Offline efel
#1 Posted : 29 August 2005 01:51:15(UTC)
efel
Some of my locos, with rather old decoder, have their lights that flicker, likely due to single phase rectifiers.
Did anyone solve the problem (in another way that updating the decoder)?
Thanks in advance!
Fred
Offline jorge_vilarrubi
#2 Posted : 29 August 2005 04:32:25(UTC)
jorge_vilarrubi
Hello Fred, you need to feed the lights from the + pole of the decoder instead of the chassis.
For doing this, you need to isolate the light bulbs from ground.
Märklin has some connectors to accomplish it, those supplied with 60903 and 60904 kits.
If you decoder has a Black wire which goes to the motor, that is the + pole. If your decoder has no Black wire (e.g. 6090, 6081) you can create a + pole connecting two diodes (1N4001 will fit) from both Ground and the Pickup Shoe, with its cathodes (marked with a white or black circle) joined and pointing to the lamps, this will be your + pole.
Feed both lamps with the + pole and either the gray or yellow wire and you will have flicker-free lights.
Hope this can help.
Best regards from Buenos Aires, Argentina.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline efel
#3 Posted : 29 August 2005 17:22:24(UTC)
efel
Hi Jorge,
Thanks for your answer. I've just tried it and it works perfectly well.
As the loco lamps are 35 mA, I used 1N4148 diodes (small size).
I wonder why such a mere solution was not used by Marklin: flickering lights are really unrealistic!
Thanks again,
Fred
Offline hqstu
#4 Posted : 02 September 2005 08:37:15(UTC)
hqstu
I use the 2 diodes and capacitor approach. I initially used the 1N4148 but they failed after a short time, so I changed to bigger power type diodes 1N4007 (I think)
Stuart
Offline efel
#5 Posted : 04 September 2005 00:48:59(UTC)
efel
Hi Stuart,
What is the aim of the capacitor?
Is'nt it the large starting capacitive current that may damage the diodes? They are supposed to sustain 100mA, permanent current.
Anyway, if they burn out, I will change them for 4004 or 4007.
Fred
Offline hqstu
#6 Posted : 04 September 2005 20:16:30(UTC)
hqstu
Not sure, by no means an expert, but every website I've seen has this approach. I guess it may be some type of smoothing effect.
Stuart
3696 with flickering lights (Digital)
by dominator 10/04/2020 02:00:57(UTC)
Flickering lights (Digital)
by ocram63_uk 12/01/2019 20:25:35(UTC)
Flickering lights in passenger wagons (H0-scale)
by Br502362 25/02/2016 16:26:21(UTC)
29605 Flickering Lights/Braking Delay-The Saga Continues... (Digital)
by Dimi194 17/04/2014 03:10:34(UTC)
digital start set 29539-Flickering lights? (Digital)
by Joseph Meiring 10/05/2011 19:19:00(UTC)
Flickering lights on HAG E-Lok 225 RE 4/4 I (Digital)
by biswasg 06/01/2009 23:45:35(UTC)
Revisited: flickering lights in coaches (Digital)
by Rudi Bekkers 04/01/2007 23:52:22(UTC)
Flickering lights with digital (Digital)
by Rudi Bekkers 23/02/2006 12:50:57(UTC)
by Gregor 28/12/2003 16:06:13(UTC)
Flickering Lights on a 37637 (Digital)
by xxup 15/06/2003 12:13:19(UTC)
This page was generated in 0.358 seconds.
