Offline PeterCambridge
#1 Posted : 16 June 2025 17:06:58(UTC)
PeterCambridge
My MAR 39353 sometimes fails to pick up any signal when I switch it on. It's just dead - no lights, nothing. If I can get it to start it runs perfectly and the functions all operate. The if I take it off the track and put it back, the whole thing is dead again. I've cleaned the wheels and slider and oiled it as per the instructions and tried fiddling with the addresses. Does anyone have any suggestions?
thanks 1 user liked this useful post by PeterCambridge
#2 Posted : 16 June 2025 21:32:31(UTC)
It's a C sine motor. Mine is not. It's the DB museum version. I have a Taurus with a C sine motor and until it's warmed up, it runs sporadic. Always has. When I nudge it from the sides it usually takes off again. This only happens when it hasn't been run in a long time. If only a day or two it runs perfect even cold.
#3 Posted : 16 June 2025 23:36:04(UTC)
Hi Peter
Your loco was designed in 2003, has a full size Sinus motor and a separate simplified sound module (I thinki).
The slider (Ski) is clipsed.
From what you describe it looks like a current pickup issue
I would check the following things:
- make sure the slider is straight and totally clean not only on the sliding surface but also between the spring blade and the ski itself I experienced sometimes issues there on older sliders. A bath in Noch RS24 may help (contact fluid is also OK).
- make sure the ski base is fully home and not partly clipsed thus causing bad contacts
- check the contact between each wheelset and the frame / decoder. Upside down on a foam bed, alligator clip on the slider bringing B and a loose wire bringing the O used to check each ground point (each wheel). If bad contacts there: a tiny drop of Märklin oil on each side of each axle, let the loco run for a while and wipe excess oil
- on older locos sometime one wire attached to moving parts like bogies, may be almost broken
On these locos in those years, often only one bogie was connected to ground while the other one was relying on metal to metal connection. An additional grounding of the ungrounded bogie may help using thin and flexible wire (similar to those wires with Märklin mLD3 / mSD3 decoders.
Cheers and bonne chance with your repair
Offline dickinsonj
#4 Posted : 17 June 2025 03:24:15(UTC)
Hi Peter
Good advice as always from Jean! When running down a current problem I often find it in the return side rather than the supply, and extra ground points can never hurt anything.
#5 Posted : 17 June 2025 10:53:57(UTC)
PeterCambridge
Many thanks, Jean. I'll try your suggestions.
ESU compatibility with new Trix/Marklin locomotives (Digital)
by JayMac 23/08/2024 04:23:38(UTC)
Identifying Marklin Locomotives and Passenger Cars (H0-scale)
by Alex H 20/08/2023 18:25:50(UTC)
Appropriate (prototypical) Marklin locomotive for Roco 44096 Coach Set?? (H0-scale)
by 5HorizonsRR 29/06/2023 02:52:53(UTC)
Marklin Locomotive Repair (H0-scale)
by Marklin newby 29/12/2020 09:38:28(UTC)
Identify a br41 steam 150 year Marklin locomotive (Small scale)
by pdiam2 13/12/2020 12:29:17(UTC)
Can anyone identify this Marklin locomotive? (H0-scale)
by pclancy 02/02/2020 23:43:28(UTC)
paint recomondation for marklin locomotive (Painting & Weathering)
by cmulder 05/01/2020 21:33:10(UTC)
Marklin locomotives power (General MRR)
by YannisB 23/05/2019 17:58:26(UTC)
Record price realized for Marklin locomotive (Collector's Corner general)
by kamstutz 01/03/2019 15:52:53(UTC)
Programming non Marklin locomotives on Mobile Station (Digital)
by Alko 07/12/2018 04:58:18(UTC)
RLR-01 Proses Powered Railer For Marklin Locomotives (News from Märklin and others)
by Harun 08/09/2018 05:35:09(UTC)
Marklin locomotive advertisements (General MRR)
by michelvr 28/02/2017 14:22:36(UTC)
Unusual Marklin locomotive set - Not in Koll's special catalog (H0-scale)
by owidgie 10/12/2015 22:46:59(UTC)
DC on Marklin locomotive (H0-scale)
by nomda777 15/03/2015 17:31:33(UTC)
New "fantasy" Competition to win a Marklin locomotive (General MRR)
by kimballthurlow 26/01/2015 10:12:05(UTC)
Types of decoders for Marklin locomotives (Digital)
by danmarklinman 01/08/2014 21:56:21(UTC)
Marklin Locomotive 3657 (Digital)
by David1954 26/08/2013 03:41:21(UTC)
Instructions for Marklin Locomotive 3048 (Collector's Corner general)
by kumarvartak 25/04/2013 12:38:33(UTC)
Marklin Locomotive 3048 Instructions Manual (General MRR)
by kumarvartak 20/02/2013 09:56:49(UTC)
TEE ? How many different Marklin locomotives are there ? (Collector's Corner general)
by 20-VOLT-AC 14/04/2012 14:10:04(UTC)
Marklin Locomotive running along side oo gauge. (H0-scale)
by A1A A1A 09/10/2011 00:50:33(UTC)
Marklin locomotive 83320 (BB22200 SNCF TUNNEL) new condition running slow.... ??? (H0-scale)
by marklinsncf 08/08/2011 04:13:55(UTC)
Marklin locomotives. Where are they now made? (General MRR)
by Kevin Weis 29/12/2010 05:20:36(UTC)
Cleaning vintage Marklin locomotive's motor (Collector's Corner general)
by DorothyMacaw 15/07/2010 20:02:03(UTC)
Marklin c81 decoder in Marklin locomotive (Digital)
by digitaltrainshort 30/06/2010 13:24:44(UTC)
Lubrication for Marklin locomotives (General MRR)
by KeithLForMarklin 02/01/2010 20:04:47(UTC)
Marklin Locomotive roundshed (Model kits & layout details, kitbashing and such)
by Nuno 20/11/2009 21:53:19(UTC)
Marklin locomotive packaging. (Small scale)
by Breitenfurt 22/09/2009 11:37:24(UTC)
Trix coaches compatible with Marklin Locomotives? (H0-scale)
by I_love_Marklin_37538 18/11/2008 12:28:03(UTC)
Do Marklin locomotives have a flywheel ? (H0-scale)
by Biased turkey 11/10/2006 13:23:12(UTC)
Marklin locomotive #3045 (H0-scale)
by artecar24 03/10/2003 16:07:39(UTC)
Marklin Locomotives Pricing (H0-scale)
by Thanos 21/10/2002 10:30:03(UTC)
This page was generated in 0.322 seconds.
