Offline charles Sharpe
#1 Posted : 08 May 2007 21:53:13(UTC)
charles Sharpe
Hello. Please can help me I have just fitted a level crossing 74920 on c track. I have connected it up as per instructions and cut the track links 400mm back from the crossing but the barries go down when the train is only 25mm from the crossing.What have I done wrong
CHARLES SHARPE
Offline DasBert33
#2 Posted : 08 May 2007 22:03:06(UTC)
DasBert33
Did you connect your 400mm track between the lightgrey 'roadtrack' and the 2 other tracks supplied with the crossing, or outside? You just have to make the contact area longer but then the contact area has to be connected with the crossing...
Bert
#3 Posted : 09 May 2007 00:55:16(UTC)
charles Sharpe
Hello DasBert33. I am sorry to be so thick but I do not quite understand what you mean. No I did not connect the 400mm. I have the piece of gray track then one piece of short track with the blue arrows each side of that them 400mm of C track each side of that with the links cut as on page15 of the instruction booklet.
Many thanks Charles
CHARLES SHARPE
Offline Lars Westerlind
#4 Posted : 09 May 2007 01:03:21(UTC)
Lars Westerlind
The order should be:
1. One track with blue arrow where the barriers should go down.
2. Some tracks with cut connection between trails.
3. Grey track.
4. Optional some more track with cut connection
5. Second track with blue arrow.
The arrows must be at the same side, and the grey track must also be turned the right way. If you travel one direction only, 4 could be omitted, barriers may go up instantly when the last car has left.
/Lars
#5 Posted : 09 May 2007 20:23:30(UTC)
charles Sharpe
Hello Lars . Today I have Layed out my track as you suggested and put in the level crossing and all ok but when I lay out the other track going the opposite way ie two tracks one level crossing spanning both tracks the trains short circuit at blue marked track which is 400mm away from the L C. PLease can you help me . Many thanks Charles
CHARLES SHARPE
#6 Posted : 10 May 2007 00:33:07(UTC)
Lars Westerlind
Short circuits? First thing that comes into my mind is to check the tracks you've done the surgery. Any metal bent that now connects the rail with the center studs?
I guess inspection will show the error.
It could also be something wrong with power supply. If you run trains with MobileStation (just guessing) it's transformer should be used for the MobileStation only; you need an extra accessory transformer. This one feeds the level crossing with the yellow socket and cables; the transformers brown should be connected to the rail (outside the LC area).
/Lars
Offline Ayala
#7 Posted : 10 May 2007 13:41:46(UTC)
Ayala
check this link:
https://www.marklin-user...ault.aspx?g=posts&t=6678
It might help you.
Ayala
Lisbon, Portugal
Level Crossing for R1 curve (H0-scale)
by Alex H 11/03/2024 20:05:07(UTC)
Level crossings with a ramp (Model kits & layout details, kitbashing and such)
by 1borna 03/03/2024 20:59:54(UTC)
Hesitating Halfway: The 1959 Lauffen (Germany) Level Crossing Collision (Prototype)
by applor 12/10/2021 12:19:16(UTC)
Level Crossing 7054 (H0-scale)
by sharples 02/09/2019 01:18:22(UTC)
Motorise an Auhagen 11345 level crossing (H0-scale)
by LongHairedDavid 08/04/2019 17:21:28(UTC)
Woman hit by train at Brisbane level crossing (Prototype)
by ShannonN 28/02/2019 00:03:47(UTC)
Era III DB level crossings (Prototype)
by LongHairedDavid 23/01/2019 11:30:06(UTC)
Adjustment to Viessmann 5104 level crossing barrier arm (H0-scale)
by marklin61 25/06/2018 08:13:09(UTC)
wiring up my level crossing (Collector's Corner general)
by MalinAC 26/01/2017 16:02:39(UTC)
Marklin level crossing project (H0-scale)
by ixldoc 02/07/2016 05:59:35(UTC)
Marklin 74920 level crossing (General MRR)
by charles Sharpe 03/03/2014 14:20:19(UTC)
Marklin Level Crossing 7393 (Collector's Corner general)
by kumarvartak 22/12/2013 15:22:21(UTC)
7192 Electric Level Crossing Instructions please (Collector's Corner general)
Belarus cookee_nz 09/12/2012 22:44:34(UTC)
Level Crossing 7054. (Collector's Corner general)
by Ian555 06/08/2012 15:40:15(UTC)
Viessmann 5835 Level crossing (H0-scale)
by Fenderico82 20/04/2011 17:01:10(UTC)
Another level crossing collision (Prototype)
by Breitenfurt 20/08/2010 19:53:27(UTC)
Is this a peculiarly British problem or is it worldwide - level crossings (Prototype)
by Breitenfurt 23/06/2010 00:12:54(UTC)
Level Crossing (General MRR)
by bobhunt 05/03/2007 11:24:24(UTC)
Level Crossings (General MRR)
by bobhunt2 22/02/2007 07:03:58(UTC)
K-track level crossing (H0-scale)
Belarus rschaffr 11/12/2005 04:16:05(UTC)
Wiring for Level Crossing 74920 (H0-scale)
by banco 22/07/2005 14:23:31(UTC)
fitting level crossing on curved track (H0-scale)
by grattieri 14/11/2003 09:01:46(UTC)
This page was generated in 0.465 seconds.
