Offline QQQ1970
#1 Posted : 24 March 2021 04:47:55(UTC)
QQQ1970
Can I place a circuit track inside a contact track section?
Offline PeFu
#2 Posted : 24 March 2021 06:58:02(UTC)
PeFu
As a matter of physics, yes, but this could cause challenges regarding logics.
What tracks do you intend to use (K/M/C? Item numbers?) and why would you like to do this?
Smile
Offline QQQ1970
#3 Posted : 24 March 2021 10:30:33(UTC)
QQQ1970
C track. I am looking to do this due to space limitation.
Offline PeFu
#4 Posted : 24 March 2021 14:40:14(UTC)
PeFu
Still don’t understand why you would need two feedback outputs from one single track location?
Offline QQQ1970
#5 Posted : 24 March 2021 14:55:52(UTC)
QQQ1970
I inherit a layout. It is single track station with exit signals at both directions. I want a circuit track to trigger signals at both directions. The contact track is already in place for switching turnouts.
Offline PeFu
#6 Posted : 24 March 2021 15:25:32(UTC)
PeFu
Why don’t you use the same contact track for both switches and signals?
Offline QQQ1970
#7 Posted : 24 March 2021 15:44:31(UTC)
QQQ1970
Can I set separate events for eastbound and westbound trains running over the same contact tracks?
Offline PeFu
#8 Posted : 24 March 2021 18:33:13(UTC)
PeFu
The method of doing that depends on how you control your layout. Analogue? Digital? Using a mobile station? Using a central station? Using a central station AND a PC software?
Circuit tracks (Digital)
by Bones 13/12/2023 02:07:12(UTC)
Marklin Circuit Track and Train Controller (Model railroad software)
by garben 20/06/2023 17:17:09(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
Circuit Track 24194 (General MRR)
by Vaji2021 15/08/2021 15:37:40(UTC)
Help - Problem with Event/dragging circuit track (Digital)
by petestra 26/03/2021 14:58:01(UTC)
Circuit track track diagram (Digital)
by QQQ1970 01/12/2020 00:17:25(UTC)
24994 circuit track (H0-scale)
by Timnomads 10/11/2020 12:33:35(UTC)
Circuit track with digital decoder? (H0-scale)
by SBB_CFF_FFS 03/01/2020 02:59:15(UTC)
Signal light on a M84 ,feedback from circuit track (Digital)
by geir 02/03/2019 23:29:37(UTC)
Circuit track vs reed switch (H0-scale)
by Jack_Peters 10/02/2019 23:43:23(UTC)
circuit track triggers (General MRR)
by ae66green 05/02/2018 23:07:56(UTC)
Tracking occupancy with TrainController and CS2/circuit track/s88 (Model railroad software)
by Rdsmarklin 25/10/2017 16:43:18(UTC)
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
Adjusting the circuit track 5107 (H0-scale)
by Z-nerd 30/12/2016 23:59:24(UTC)
Signal Module 72442 and circuit track (Digital)
by nofalal 30/05/2015 02:15:32(UTC)
Circuit Tracks (Digital)
by David1954 11/09/2013 00:45:23(UTC)
Bypass with circuit track (Digital)
by David1954 30/08/2013 11:40:33(UTC)
How do circuit track work with S88? (Digital)
by Jvt1 12/08/2013 04:15:59(UTC)
Finicky, Sticky Circuit Tracks ? Fixed? (Digital)
by Laxman 02/02/2013 05:18:32(UTC)
hints for using circuit track 24994 and contact track 24995 (Digital)
by sikardon 11/08/2012 16:08:35(UTC)
False alarms with circuit tracks (Digital)
by Semaphore 15/03/2012 23:25:11(UTC)
Help with Circuit Track Wiring (Digital)
by Laxman 17/02/2012 18:28:23(UTC)
Circuit track (24994 and 24194) (Digital)
by rcartwri 17/08/2011 06:12:58(UTC)
Circuit Track problem (General MRR)
by Pabbi 03/06/2011 10:21:09(UTC)
What's better- Circuit track or isolated section? (Digital)
by Myowngod 19/03/2009 04:53:57(UTC)
Circuit Track (K Track) (General MRR)
by dpg001 19/10/2008 23:07:11(UTC)
Contact duration of the 24994 circuit track (H0-scale)
by efel 13/08/2008 12:28:42(UTC)
24194 circuit Tracks. (Digital)
by charles Sharpe 10/07/2008 23:38:11(UTC)
Marklin 76XXX series signals and circuit track (Digital)
by jimbrauer 31/03/2008 06:49:45(UTC)
Circuit Tracks in 1 Gauge? (Big scale)
by sprogger 07/03/2008 07:43:11(UTC)
circuit tracks and ms (Digital)
by db216 09/12/2007 07:16:32(UTC)
Newbie question regarding Circuit Track...solved! (H0-scale)
by ulf999 03/10/2005 13:47:21(UTC)
Using Circuit tracks (General MRR)
by malsnake 02/12/2004 23:32:03(UTC)
This page was generated in 0.330 seconds.
