Offline morsing
#1 Posted : 18 October 2018 21:44:59(UTC)
morsing
So, having fitted current conducting couplers to some carriages, it appears to can't hook them up to normal couplers... Is that right? It certainly wouldn't hook onto the loco at all, with difficulty to another carriage.
It seem the protruding pin prevents this.
Marklin C-track + CS3+
Offline Drongo
#2 Posted : 19 October 2018 00:42:03(UTC)
Drongo
IMHO The current conducting couplers are extremely difficult to use. I try to avoid them.
#3 Posted : 19 October 2018 08:43:01(UTC)
Originally Posted by: morsing Go to Quoted Post
Is that right?
Is that question about H0 gauge? Is that question about Märklin couplers?
There are many different couplers sold by Märklin and not all are fully compatible with all others. There are different versions of current-conducting couplers.
Märklin coach sets usually have normal close couplers at the outer ends to hook them up to locomotives, with current-conducting couplers between the coaches. This avoids mixing different types of couplers.
#4 Posted : 19 October 2018 21:55:25(UTC)
I'll echo H0's questions. If you are asking about H0 Märklin current conduction close couplers - the couple well with other conducting close couplers.
Close couplers (current conducting or not) can have issues coupling with non-close couples, such as the relex couplers. If you are trying to couple with non-Märklin couplers thats an additional level of difficulty. Generally couplers work well with others of the same make/type, and tricky if mixing/matching.
If you are trying (I'm taking a guess here) to couple Märklin conducting close couplers to a Märklin telex coupling (due to the reference of the "pin" and it being on a locomotive) - that is another issue. Not sure what is meant by "normal coupler".
So if you can provide some clarity as to which coupler is on the loco and which is on the car, and the scale (H0 vs others) that would help.
Offline morsing
#5 Posted : 19 October 2018 22:42:22(UTC)
morsing
The protruding copper pin at the front of the coupler in the picture below, prevents it getting close enough to a non-conducting coupler to lock in place.
This isn't exactly made clear in the description of these. It just means you have to leave the consist with one non-conducting coupler (at either end).
The loco I tried this on (but can't see this being loco dependent) is a Marklin 39674.
Offline madhu.gn.71
#6 Posted : 21 November 2019 03:39:10(UTC)
madhu.gn.71
India
@morsing, that is true as per my experience. Last year I purchased 3 wagons from Rheingold set and I too had similar query as I was not able to couple these conducting couplers with regular coupler of my BR23. Later my friend suggested to replace the last wagon's conducting coupler with a regular one.
thanks 2 users liked this useful post by madhu.gn.71
Offline costing
#7 Posted : 21 November 2019 19:11:37(UTC)
costing
I confirm that you should only use these couplers between themselves, the spring is too long and prevents coupling with a "regular" one. Fortunately the design is good and you can easily pull them out when you have to place / replace them.
Another type of couplers I've used is the ESU (http://www.esu.eu/en/products/accessories/kupplungen/current-carrying-coupler/). These are compatible with regular couplers, but the two springs are more fragile than Marklin's and easily bend and get out of reach of each other. And they are permanently connected to the wires. While it is cool to have a single wagon equipped with current pickups I find the Marklin ones more reliable overall.
thanks 2 users liked this useful post by costing
Offline dominator
#8 Posted : 21 November 2019 22:00:38(UTC)
dominator
If you coupled those couplers with non conducting ones, would that not cause a short. If that's the case, then they are designed to couple only with each other for safety reasons. Would you not think!!!!!!!!
Dereck
Northland. NZ
Offline costing
#9 Posted : 21 November 2019 22:48:36(UTC)
costing
The non conducting ones are usually in plastic pockets or their body is made of plastic, apart from the hook. So there is nothing to connect you to the rails. At least in the models I have this is the case.
thanks 4 users liked this useful post by costing
Offline dominator
#10 Posted : 21 November 2019 23:11:36(UTC)
dominator
Ah, I had in mind the really old stuff. I forgot about the newer items.
Dereck
Northland. NZ
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Voltage in Current Conducting Couplers? (H0-scale)
by waltklatt 10/05/2018 16:19:47(UTC)
New Märklin current conducting couplers (H0-scale)
by Minok 04/10/2017 23:43:34(UTC)
Current Conducting Couplers -- Installation Help (General MRR)
by AJH4 03/03/2017 01:06:30(UTC)
Marklin Locos with Current Conducting Couplers (H0-scale)
by xxup 13/04/2016 07:42:43(UTC)
Coach not prepared for current conducting couplers? No problem. (H0-scale)
by biedmatt 30/05/2015 23:30:51(UTC)
HO current conducting couplers (H0-scale)
by rhfil 23/09/2014 17:20:40(UTC)
RTS Current Conducting Couplers (News from Märklin and others)
by Armando 14/03/2014 23:28:43(UTC)
Current Conducting Couplers 43873 (H0-scale)
by Harvey 29/12/2013 19:38:53(UTC)
Installing 72021 current conducting couplers (Collector's Corner general)
by Bob 01/05/2011 15:11:44(UTC)
2 Pole Current Conducting Couplers (AGAIN) (H0-scale)
by nevw 08/03/2010 06:09:34(UTC)
Can I use current conducting couplers on a loco? (Digital)
by sebastian 31/05/2007 22:06:58(UTC)
Viessmann vs RTS current conducting couplers (H0-scale)
by efel 10/03/2007 19:44:10(UTC)
by applor 13/02/2005 12:17:56(UTC)
Roco Current Conducting Couplers (H0-scale)
by tnx jake 09/02/2003 17:25:36(UTC)
Current conducting couplers from RTK-Elektronik? (H0-scale)
by Hans_Dietrich 10/01/2003 18:25:41(UTC)
This page was generated in 0.474 seconds.
