Offline rhfil
#1 Posted : 04 March 2023 19:59:10(UTC)
rhfil
I recently purchased a set of Palatinate cars and dug out a Marklin 37166 to pull them. But the loco was not working well - jerky, running hot, and kept losing power. I finally took the chassis off and discovered the inside was covered with a slightly sticky liquid. Apparently the previous owner had shipped it to me with smoke fluid in the smoker and it had leaked out in shipment and covered most of the inside. A bunch of Q-tips and isopropyl alcohol removed it all and now it runs normally. If you use smoke fluid don't allow it to get all over the inside of your loco.
Offline thing fish
#2 Posted : 04 March 2023 21:43:36(UTC)
thing fish
Turkey
Thanks for sharing.
I didn't know smoke fluid would become sticky; somehow I always thought it would vaporise. Maybe it came in contact with some other stuff ... maybe oil?
C.
thanks 2 users liked this useful post by thing fish
Offline rhfil
#3 Posted : 04 March 2023 21:54:41(UTC)
rhfil
I used "sticky" but it was just all over everything and seemed to originate under the smoke unit and then run down under the motor and decoder electronics. Not sure if someone used the wrong fluid but it did not seem to be around places that one would oil. I have heard that smoke fluid is kerosene which in volatility is between fuel oil and gasoline. It did not have an oily smell so maybe someone tried a different product.
thanks 3 users liked this useful post by rhfil
Offline thing fish
#4 Posted : 04 March 2023 22:22:10(UTC)
thing fish
Turkey
That sounds right ... I remember from my childhood; I used to fill the smoke gen with diluted detergent ... worked pretty good; anything that gives up smoke right? ThumpUp
Online bph
#5 Posted : 06 March 2023 19:25:19(UTC)
sound like someone overoiled it or used some really poor quality smoke oil.
Modern quality smoke oil should not behave like that, and some types are also used as a cleaning fluid.
eg this: Steam & Clean Dampfdestillat and this Steam & Clean Reinigungsdestillat (used by Marklin in their lasted cleaning instruction videos)
the only difference between the products is that the smoke oil/distillate contains some perfume to make it smell better.
smoke fluid (General MRR)
by Dreadnought 04/02/2023 19:02:19(UTC)
Smoke fluid (Digital)
by Normmeister 19/05/2022 03:09:16(UTC)
Smoke fluid help (General MRR)
by Puttputtmaru 17/05/2021 18:35:06(UTC)
Smoke Fluid (H0-scale)
by garben 16/12/2019 03:11:59(UTC)
ESU Smoke Fluid (H0-scale)
by bugsmasher 08/06/2018 07:20:31(UTC)
Smoke fluid question (General MRR)
by mike c 26/01/2018 00:51:09(UTC)
Smoke fluid - is it safe to use? (H0-scale)
by baggio 09/03/2016 05:51:21(UTC)
Prairie Pony, smoke fluid and other steam locos - how long does one dose last? (H0-scale)
by baggio 07/03/2016 03:42:35(UTC)
Smoke Fluid for Seuthe (H0-scale)
by Hoffmann 07/02/2014 04:41:39(UTC)
Marklin 02420 Smoke Fluid - Health/Saftey Info? (General MRR)
by BrandonVA 26/09/2013 15:46:05(UTC)
Overfilled a seuthe with smoke fluid. Now doesn't work (Digital)
by nelson77 01/02/2012 21:46:43(UTC)
Final decision_Marklin Smoke Fluid (H0-scale)
by FMS 17/01/2012 21:47:26(UTC)
Clean after smoke fluid? (General MRR)
by Mitropa 20/02/2010 19:24:39(UTC)
Märklin/Seuthe Smoke Fluid (H0-scale)
by Armando 01/08/2009 02:01:17(UTC)
Running steamers w/smoke unit w/o smoke fluid (H0-scale)
by Brakepad 18/03/2009 22:45:47(UTC)
Smoke fluid (H0-scale)
by Kenneth_H 18/11/2007 04:48:14(UTC)
Damages from smoke fluid? (General MRR)
by Armando 04/02/2005 06:18:20(UTC)
DIY Smoke Fluid (H0-scale)
by justin182 12/10/2003 20:33:58(UTC)
This page was generated in 0.386 seconds.
