z21
Offline morsing
#1 Posted : 05 February 2019 12:12:46(UTC)
morsing
I can't justify a CS2/3 - sadly. So looking at z21 but not quite sure what I need.
- Want to be able to computer control
- Want handset(s) for simultaneous manual control
So,
- Am I correct that Multimaus is a handset for z21?
- Is it wireless? Or is that only Z21?
- Can I connect a computer to z21?
- I does it do MFX?
Thanks, no clear guidance found anywhere so far.
Marklin C-track + CS3+
Offline mbarreto
#2 Posted: : 05 February 2019 13:18:55(UTC)
mbarreto
Views messages in topic : 1,341
So,
- I does it do MFX?
Roco information on Z21: https://www.roco.cc/en/p...0-006001-0/products.html
Here it is not the best place to ask about Z21, and as such it is beter you think in a CS or Ecos ;) as they both have mfx.
Z21 is only DCC and MM, no mfx and much less mfx+. Z21 only has Railcom in opposition to Ecos that also have Railcom+
As you can read in the pages with links in the page I stated above, there are 2 Lokmaus, one wireless and one wired.
In youtube you can find sevral videos with rocrail and z21.
I don't know if the Viessman controller has mfx, but I think not.
Miguel
Mostly Märklin H0.
Offline morsing
#3 Posted : 05 February 2019 14:23:02(UTC)
morsing
Thanks, but you linked to the Z21, not the z21. And the similar names makes it very difficult to Google or search on Youtube, and even Roco's website is confusing...
I think, from Roco's website, only Z21 can use wireless controllers.
Just looked up the Ecos and it's comparable in price to the CS.
Offline mbarreto
#4 Posted : 05 February 2019 14:36:18(UTC)
mbarreto
Probably you are refering to the z21 Start...:
https://www.z21.eu/en/products/z21start
Not much information indeed, but that is a good hint to choose something different ;)
Miguel
Mostly Märklin H0.
Offline morsing
#5 Posted : 05 February 2019 14:38:34(UTC)
morsing
Which I can't afford... So, I'll keep running my trains with my mobile stations then.
#6 Posted : 05 February 2019 14:57:47(UTC)
No.
They have three products:
"z21 start" requires the WLAN package 10814 to use WLAN controllers (WLANMAUS or smartphone with app).
"z21" supports WLAN out of the box.
"Z21" ditto.
The English website lacks many pieces of information you can find on the German pages.
Their product naming scheme is neither "google-friendly" nor "user-friendly".
Offline kgsjoqvist
#7 Posted : 05 February 2019 15:31:35(UTC)
kgsjoqvist
No.
"Z21" ditto.
I beleive they only sell the white "z21 start" and the black "Z21" now. If you buy the z21 start you have to calculate at least with the price for WLAN package, and probably a LokMaus as well. I wouldn´t be comfortable to have my smartphone as the only possible controller...
The black Z21 has become very popular among 2-rail users, because it supports many different bus connections to other devices. But for 3-rail users it has one big disadvantage - no mfx support. This means you will have to run your mfx locos with DCC (if the decoder has DCC inside) or if it is an older mfx decoder with MM protocol (4+1 functions, 28 speedsteps).
If you are on a tight budget but still want to control your locos by computer, I would suggest you take a look at "CC-Schnitte" that costs 139€ and connects to your computer + one of the trackbox connectors for Mobile Station. So you can use a Mobile Station for manual control and CC-Schnitte as a computer interface. It can also be used without the Mobile Station, but then you still need a track box.
thanks 2 users liked this useful post by kgsjoqvist
Offline ChrisWV10
#8 Posted : 05 February 2019 21:14:57(UTC)
ChrisWV10
The black Z21 (capital Z) has separate programming track output, adjustable voltage, loconet connector and sniffer port. It’s supplied with a wireless router and the network connection is unlocked for connection to the supplied router. You can use your own, but I’d recommend using the supplied one as it’s all preconfigured. Using your own WiFi is only for the very network savvy.
The white z21 (small z) has no separate programming track, no adjustable voltage, no loconet and no sniffer port. It usually is supplied with a wired multimaus and the network port is locked in software. You can buy the unlock code (see fleischmann website) To use your own router or buy the router with the unlock code.
Both accept wired Multimaus, 2 xbus ports on the front of the white.
For the wireless multimaus you need a wireless setup either the black Z21 package or buy the separate router for a white z21 starter.
The app is a free download from Apple or Android App Store. It’s not available on Amazon for Fire tablets.
C. :)
thanks 1 user liked this useful post by ChrisWV10
Offline morsing
#9 Posted : 07 February 2019 16:07:32(UTC)
morsing
Some things to consider. CC-schnitte does look like a good option, but I have been unable to find a price or a place to buy it.
Offline costing
#10 Posted : 08 February 2019 00:08:58(UTC)
costing
Since you are willing to jump off the mfx wagon I suggest JMRI on Raspberry Pi and DCC++. The whole package will set you back between 30 and 50 ($, EUR, whatever), depending on the RPi model you get.
WiFi included for free. As many throttles as mobile devices you have around. Separate programming track. Graphical interface as large as your TV. Remote desktop connection if you don't have/want to connect to the TV.
If you want to test it out just run JMRI on your computer with the DCC++ Arduino on USB. You can experiment with all the above for a few bucks only and if you are not happy with the solution move along to any of the above brands.
.costin
Offline costing
#11 Posted : 08 February 2019 08:17:21(UTC)
costing
And to illustrate the programming and control panels of JMRI here is a screenshot of it with one of the locos. I can't imagine programming CVs without it, especially in complex decoders like ESU's.
.costin
Z21 with Marklin (Digital)
by Giovanni Carboni 27/12/2024 17:18:35(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
Operating Marklin locos and cars with Roco Z21 (H0-scale)
by husafreak 02/06/2020 05:43:59(UTC)
New Marklin VS TRIX choice, to be used with Z21 (H0-scale)
by husafreak 12/04/2020 20:16:28(UTC)
Z21 (Digital)
by Wasp 25/06/2019 08:24:11(UTC)
Z21 is not compatable with Marklin BR042 Spur 1 (art. no. 55424) (Digital)
by dogjumpjump 09/11/2017 06:34:15(UTC)
Is the Z21 start controller compatible with m83 (60831) decoders (Digital)
by BR221 31/08/2017 06:26:52(UTC)
z21 (Digital)
by Pablo Mardones 05/09/2016 18:13:46(UTC)
Roco Z21 Digital Control System for/including Ipad capability- anyone have experience? (Digital)
by 5HorizonsRR 21/10/2015 21:04:10(UTC)
Z21 and MFX (Digital)
by Sparrow 23/08/2015 23:52:36(UTC)
Controlling 36502 HO Loco With Roco Z21 (Digital)
by IsItDigitalAlready? 24/04/2015 19:55:27(UTC)
Z21 and SmartRail from Roco/Fleischmann - my first impressions (Digital components and Software reviews)
by plavnostruev 26/02/2013 20:44:33(UTC)
Z21 and SmartRail from Roco/Fleischmann - first impressions (Accessories reviews)
by plavnostruev 26/02/2013 20:33:27(UTC)
Roco Z21 (Digital)
by Darren W 04/03/2012 17:50:43(UTC)
This page was generated in 0.721 seconds.
