Offline bobhunt
#1 Posted : 05 March 2007 11:24:24(UTC)
bobhunt
I am having some trouble with the powered level crossing.
On unpacking it I installed it as per the instructions - yellow wire to the same terminal as yellow leads from points on the transformer.
I aligned the blue contact indicators with the relevant signs on one of the road ramps, and a brown wire from a track terminal suggested by my dealer to the same terminal on the transformer as the brown wire to the points controllers.
It worked perfectly.
I then decided to separate the lead contact point from the crossing by snipping the contacts on a straight section and inserting it between the crossing and the contact. Did not work.
I took the whole lot back to the dealer today and we tried to replicate my setup. The only difference was that he did not have a Central Station (rather an older digital controller) and provided that we did not attach the brown power wire it worked perfectly.
Back here I have tried every combination I can think of and when I attach both the brown and yellow wires as per the diagrams the best that I can get is the warning lights constantly on, the gates up but pulsating and the crossing giving off a pulsating sound.
I need help!!
Bob Hunt
Offline MärCo
#2 Posted : 05 March 2007 11:58:52(UTC)
MärCo
1) What do you have at home? A analog, Mobile Station or Central Station layout?
2) Are the arrows on the rails all at the same side?
3) Is the Central Station and the level crossing powered by the same transformer? That is not permitted.
Absolutly AFB-NOHAB fan ;-)
Offline bobhunt
#3 Posted : 05 March 2007 23:28:12(UTC)
bobhunt
1. Central station
2. The arrows and blue discs are all on the same side
3. The central station has its own transformer, the level crossing is powered by a separate transformer - as are the points and uncouplers.
[size=1" face="Verdana" id="quote]quote:Originally posted by MärCo
<br />1) What do you have at home? A analog, Mobile Station or Central Station layout?
Bob Hunt
Offline MärCo
#4 Posted : 05 March 2007 23:39:14(UTC)
MärCo
[size=1" face="Verdana" id="quote]quote:Originally posted by bobhunt
<br />I then decided to separate the lead contact point from the crossing by snipping the contacts on a straight section and inserting it between the crossing and the contact. Did not work.
I need help!!
As far I understand it, it works perfect as you connect the level crossing according to the Märklin manual.
But after that, what are you trying?
#5 Posted : 06 March 2007 01:10:58(UTC)
You have been a member since:: 27/08/2005(UTC)
The crossing gets its power from the tracks. NOT a separate Transformer.
REd/brown Lead from Crossing to positive on track AFTER the Contact Piece. Yellow from one side of Crossing to the Other. the Red/brown Wire shares the connection on one side.
It is important that the Contacts on hte crossing are making good contact with the centre piece of the crossing.
Nev
Nev.
Offline MärCo
#6 Posted : 06 March 2007 06:43:59(UTC)
MärCo
<br />The crossing gets its power from the tracks. NOT a separate Transformer.
Nev
Nev.
That is a very wrong way to connect a level crossing. The electro magnets from the level crossing will distort the signal from the Central Station. You will probably hear a humming sound.
#7 Posted : 06 March 2007 07:12:47(UTC)
Nev
Nev.
It is the only way it will work.and it does work. I went through this exercise 12 months ago.
nev
n
#8 Posted : 06 March 2007 10:45:03(UTC)
Wow!.. My M-track crossing which looks almost identical uses a separate transformer that has a common ground (brown wire) with the track ground (brown) wire.. I use computer control (used to be powered by the IB - but that's is a sad tale)..
Offline bobhunt
#9 Posted : 06 March 2007 10:49:42(UTC)
bobhunt
Nev
We have made some progress and thanks for the help so far.
I rewired the crossing as you suggested and when a train enters it the warning light come on and remains until it has exited it.
What does not happen is that the boom gates lower themselves. They remain vertical, vibrating.
So more to do.
Isn't it a pity that there is not someone from Marklin to assist in these types of situations - after all it is their product.
Nev
Nev.
nev
n
Bob Hunt
Offline MärCo
#10 Posted : 06 March 2007 13:12:00(UTC)
MärCo
The power supply from the level crossing must be seperated from the Central Station.
http://www.maerklin.de/f...;sb=5&o=&fpart=1
Offline Tony
#11 Posted : 07 March 2007 08:01:13(UTC)
Tony
Hi Bob
A couple of years ago there was some discussion on connecting level crossings - may be of interest to you:
https://www.marklin-user...amp;SearchTerms=crossing
Regards Tony
Offline bobhunt2
#12 Posted : 08 March 2007 06:57:05(UTC)
bobhunt2
Thanks very much Tony - I have my electrical engineer on the job and will let you know the outcome.
[size=1" face="Verdana" id="quote]quote:Originally posted by Tony
<br />Hi Bob
Offline bobhunt2
#13 Posted : 09 March 2007 04:24:15(UTC)
bobhunt2
I think we have solved the problem:
*wire as per the diagram in the book using the separate transformer
*attach the brown wire to the unbroken rail
*improve the bridging contact between the ramps on the side of the crossing.
Here's hoping!!
[size=1" face="Verdana" id="quote]quote:Originally posted by bobhunt2
<br />Thanks very much Tony - I have my electrical engineer on the job and will let you know the outcome.
<br />Hi Bob
#14 Posted : 18 March 2007 13:25:24(UTC)
I am using a 60652 Mobile Station, and it took me four hours to figure out, and get this working corectly.
1. Separate transformer to power crossing.
2. Arrows embossed on crossing plastic, and blue arrows on track set on same side.
3. Hooked up everthing, and red and yellow wires as per M diagrams, but I DID NOT HOOK UP THE BROWN wire.
4. Works perfectly except that the crossing buzzes, and also shakes a little, but I guess that is typical of solenoid devices.
5. I have the crossing set on double track, it looks good. Happy customer.
#15 Posted : 18 March 2007 13:32:15(UTC)
Welcome to the forum,kimballthurlow.
#16 Posted : 18 March 2007 14:01:18(UTC)
Thankyou Steven. After reading the forum on the "Dutch" Marklin family, I have aching sides.
And I have to admit here that the Irish contributed greatly to Australian society. Well, probably more than greatly, my wife is pure Irish descent.
But she gave me the impression that the Irish don't care much for Marklin, or any model train stuff, for that matter.
Actually, while she watches TV, I can do almost anything and get away with it.
Offline Rowan
#17 Posted : 18 March 2007 20:37:07(UTC)
Rowan
Hi Kimball, welcome.
Smile
#18 Posted : 19 March 2007 00:41:22(UTC)
Welcome Kimball, another for Brissie
#19 Posted : 19 March 2007 10:36:02(UTC)
G'day Kimball... I am in Brisbane too.. Irish wife hey! Thank God for the TV...
#20 Posted : 19 March 2007 11:12:06(UTC)
<br />G'day Kimball... I am in Brisbane too.. Irish wife hey! Thank God for the TV...
#21 Posted : 19 March 2007 11:13:35(UTC)
Maybe it time for us Brisbaneites to have a social greet and meet and a XXXX or two. biggrin
Hands up who from Brisbane or near Brisbane.
#22 Posted : 19 March 2007 13:51:47(UTC)
Pick me!
Edited by moderator 10 January 2011 20:12:25(UTC)  | Reason: Not specified
#23 Posted : 20 March 2007 00:33:09(UTC)
1. 2 Starters so far . One Stubby and 2 Straws. biggrin
2/ Meeting Point??
#24 Posted : 20 March 2007 09:55:58(UTC)
1. More for us.. biggrin
2. Somewhere in Brisbane?
#25 Posted : 09 April 2007 14:19:16(UTC)
Further on recent discussions.
My level crossing 74922 works well on double track, and I have it connected to a separate transformer, and also use MS 60652.
At this time, the separate transformer is used only for the level crossing.
Today, I disconnected the separate transformer by mistake.
<u>Hey presto!!</u> The crossing still works perfectly without the transformer.
Now I realise it is in Marklin's interest to have everyone believe that you MUST have a separate transformer for this device. No hard fellings, because I will need it for lights and other devices anyway.
And if I use a CS, the situation may change again.
I thought this fact may interest other users.
#26 Posted : 09 April 2007 14:31:16(UTC)
<br />UserPostedImage
Pick me!
Don't forget me..... that's if I can ever find out when this dang course is....
Edited by moderator 10 January 2011 20:13:49(UTC)  | Reason: Not specified
#27 Posted : 09 April 2007 14:40:08(UTC)
On going back over the posts, Nev W also has the crossing working without separate transformer.
Just to clarify, I disconnected the transformer at the 240v, so any track wiring connections I did were still intact.
Offline Ayala
#28 Posted : 09 April 2007 19:11:43(UTC)
Ayala
probably this is not the best forum to post this question, but me too, I'm having problems regarding the installation of Viessmann Railroad Crossing Gate HO Refª5100 in a single way C-Marklin track, where the trains always run in the same direction.
Can anybody help me or point me to the right forum in English, please?
thanks
Ayala
Offline efel
#29 Posted : 10 April 2007 01:39:32(UTC)
efel
Hi Ayala
You can get english manual at:
http://www.viessmann-modell.com/en/suche/suche.php
You need either reed relays (7555) or "contact track" 24994.
Follow the diagram given by Viessmann. If you use reed relays, and if it is a single one way track, you may use only 1 relay on each side (instead of 2 for a 2 way track, as shown on the diagram).
Reed relays need magnet under loco.
Viessmann crossing gate is a good choice for the gates can move very slowly, and are very realistic.
Have fun
Fred
Offline Ayala
#30 Posted : 13 April 2007 18:43:52(UTC)
Ayala
Hi efel,
I managed to install the Viessmann RailRoad Crossing Gate HO Ref.5100.
I installed 1 relay in each side because the trains runs only in one direction. And works find!
Now I bought Viessmann "Indicating Electronic Warning Lights" Ref 5835 with 4 warning lights and 1x "blinking light device".
The question now, is how I install the Warning Lights (ref 5835) with the crossing gate?
I can't found an English Spoken Forum regarding Viessmann stuff....
Ayala
Offline efel
#31 Posted : 13 April 2007 20:19:25(UTC)
efel
[size=1" face="Verdana" id="quote]quote:Originally posted by Ayala
Referring to the 5100 "Assembly instruction" that you can download on the Viessmann site, you have to follow the connection of Figure 6.
On that Figure, the wires on the right, going to the "switching contact", are the 2 red wires of a gate drive unit.
As you have 4 lights you can use all the outputs of the 5065, instead of 2 as shown on Figure 6.
Fred
Offline Ayala
#32 Posted : 14 April 2007 01:02:26(UTC)
Ayala
Okay, I know this is not a Viessmann forum, but I really need your help
Here is the story:
I installed a Viessmann Railroad Crossing Gate HO Refª5100 in a single way C-Marklin track, where the trains always run in the same direction. From the left to the right on the picture.
It works perfectly. The cross gate close when the trains (with magnets) reaches Reed A, and opens when the train reaches Reed B. Red Wires 5,6,7 and 9 are not used!
Now I want to install the Warning Lights (ref 5835) with the crossing gate (4x Warning lights), but I can’t figure out how to connect so many wires!
Here's the picture:
Now the questions:
1) where should I connect the black wires 1, 2, 3 and 4, that are connect to the Warning lights?
2) What should I do with red wires 5,6,7 and 8? I did not use them until now and the crossing gates works perfectly
BTW, I'm using a separate transformer to power the crossing gate as well as the blinking warning lights!
Any suggestion would be welcome!
Ayala
#33 Posted : 14 April 2007 03:11:22(UTC)
1,2,3,4 should be connected to the Yellow terminal
Offline efel
#34 Posted : 14 April 2007 10:28:19(UTC)
efel
Modify your diagram as follows:
1- Connect 1,2,3 and 4 to the yellow wire.
2- Remove the brown wire connecting the brown plug of the 5065 to the transfo brown plug
3- connect 6 to the brown plug of the 5065 instead
4_ Connect 7 to the transfo brown plug.
Of course you may use 8 and 9 instead of 6 and 7.
Fred
Offline Ayala
#35 Posted : 15 April 2007 00:49:24(UTC)
Ayala
[size=1" face="Verdana" id="quote]quote:Originally posted by efel
<br />Modify your diagram as follows:
Fred
Hi Fred
it works!
thanks a lot for your tips!
I would never make it without your help!
Ayala
Offline Rowan
#36 Posted : 18 June 2007 21:48:07(UTC)
Rowan
How did it all end up Bob?
Smile
Level Crossing for R1 curve (H0-scale)
by Alex H 11/03/2024 20:05:07(UTC)
Level crossings with a ramp (Model kits & layout details, kitbashing and such)
by 1borna 03/03/2024 20:59:54(UTC)
Hesitating Halfway: The 1959 Lauffen (Germany) Level Crossing Collision (Prototype)
by applor 12/10/2021 12:19:16(UTC)
Level Crossing 7054 (H0-scale)
by sharples 02/09/2019 01:18:22(UTC)
Motorise an Auhagen 11345 level crossing (H0-scale)
by LongHairedDavid 08/04/2019 17:21:28(UTC)
Woman hit by train at Brisbane level crossing (Prototype)
by ShannonN 28/02/2019 00:03:47(UTC)
Era III DB level crossings (Prototype)
by LongHairedDavid 23/01/2019 11:30:06(UTC)
Adjustment to Viessmann 5104 level crossing barrier arm (H0-scale)
by marklin61 25/06/2018 08:13:09(UTC)
wiring up my level crossing (Collector's Corner general)
by MalinAC 26/01/2017 16:02:39(UTC)
Marklin level crossing project (H0-scale)
by ixldoc 02/07/2016 05:59:35(UTC)
Marklin 74920 level crossing (General MRR)
by charles Sharpe 03/03/2014 14:20:19(UTC)
Marklin Level Crossing 7393 (Collector's Corner general)
by kumarvartak 22/12/2013 15:22:21(UTC)
7192 Electric Level Crossing Instructions please (Collector's Corner general)
by cookee_nz 09/12/2012 22:44:34(UTC)
Level Crossing 7054. (Collector's Corner general)
by Ian555 06/08/2012 15:40:15(UTC)
Viessmann 5835 Level crossing (H0-scale)
by Fenderico82 20/04/2011 17:01:10(UTC)
Another level crossing collision (Prototype)
by Breitenfurt 20/08/2010 19:53:27(UTC)
Is this a peculiarly British problem or is it worldwide - level crossings (Prototype)
by Breitenfurt 23/06/2010 00:12:54(UTC)
level crossing (Digital)
by charles Sharpe 08/05/2007 21:53:13(UTC)
Level Crossings (General MRR)
by bobhunt2 22/02/2007 07:03:58(UTC)
K-track level crossing (H0-scale)
by rschaffr 11/12/2005 04:16:05(UTC)
Wiring for Level Crossing 74920 (H0-scale)
by banco 22/07/2005 14:23:31(UTC)
fitting level crossing on curved track (H0-scale)
by grattieri 14/11/2003 09:01:46(UTC)
This page was generated in 1.583 seconds.
