Offline BenP
#1 Posted : 03 January 2023 15:14:17(UTC)
BenP
I have converted several vintage locs with original smoke units. I read that these units use 10-16V, but the digital voltage is 18+. The smoke units are connected to the digital decoder (here 60906, supporting original field magnets), so they are not always on.
How can I lower the voltage going to the smoke unit, so they do not overheat (as in glowing hot red)?
Ben
#2 Posted : 03 January 2023 15:20:35(UTC)
Wire in a resisitor between the decoder output and the unit as you would an led is what I would do.
#3 Posted : 03 January 2023 15:29:34(UTC)
You do not have to do anything of the smoke unit is wired between a function output and the loco frame. That's how Märklin wire the smoke units. The smoke unit will only receive part of the power and no further reduction is necessary.
If both poles of the smoke unit are connected to the decoder, then configure the decoder output to reduce the power going to the smoke unit.
#4 Posted : 03 January 2023 16:03:48(UTC)
Ben
Hi Ben
You don't need to IF you connect the smoke unit to one of the decoder outputs.
Why? Because, in most cases the return wire is the loco ground return, so only half-wave so the avarage current is lower.
THIS IS NOT TRUE when the smoke unit is connected directly to the digital current. In that case:
- smoke production and current is significantly larger
- life of the smoke unit is significantly reduced by larger-than-specified voltage (18 VAC instead of 12-14 VAC average voltage value in analog mode).
- in all cases, the smoke unit must be turned OFF in prolonged absence of smoke liquid.
In Digital one simple way is to insert a diode (anode to the smoke unit) 1N4001 to 1N4007 to reduce the current and behave EXACTLY as if driven by a decoder
You can further with a CS3 or CS2 configure the output as a smoke unit (pulsating and reduced intensity when stopped).
Be aware that a smoke unit needs additional current
- a regular smoke unit controlled by a decoder 80mA
- pulsated smoke unit 300 to 400 mA like on my BR06 (39662)
By comparison, a modern Märklin motor (CAN) needs 150mA to 180 mA
Sound and LEDs give no noticeable current (1 mA or less)
So if you plan to have many smoke units, be sure to have plenty of power available.
Edited by user 04 January 2023 11:29:49(UTC)  | Reason: Not specified
#5 Posted : 03 January 2023 17:52:17(UTC)
Ok, I thought he meant it was glowing red hot!
Smoke units (H0-scale)
by Keim 30/05/2024 01:05:28(UTC)
Ac analog smoke units (H0-scale)
by Keim 09/03/2024 02:10:54(UTC)
BR53 Mallet & smoke unit (H0-scale)
by cintrans 03/03/2024 21:19:29(UTC)
Smoke units - can you tell the difference? (General MRR)
by ocram63_uk 21/01/2023 17:14:26(UTC)
Marklin 55082 SCNF 241 65 A Smoke Unit (Big scale)
by BurritoJoe 22/12/2022 13:17:35(UTC)
KM1 01 180 1 Gauge loco Smoke Unit repair (Big scale)
by Bigdaddynz 29/12/2020 05:59:05(UTC)
Connecting 2 x 7226 Smoke Unit in Borsig (H0-scale)
by Johnvr 05/11/2019 16:31:02(UTC)
Smoke Unit Issue (H0-scale)
by madhu.gn.71 04/11/2019 03:41:36(UTC)
eCig fluid in smoke units (General MRR)
by ocram63_uk 10/03/2019 14:16:06(UTC)
Which Smoke unit for 37195? (General MRR)
by Melbourne marklin 07/02/2019 13:21:50(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
Adding Wires to Seuthe Smoke Units (General MRR)
by skeeterbuck 03/11/2018 17:21:56(UTC)
Smoke units and there use (H0-scale)
by danmarklinman 27/12/2017 23:15:25(UTC)
Why Do Smoke Units Fail? (General MRR)
by SteamNut 26/10/2017 22:12:54(UTC)
3046/3047 BR 44 Digital Conversion- Keeping the smoke unit? (Digital)
by 5HorizonsRR 20/10/2017 02:25:14(UTC)
smoke units for Lady C (Württembergerin) locos? (H0-scale)
by DaleSchultz 11/03/2017 04:50:53(UTC)
Fitting smoke unit to 37085 - help (General MRR)
by twmarklinfan 28/02/2017 12:51:01(UTC)
3102 with 6090 - Smoke Units and Lights not working anymore (General MRR)
by mb300e4m 27/02/2017 21:39:06(UTC)
my 3047 Loc runs slower as soon as I enable the smoke unit (Digital)
by acwertheim 03/07/2016 19:33:06(UTC)
Need to set my smoke unit 7226 to be always on (Digital)
by acwertheim 14/06/2016 18:29:21(UTC)
LokSound V4 M4 - How to control the flow of smoke unit (Digital)
by Armando 28/03/2016 01:17:08(UTC)
Smoke unit in Marklin 3099 (General MRR)
by joyofmarklin 09/03/2016 22:29:37(UTC)
Marklin 7226 & Marklin 72270 Smoke Units (General MRR)
by skeeterbuck 20/01/2016 19:36:23(UTC)
Problem while installing smoke unit on 36243 (H0-scale)
by madhu.gn.71 01/09/2015 10:51:26(UTC)
smoke unit fitted to S2/6... (H0-scale)
by Joseph Meiring 25/06/2015 21:28:54(UTC)
Adding a Seuthe Smoke Unit to a Trix 2-8-2 (Digital)
by trainstamp 17/04/2015 20:01:15(UTC)
Help With Smoke Unit (H0-scale)
by SteamNut 28/01/2014 23:22:53(UTC)
Trouble with smoke unit (H0-scale)
by SteamNut 28/09/2013 14:43:56(UTC)
Smoke Units (H0-scale)
by SteamNut 21/09/2013 02:08:43(UTC)
7226 Smoke Units - does anybody try to maintain these ? (H0-scale)
by Johnvr 07/09/2013 12:51:23(UTC)
Smoke unit 7226 for 3047 Loc? (H0-scale)
by acwertheim 04/07/2013 23:29:05(UTC)
can't turn off smoke unit. is that bad? (Digital)
by obxbill 30/01/2013 02:38:03(UTC)
39103 BR 01 1057 smoke unit output not working (no voltage) (Digital)
by Janne75 23/01/2013 18:14:30(UTC)
Help with smoke unit for M BR 94 37160 (H0-scale)
by Torstein 25/12/2012 16:37:47(UTC)
Strange smoke unit behaviour (General MRR)
by sebastian 01/01/2012 22:17:30(UTC)
Need Advice On 72270 Smoke Unit Operation (H0-scale)
by 5HorizonsRR 24/11/2011 03:25:55(UTC)
smoke unit for 39022? (General MRR)
by Joseph Meiring 30/10/2011 17:01:20(UTC)
Installing the tapered smoke unit in BR 55 (H0-scale)
by Armando 14/10/2011 21:24:55(UTC)
Smoke Units identifications (H0-scale)
by ac jacko 18/06/2011 04:42:10(UTC)
Smoke unit not working (Digital)
by REUBEN 10/06/2011 21:44:49(UTC)
Marklin 3311 smoke unit questons (H0-scale)
by Kevin Weis 10/02/2011 02:27:27(UTC)
37193 and Smoke Unit (H0-scale)
by I_love_Marklin_37538 03/01/2010 10:07:55(UTC)
Running steamers w/smoke unit w/o smoke fluid (H0-scale)
by Brakepad 18/03/2009 22:45:47(UTC)
smoke units for dummies (H0-scale)
by dlarson 22/05/2008 19:20:01(UTC)
Adding a Smoke Unit (Digital)
by elsleuth 24/04/2008 02:06:21(UTC)
smoke units for buildings (Model kits & layout details, kitbashing and such)
by prc 04/01/2006 05:04:47(UTC)
smoke unit vs decoder (Digital)
by HvR 04/07/2005 14:49:36(UTC)
Busted Smoke Unit (Big scale)
by xxup 19/12/2004 09:21:03(UTC)
Smoke unit retrofit (H0-scale)
by Tamrac 08/11/2003 19:06:23(UTC)
Smoke Unit (General MRR)
by argal 25/02/2003 10:07:21(UTC)
This page was generated in 0.340 seconds.
