Offline Drongo
#1 Posted : 21 April 2015 14:29:02(UTC)
Drongo
Hi Everyone,
I've started making another layout with C Track and I want to use TrainController with my CS2. Therefore I need to install sensors and create blocks within the track, however, every piece of track has to be cut so as to isolate the 2 rails.
My question is - why can't Marklin manufacture the C Track with the 2 rails already isolated? Is there any reason to have the 2 rails connected?
Greg
#2 Posted : 21 April 2015 14:40:21(UTC)
Hi Everyone,
Greg
Yes, it makes the running of the trains more reliable. I am surprised your blocks are such that you need to split the rails on EVERY piece of track. Note that it is an impracticality when you get to the points ...
Offline sjlauritsen
#3 Posted : 21 April 2015 15:46:03(UTC)
sjlauritsen
I am surprised your blocks are such that you need to split the rails on EVERY piece of track. Note that it is an impracticality when you get to the points...
If you want to have a feedback sensor in a block, you need to cut the connection between the two rails in the join underneath each piece of C track. Otherwise the feedback sensor will not work. There is a connection in both end of every piece of track. A normal wire cutter will do. I also push the metal pieces a bit away from each other. Some times they can begin to touch each other, which will ruin the isolation of the rail.
Søren from Denmark
#4 Posted : 21 April 2015 16:26:27(UTC)
You can use other types of sensors to avoid cutting the connections between tracks. The main advantage of the Marklin 3 rail system is its superior current conducting properties, and this is negated when the tracks are isolated in this way. It also means that if you are using non-Marklin wagons with original 2 rail wheels they wont be detected.
For trains detection many people use optical sensors or magnetic reed switches, especially in the 2 rail DC world.
#5 Posted : 22 April 2015 11:46:54(UTC)
Not totally. Once the first pair of wheels bridges one rail to the other, the other also becomes "ground". Once a whole consist is present on the track, there will not be any difference between the potential of the rails.
To use this system for train-detection is one of the huge advantages of the 3-rail system!
#6 Posted : 22 April 2015 12:06:31(UTC)
Consider a Köf III running all alone. Three wheels without traction tyres for good contact.
On a contact track there is a 50% chance that only one wheel without traction tyre will be left on the "ground" side with two wheels on the "dead" side. When used with s88, the famous diode trick can improve contact in such a case.
You need three feeder wires if they are isolated, only two if they are connected.
It's easy to cut them, it's more complicated to connect them.
For C track without centre rail, they cut the bridge at the factory.
K track comes isolated (most pieces except feeder tracks and some turnouts), C track comes connected.
Offline Drongo
#7 Posted : 24 April 2015 15:03:24(UTC)
Drongo
Thanks fellas for the information. I'll just keep on cutting. Laugh Laugh Laugh
Pillars for C track (H0-scale)
by Luna 24/02/2024 05:07:30(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
C track dead spots? (H0-scale)
by Carias205 26/01/2024 23:47:54(UTC)
C track geometry (H0-scale)
by Alex H 23/01/2024 20:51:45(UTC)
C track points (Digital)
by dave55uk 06/12/2023 17:38:21(UTC)
Marklin C track and iTrain (Digital)
by honovice 04/12/2023 15:59:59(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Fixing C Track down (H0-scale)
by Alex H 31/07/2023 22:50:40(UTC)
R4/R5 reverse loop C track (H0-scale)
by Snowfun 19/07/2023 18:22:25(UTC)
by einotuominen 23/03/2023 14:43:49(UTC)
C TRACK NOISE (H0-scale)
by Alex H 23/02/2023 21:54:45(UTC)
Feasibility of Running 4 separate Marklin C Track Loops Using 2 Mobile Stations 60653 (General MRR)
by mjborelli 31/01/2023 02:44:06(UTC)
C track wiring for DCC (H0-scale)
by Alex H 24/01/2023 21:35:17(UTC)
Multi-Level Marklin C Track Layout (H0-scale)
by MarklinDutchies 03/01/2023 02:04:25(UTC)
Marklin or Trix C Track? (H0-scale)
by Alex H 29/12/2022 23:05:44(UTC)
C track automation (Digital)
by Carlos 09/12/2022 02:33:44(UTC)
Marklin, C track and 52 degrees (H0-scale)
by revmox 28/10/2022 11:18:53(UTC)
Can Digital Bahn GleisReporter C track connections/contact track (Digital)
by einotuominen 06/10/2022 10:49:05(UTC)
C track and SCARM (H0-scale)
by revmox 02/10/2022 05:37:22(UTC)
Electronic Track Cleaner (Small scale)
by dannyboyz 25/07/2022 23:09:34(UTC)
New Roco AC sound loco on Marklin C track Analog system (H0-scale)
by egonzinc 14/07/2022 12:25:33(UTC)
C Track 3Way Left Turns (H0-scale)
by LocoLynk 20/06/2022 06:37:35(UTC)
C track Turnout noob question (H0-scale)
by stratos858 13/06/2022 23:11:03(UTC)
Transparent C Track (General MRR)
by Mman 18/05/2022 18:31:40(UTC)
New Marklin C track Turntable and TC9 (Model railroad software)
by eurotrain 18/05/2022 17:33:44(UTC)
Is C track any good (General MRR)
by Train train 21/03/2022 10:06:06(UTC)
Lantern for switch k and c track (H0-scale)
by Puttputtmaru 15/03/2022 03:31:48(UTC)
Sound triggered automatically in a specific track position (H0-scale)
by Puttputtmaru 13/03/2022 15:29:01(UTC)
What is this just announced 2023 new c track DKW Bächle was on about? (H0-scale)
by Minok 10/02/2022 10:02:52(UTC)
Mixing M track and C track (Model railroad wiring)
by PedroRyder 13/01/2022 16:35:36(UTC)
Turnout mechanism c track (H0-scale)
by DB Fan 05/01/2022 04:46:15(UTC)
Stations and platforms for C track (H0-scale)
by revmox 30/11/2021 07:46:42(UTC)
C track Layout plans for sale (H0-scale)
by Rngr2 28/11/2021 16:18:25(UTC)
360 mm C track section (General MRR)
by Bones 23/10/2021 11:37:19(UTC)
Double slip C track (General MRR)
by Drongo 18/09/2021 08:40:04(UTC)
C Track point levers (H0-scale)
by Mman 25/08/2021 20:19:13(UTC)
C track curved point problem (H0-scale)
by revmox 29/07/2021 20:11:24(UTC)
C track curved points (H0-scale)
by revmox 28/05/2021 06:10:13(UTC)
Trix c track (Digital)
by Tangieriris 12/03/2021 21:04:01(UTC)
Awaiting a C track delivery (H0-scale)
by marklinist5999 20/02/2021 17:17:17(UTC)
C track part numbers in SCARM (Model railroad software)
by fbaube 17/02/2021 16:11:54(UTC)
C Track and K track flex (H0-scale)
by Timnomads 08/02/2021 14:33:05(UTC)
Who said C track is ugly! (Painting & Weathering)
by michelvr 01/02/2021 16:42:22(UTC)
Märklin’s C track + Ballast + Paint = Realistic Looking Track! (Painting & Weathering)
by michelvr 23/01/2021 16:01:09(UTC)
Which turnout to use to minimize space between c tracks (H0-scale)
by geir 22/01/2021 21:52:56(UTC)
c track bridge pillars (General MRR)
by MalinAC 02/01/2021 11:17:21(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
Marklin H0 - Article No. 07451 Track Planning Book - C Track. English Edition (General MRR)
by Abdul 14/12/2020 21:39:35(UTC)
C Track Junction problem (H0-scale)
by Timnomads 14/12/2020 14:58:44(UTC)
This page was generated in 0.412 seconds.
