Offline PMPeter
#1 Posted : 23 November 2017 15:25:17(UTC)
PMPeter
In one of the other postings regarding servo installations a statement was made by Applor saying "If you use under board servos not only does it look a lot better it also means you can also mount the turnout lanterns on the correct side too."
What is the correct side?
Offline applor
#2 Posted : 23 November 2017 23:21:00(UTC)
applor
In the majority of cases (from real life photos I have studied), the lantern is installed on the straight side of the turnout, rather than the curved.
There are examples of the lanterns on the curved side, usually due to space constraints, but you should have them on the straight side wherever possible.
Not possible with C track of course, due to fixed lantern into the mould.
Offline PMPeter
#3 Posted : 24 November 2017 01:10:50(UTC)
PMPeter
I should have known that I had a 50:50 chance of getting it correct and that my odds were probably better if I followed the C track example, only to have Murphy strike and I made the wrong decision on my first 4 servo conversions. However, after posting this morning I found another German thread from around 2009 about the same issue (not Stummis) and the debate went on for quite a while with no final conclusion. However, an ex DB employee noted that there was no distinct regulation other than the lantern should be placed where it will be most visible by the engineer unless there was a space restriction. Another member insisted that it should always be on the straight. And the debate raged on.
So I decided since I am modelling left hand traffic I will place the lanterns on the right side when viewed entering the switch at the points end. That way I will be correct one way or the other 50% of the time. BigGrin
#4 Posted : 24 November 2017 03:00:23(UTC)
I also don't know which side, but I have some images of their insides and some other information on them at
https://cabin-layout.blo...urnout-lantern-7547.html
I see I placed one on the curve side... probably because I already had the turnout motor on the straight side...
Offline Markus Schild
#5 Posted : 24 November 2017 07:32:27(UTC)
Markus Schild
The majority, but not all of the lanterns I can see, are on the curved side.
Markus
#6 Posted : 24 November 2017 11:38:58(UTC)
And M. have (mostly) had the lantern on the curved side on M track and most K track so they have actually rather set the scene for the past 70-odd years.
Old habits.... Laugh
Edited by user 15 December 2017 02:08:43(UTC)  | Reason: Not specified
Offline applor
#7 Posted : 25 November 2017 02:20:44(UTC)
applor
That is a good example of turnouts on the curved side, definitely. I could also post hundreds of pictures showing them on the straight side.
In regards to marklin, when using solenoid motors on the standard (R3) turnouts you must install the motor on the straight side since it cannot fit around the curved side.
I would also say they used the curve side originally because it is less likely to get in the way and prevents the lantern sticking out on the straight side where it is more likely to get damaged.
Lastly in the Marklin instructions for the K track underboard mounting kits with lanterns they illustrate the lanterns to be installed on the straight side.
So again, yes there are plenty of examples of them on the curved side and that is fine to represent but if you have a choice I would advise the straight side of the turnout as it is far more common.
Offline Bones
#8 Posted : 15 December 2017 00:14:39(UTC)
Bones
I'd trust whatever a railway engineer say's over anyone else's opinion because a person's opinion isn't fact in law
The railways just like any other organisation will place point lanterns anywhere it chooses if it helps with railway operation's and avoids infringement on clearways
My father was a design engineer for the NSW goverment railways for over 35 years and would tell you the same thing because he would always see the way and works branch
engineer's who were responsible for carrying out this kind of work
Again anyones opinion is irrelevant if some one who has knowledge of and is qualified to speak about said subject has first hand knowledge otherwise you are telling these people they
are liar's which is defamation
Edited by user 15 December 2017 03:37:22(UTC)  | Reason: Typo
thanks 2 users liked this useful post by Bones
Offline michelvr
#9 Posted : 15 December 2017 01:00:24(UTC)
michelvr
This seems like a good discussion so hopefully when Marklin makes the NEW C track Wide Double Slip Switch they will have read these posts.
Offline Bones
#10 Posted : 05 September 2020 05:48:23(UTC)
Bones
Markus
I think they are mostly on the right because they show a lit arrow pointing towards the curve to give a visual indication of the points direction and if it's not in the right direction he can
pull the train up and stop
#11 Posted : 05 September 2020 13:08:28(UTC)
Actually. Märklin has always had the lanterns on the straight side on K-tracks, until the new versions which allows the user to choose ThumpUp
https://www.picclickimg.com/d/l400/pict/263940823873_/Marklin-Ho-2161-2164-Left-And-Right-K-Track.jpg
#12 Posted : 05 September 2020 13:16:34(UTC)
My father was a design engineer for the NSW goverment railways for over 35 years and would tell you the same thing because he would always see the way and works branch engineer's who were responsible for carrying out this kind of work
Your father again, eh?
This "deferred experience" that you try to present here doesn't really work. -And here is why; As per problematic overlap with cutting aluminium tubes, the knowledge and experience of ONE person cannot reliably be transferred to the community via a 3rd person, who POSSIBLY may have MISUNDERSTOOD something on the way. Just IMHO, of course.
#13 Posted : 05 September 2020 21:29:46(UTC)
I would suggest anybody can have an opinion on this site and it does not matter if right or wrong as it is just an opinion. An owner of a layout can place a lantern where it is most suitable for the the operation of the layout and the operator. Just my opinion.
thanks 4 users liked this useful post by David Dewar
Marklin 74470 Turnout Lanterns (Digital)
by Alex H 31/08/2023 14:27:08(UTC)
Found the culprit that snaps off all my C-Track turnout Lanterns (H0-scale)
by Dave Banks 05/07/2021 10:37:48(UTC)
Old K Track 2161 Turnout Lanterns (H0-scale)
by davo_vespa 15/04/2020 07:55:57(UTC)
Turnout lantern 74470 (Digital)
by Carlos 03/05/2015 01:50:44(UTC)
K83 and turnout lanterns (Digital)
by Paul59 30/12/2012 12:00:27(UTC)
Flickering LED turnout lanterns (Digital)
by SCWHIPPLE 26/12/2012 19:00:00(UTC)
RE620 #37321 & C-Track 3 -way turnout lantern (H0-scale)
by Dave Banks 19/06/2012 12:30:53(UTC)
Turnout lanterns (Model railroad wiring)
by drmarklin 05/06/2011 23:47:40(UTC)
Märklin 7547 turnout lantern set (Accessories reviews)
by DaleSchultz 06/03/2011 00:45:59(UTC)
Turnout Lantern Wiring (H0-scale)
by jocoyn 09/12/2006 04:06:46(UTC)
Wiring Turnout Lanterns (General MRR)
by nevw 22/10/2005 06:30:43(UTC)
Need OLD M-track turnout lanterns (H0-scale)
by mascagni 25/07/2002 19:02:47(UTC)
This page was generated in 0.852 seconds.
