectifier, and a smoothing capacitor, and measure the rectified DC voltage that is produced.
Then use that value as your DC power supply voltage in the LED resistor calculations.
Perhaps someone here has already done this test...?
Offline Michael4
#4 Posted : 09 October 2018 00:03:58(UTC)
Michael4
For an alternative solution see this thread.
https://www.marklin-user...rain-Tech-Coach-Lighting
I have just had some delivered and will be installing them shortly.
#5 Posted : 09 October 2018 08:16:47(UTC)
The 22 V digital track voltage will produce about 22 V with that setup.
The 16 V AC used for analogue operation will also produce about 22 V in that case.
The reversing voltage used for analogue operation will give you about 40 V DC.
An MS2 will only give you about 16 V, but it's better to design the circuits for at least 25 V (digital only) or 50 V (digital and analogue).
Make sure the test covers the extremes. MS2 is the low end of Märklin H0 controllers with respect to track voltage, the CU 6021 is most likely the high end. And analogue operation is a completely different story.
Offline ktsolias
#6 Posted : 09 October 2018 08:44:07(UTC)
ktsolias
The diagram of a full rectifier is like this:
In the first plan a rectifier bridge is used, (better solution, fewer components) and in the second diodes.
The output voltage of this circuit is calculated as follows:
{V(in)-1,4} x 1.4 = V(out)
Ex: (18v-1,4)X1.4 = 23,24
Another solution is to use a voltage regulator.
I don't think that is necessary for LED lighting circuits. Usually we use much more higher resistors just to dim the LED's because they are to bright.
Something that must be in our mind is that if we use to many circuits with capacitors, without a resistance and a diode, when we turn on the power supply to the layout, all the resistors start to draw current and if they are many draw so much that is more than the capacity of the power supply and looks like a shortcut, and the power supply (MS2 or CSx) cuts the power!!!
Costas
#7 Posted : 09 October 2018 11:35:09(UTC)
Yep. Now use these all the time. No flickering or sliders or current conducting couplers etc. Great product.
#8 Posted : 09 October 2018 14:09:46(UTC)
Please note that this formula is just a rule of thumb and that it applies when the input voltage is sine wave AC.
It does not apply to DC voltages or digital track voltages.
Maybe it should be V(in) x 1.4 - 1.4 = V(out).
Offline Bates
#9 Posted : 12 October 2018 20:46:06(UTC)
Bates
Thanks everyone for the advice and comments
LED lighting and MS3 for Buildings (Digital)
by garben 06/01/2025 18:06:52(UTC)
LED lighting with replacement decoder (General MRR)
by jpklecker@yahoo.com 02/07/2024 03:29:45(UTC)
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
New passenger car LED lighting burnout - is this normal (H0-scale)
by dwptravel 06/07/2022 02:14:37(UTC)
LED lighting for the layout (Model railroad wiring)
by Bernd 21/12/2021 15:55:55(UTC)
LED lighting (Digital)
by tinroofrusted 07/09/2021 15:48:19(UTC)
Success with coach LED lighting WORKS FOR ANALOG AS WELL (H0-scale)
by dominator 12/11/2020 07:41:55(UTC)
Marklin maximum voltage for passenger/freight cars LED lighting (H0-scale)
by seanshintaro 10/05/2018 13:33:52(UTC)
Putting Led Lighting In A Silberlinge Pilot Coach (Small scale)
by Artologic 15/08/2017 17:28:54(UTC)
Roco ET 420 - LED Interior Lightning with ESU Digital LED lighting strip (H0-scale)
by Moritz-BR365 14/03/2017 15:39:03(UTC)
LED Lighting for the Plastic Passenger Cars (H0-scale)
by Hoffmann 07/02/2014 23:26:22(UTC)
LED Lighting for Tin Plate Passenger Cars (H0-scale)
by Hoffmann 07/02/2014 14:44:07(UTC)
New LED lighting for coaches with decoder (Digital)
by jeehring 21/03/2010 20:39:15(UTC)
LP Convert of 3021/3676 with LED lighting Update (Digital)
by Ross 16/06/2009 05:02:09(UTC)
LED lighting kits 73400 and 73401 (General MRR)
by mjrallare 11/10/2008 19:04:41(UTC)
Strange problem with LED lighting (Digital)
by gachar001 30/08/2008 23:37:01(UTC)
V36 Led Lighting Improvement (Digital)
by Ross 06/05/2008 11:32:43(UTC)
This page was generated in 0.640 seconds.
