Offline pjdlm
#1 Posted : 05 November 2002 00:15:09(UTC)
pjdlm
How do you open the new white marklin transformers?
A part is loose inside of mine and I need to open it up to perform the repair.
Do you need a special tool to open them or can it be done with common tools?
#2 Posted : 05 November 2002 01:23:25(UTC)
Have a look in the Digital forum section, the topic "Repair Interface 6050" thread tells you one way to do it. This procedure is "general" to all white Märklin control boxes...
Offline hqstu
#3 Posted : 07 November 2002 06:16:50(UTC)
hqstu
Failing that - a sledgehammer. Your rattle will then be masked by several others...
Stuart.
Stuart
Offline pjdlm
#4 Posted : 07 November 2002 20:14:52(UTC)
pjdlm
The drilling and screw method worked great. I found it was best to pry them out with one needle-nose plier under another one which would lift the screw.
I suppose you can re-insert these plugs and use them again.
Thanks again.
Marklin transformer 6627 (H0-scale)
by Jerry McLane 12/04/2025 21:38:56(UTC)
Marklin Transformer from 1960 (General MRR)
by Slinger 30/12/2022 15:12:15(UTC)
Marklin transformer 6611 (H0-scale)
by michaelh 13/10/2021 09:30:34(UTC)
Marklin Transformer Voltage (Small scale)
by zoooctan 04/05/2021 14:40:11(UTC)
Non marklin transformers (H0-scale)
by Traindutchman 23/04/2021 17:20:33(UTC)
Old Marklin Transformers (Collector's Corner general)
by GG1 Fan 24/03/2021 05:54:57(UTC)
Marklin Transformer (Digital)
by dboost 24/02/2021 00:51:34(UTC)
Marklin Transformer 67271 (Small scale)
by Carlos 20/03/2020 19:17:19(UTC)
Blue marklin transformer repair (H0-scale)
by Victor Almeida 01/11/2019 00:51:49(UTC)
Marklin Transformer No. 37547 A (General MRR)
by Albert Lind 19/01/2018 05:08:18(UTC)
Marklin transformers: 278A (16 VA) vs. 280A (30 VA) (General MRR)
by Albert Lind 04/01/2018 05:00:04(UTC)
Marklin Transformer 66185 (General MRR)
by sjbartels 14/10/2016 05:00:46(UTC)
Using a non marklin transformer or laptop PSU for CS 60215 (Digital)
by kpallund 12/11/2013 17:43:44(UTC)
Marklin Transformer 60055 (Digital)
by David1954 15/09/2013 02:35:04(UTC)
Marklin Transformer 60055 wire colors (Digital)
by Semaphore 30/06/2013 03:01:16(UTC)
Marklin Transformers (Digital)
by dandrikop 10/01/2007 13:20:04(UTC)
Marklin transformer controller 278A (H0-scale)
by steventrain 30/05/2005 00:29:19(UTC)
This page was generated in 0.356 seconds.
