Offline Zme
#1 Posted : 12 February 2025 00:03:45(UTC)
Zme
Hello everyone, hope all is well.
I thought some might find it interesting to see what is different between the same model 5 pole and coreless locomotive. This steamer is a BR 86.
The frame on this model seems to be identical. Notice the small core less motor on the one to the right. This motor is nestled in a motor bracket which keeps it stable against the worm gear. The lower portion of this bracket seems to be the same size as the 5 pole motor magnetic case. What I have noted is the core less motor bracket does not have a part number assigned on the Marklin parts diagram. Apparently, this piece is not available to the customer.
It would seem if we could get this bracket part 3D printed, we would be able to replace a 3 or 5 pole with a coreless motor. Is anyone aware of these brackets being produced? Could you recommend a source?
Take good care.
Zme
Does anyone have a suggestion for reassembling the drive bars and linkages which have come detached on the model on the left? What a puzzle. Darn!
thanks 3 users liked this useful post by Zme
Offline georgi UK
#2 Posted : 16 February 2025 21:30:19(UTC)
georgi UK
You need to take a pic of the good side, then mirror this to the other side,,, and perhaps keep away from the small radius curves, the usual culprit.
thanks 1 user liked this useful post by georgi UK
Zme
Offline Zme
#3 Posted : 28 February 2025 19:02:34(UTC)
Zme
Hello, hope all is well.
Thanks for the suggestion, but these are a bit more complicated than the earlier versions. There is an extra link to the mechanism which is out in front of what is usually modeled. This is a newer version of the BR 86 and the extra linkage is being modeled on this one. I thought I could point this out by enlarging my photo, but I lose the detail. You can see it a bit in my original photo.
Of course, most all of these links are for show anyway, but must be properly reattached to prevent binding or rubbing on another nearby bar.
I tried a number of different things but most were unsuccessful. I used tape which was advertised as designed for sensitive or delicate work, but the parts are so small it wouldn’t stay together. I used a magnet but learned the smaller links are not magnetic as I thought this could be used to keep things in place while trying to reattach the pin. The links just keep moving out of place and this was very frustrating. I would try different things, the put things down until I could think of something else. I needed to come up with a solution to solve the puzzle.
After several weeks of trying different things, I decided to use some spit to keep everything from moving, and this worked. I used some spit and placed each link on top of the wheel attaching point. I think there were three and then the link with the pin in it. Once this was done, I added the pin to the top of the pile and used the flat end of a tool to press it in.
I was surprised at the amount of effort which was required and I now believe this pin was only loosely attached and this lead to the failure.
This is yet another story which supports the theory “There is nothing easy in Z”. Thought you might find this to be an interesting story. Who would this spit could solve a problem with these delicate jewels. Maybe this is a trick used at the factory. I hope I revived this one.
Take good care, have a great weekend 😅
Zme
Offline Poor Skeleton
#4 Posted : 28 February 2025 22:16:00(UTC)
Poor Skeleton
Who would this spit could solve a problem with these delicate jewels. Maybe this is a trick used at the factory. 😅
Zme
Maybe HOS isn't hardened oil at all...
Have a great weekend, everyone!
Chris
39662 Insider - N&W (USA) comparison (Loco Reviews)
by kimballthurlow 15/11/2022 04:23:50(UTC)
Driving comparison: Uhlenbrock 76200 vs mLd3 equipped E10's (Digital)
by Donb 08/11/2022 01:33:48(UTC)
Roller Test Stand Comparison and Evaluation (Big scale)
by Surge 02/10/2020 16:45:35(UTC)
Roco SBB EWII (2018) Review and Comparison (New Photos) (Reviews of rolling stock)
by mike c 29/05/2019 09:02:54(UTC)
Track cleaning car comparison - Lux vs Dapol (H0-scale)
by Minok 10/03/2019 22:46:06(UTC)
Z and N Scale Comparison (Small scale)
by grahame 24/10/2014 12:51:51(UTC)
Comparison of Sleeping Car models (H0-scale)
by mike c 06/02/2014 20:12:04(UTC)
comparison old-replica (Collector's Corner general)
by frankNL 09/12/2011 10:39:47(UTC)
Comparison table for layout control software (Model railroad software)
by GSRR 23/05/2010 20:46:23(UTC)
Digital Command Stations Comparison Sheet (Digital)
by sjlauritsen 06/09/2009 21:28:49(UTC)
DCC vs MFX comparison? (Digital)
by TimR 22/04/2009 04:22:26(UTC)
Comparison between Uhlenbrock and Maerklin systems (Digital)
by biswasg 25/12/2008 17:46:31(UTC)
Comparison to Marklin: HAG & Hobbytrade HO? (H0-scale)
by Larry 21/03/2007 07:20:19(UTC)
This page was generated in 0.240 seconds.
