Offline Gregor
#1 Posted : 28 December 2003 16:06:13(UTC)
Gregor
Hello All,
I am about to perform a 60904 conversion, where I cannot use the orange return line for the rear lights. According to many, the lights may flicker when connected to mass, but how bad is this realy ? And would a small capacitor solve this flickering ? This should not harm the function output, I guess.
Gregor
Offline Maxi
#2 Posted : 28 December 2003 16:43:05(UTC)
Maxi
Which locomotive are you upgrading and why are you not able to use the orange wire?
Could you post a picture of the inside of the locomotive so we may better understand your situation?
Matthew
Offline Gregor
#3 Posted : 28 December 2003 17:43:20(UTC)
Gregor
It's the 3070, Swiss/Dutch TEE 5 car combination. Special 3-wire connectors run through the complete train. I want to use 1 wire for car interior lights, to be switched through a function output, 1 wire is for the white front light of the last car, and the last wire is for the red tail light of the last car.
In this way, no wire is available for the return wire.
Gregor
Offline Bart
#4 Posted : 28 December 2003 20:10:50(UTC)
Bart
Basically, orange is DC+
Some time ago, perz came with a smart and simple way to create this, using the wheels and pickup shoe, plus 2 diodes:
http://home.swipnet.se/perz/funcret.gif
Look ma, no wires! biggrin
Thanks Per!
*Bart
Offline mascagni
#5 Posted : 05 January 2004 17:59:38(UTC)
mascagni
Hello all: I too am planning a conversion of a 3070, although I am planning on just adding a Delta decoder (66032). The reverser in it does not really work. My question is whether one has to do anything special to this Triebwagon given that the pickup shoe that is active is direction dependent in the original? Thanks.
Michael Mascagni, Tallahassee
Offline rugauger
#6 Posted : 05 January 2004 18:04:02(UTC)
rugauger
I think Uhlenbrock offer something like an add-on to their decoders that enables direction dependent selection of the pickup shoe. Have a look at their web site - www.uhlenbrock.de - before you buy your 66032.
Richard
Offline Gregor
#7 Posted : 05 January 2004 21:30:28(UTC)
Gregor
Hello Micheal, hello All,
Are you sure you need the direction dependent pick-up shoe ? Because normally this is only necessary when you want to stop the train by cutting power to the track (or a section), including the powerless emergency stop tracks that are recommended to use with braking modules.
I will not use this feature in my 3070, because I stop the train fully digital without powerless section. However I will keep the shoe on the last car, because I want to have train detection there when I drive rearwards. I use 2 ways of detection:
1) Insulated section, which the axles of the train will connect to ground when passing.
2) Current detection in certain sections. For this, a small current needs to be detected, so I have connected the pickup-shoe in the rear car through a resistor to mass. In this way, the rear car will always use a very small amount of power, enough to detect the train when driving reverse. Power to the motor always will come through the pick-up shoe of the motor car, regardless of direction.
Gregor
3696 with flickering lights (Digital)
by dominator 10/04/2020 02:00:57(UTC)
Flickering lights (Digital)
by ocram63_uk 12/01/2019 20:25:35(UTC)
Flickering lights in passenger wagons (H0-scale)
by Br502362 25/02/2016 16:26:21(UTC)
29605 Flickering Lights/Braking Delay-The Saga Continues... (Digital)
by Dimi194 17/04/2014 03:10:34(UTC)
digital start set 29539-Flickering lights? (Digital)
by Joseph Meiring 10/05/2011 19:19:00(UTC)
Flickering lights on HAG E-Lok 225 RE 4/4 I (Digital)
by biswasg 06/01/2009 23:45:35(UTC)
Revisited: flickering lights in coaches (Digital)
by Rudi Bekkers 04/01/2007 23:52:22(UTC)
Flickering lights with digital (Digital)
by Rudi Bekkers 23/02/2006 12:50:57(UTC)
by efel 29/08/2005 01:51:15(UTC)
Flickering Lights on a 37637 (Digital)
by xxup 15/06/2003 12:13:19(UTC)
This page was generated in 0.485 seconds.
