Offline kyle
#1 Posted : 23 March 2017 02:05:07(UTC)
kyle
Hi, I'm hoping to get some insight on restoration of several 800 series loco's. I have a sk 800 ca46', two rsm 800's, a rs 800, and a T 800 as well as many vintage wagons I would like to do some restoration work on. I am currently focusing on the sk 800 which I have all apart. I would say I got it in fair shape. There does not appear to be any stress cracks in the engine or frame and the tender is in decent shape as well. The only problem when I got was that the reverse unit/housing was cracked. I am going to replace it, but for now I took it all apart, cleaned it up and super glued the cracked reverse unit frame. I know what you are thinking, but it came out very nice and should hold up for a bit. So, I have basically stripped down the loco to bare parts, further then the picture shows, and cleaned up the frame when I thought how nice it would be to have a fresh coat of paint on the frame and wheels. I'm not sure if this will effect value, but my personal goal is to clean this loco up and have it in working order. So, i'm not sure how to pull the wheels off. I did a search last night which led me to a post on this forum which provided a link to a tool that clamps around the wheels and has a pin that can drive out the wheel pin. What are your thoughts? are there other ways to accomplish this without causing damage. This trick would be highly applicable with the rest of my fleet as well. Also, what are your thoughts on paint. I'd like to repaint the frame and wheel spokes. Is there a color reference where I can match original reds and blacks. Next, my rsm800 has some bad wheels. the rest of the engine is in great shape. Any resources for acquiring some replacements would be helpful. I'm sure I will have more questions. Thanks in advance.BigGrin 20170127_161512.jpg
#2 Posted : 23 March 2017 08:24:50(UTC)
I've been working in that field of Märklin restorations for a long long time
This is not the only place, but I've worked with these people for over 30 years...
Now that they have an online store life is relatively easy.
Ritter restauration
As for tools, I got 95% of what I needed from these people
Fohrmann Werzeuge
Hope this helps
Offline ktsolias
#3 Posted : 23 March 2017 08:39:24(UTC)
ktsolias
Hi Kyle
Jacques gave you the links for the best suppliers I think. I use to buy from them to.
The real problem is if you know how to dismalt the wheels (relatively easy with the right extractor) and most difficult how to press the wheels again and of course quartering them!!!!
I don't recommend to try it for the first time in a valuable loco.
If you want to spent the money to buy the tools (I don't think that is justified for 1 or 2 locos, do it first in some cheep model to get experience and then to and xx800
Costas
thanks 3 users liked this useful post by ktsolias
Offline CCS800KrokHunter3
#4 Posted : 23 March 2017 15:16:22(UTC)
CCS800KrokHunter3
Personally I have restored dozens of SK 800s without any special tools. I remove the wheels by firmly holding one side in my hands then gently twisting the other wheel until it becomes loose. A single drop of oil on the axle from the outside sometimes helps. But don't get any oil on the wheel itself otherwise it will be slippery and hard to hold with your hand. As far as repainting that's up to you but from what I can see the wheels and frame appear to be in good shape - even the best original ones look like this. The SK is one of the more difficult locos to restore to get running. The wheels must be aligned perfectly especially when adding the linkages it's easy for the linkage to jam movement.
We'll be hear if you need help! But as you said anything that causes pressure has the potential to crack something so always remember that!
Best wishes,
Paul
thanks 2 users liked this useful post by CCS800KrokHunter3
Offline GNAM
#5 Posted : 24 March 2017 08:43:39(UTC)
GNAM
There is also TTN Shop. Sometimes cheaper than Ritter. Mind, the paints have not the Märklin aspect.
GNAM
thanks 2 users liked this useful post by GNAM
Offline MalinAC
#6 Posted : 24 March 2017 16:04:57(UTC)
MalinAC
Ireland
I was just comparing prices for TTN Shop and Ritter. Front and rear truck complete and couplers for ES 800 were cheaper from Ritter.My order just came and they look very good to me. Ritters are reproduction units. Dont know about TTN . The trucks were 50% cheaper at Ritter and couplers a little bit. TTN have a nice site and they have some boxes as well. Just my 5 cents worth. Take care EddieBigGrin
thanks 1 user liked this useful post by MalinAC
Märklin 8910 Toporama Restoration (Small scale)
by Fluegelmeister 25/12/2021 02:46:20(UTC)
Marklin 8910 Toporama Restoration Table Done (Small scale)
by Fluegelmeister 25/07/2021 07:36:59(UTC)
Marklin 3011 Restoration (Collector's Corner general)
by skeeterbuck 14/05/2021 18:27:13(UTC)
Swiss Federal Loco 3050 Restoration (Painting & Weathering)
by PJ Lepard 20/03/2021 22:16:02(UTC)
Marklin Toporama 8910 Restoration Video (Small scale)
by Fluegelmeister 21/05/2020 05:07:16(UTC)
Marklin Toporama Restoration Latest Video #12 (Small scale)
by Fluegelmeister 11/05/2020 06:37:17(UTC)
Marklin Restoration Video: Control Panel design (Small scale)
by Fluegelmeister 27/04/2020 01:05:11(UTC)
Marklin Z-Scale Restoration Latest Vid. (Small scale)
by Fluegelmeister 19/04/2020 23:36:00(UTC)
Marklin Toporama Restoration - Final Track lay-down (Small scale)
by Fluegelmeister 05/04/2020 18:56:33(UTC)
Marklin 8910 Toporama restoration video (Small scale)
by Fluegelmeister 29/03/2020 21:49:28(UTC)
New Toporama Restoration Video (Small scale)
by Fluegelmeister 23/03/2020 05:01:17(UTC)
Marklin Toporama Restoration, Applying Track (Small scale)
by Fluegelmeister 13/01/2020 04:43:34(UTC)
Marklin Toporama Restoration: Costs and Value (Small scale)
by Fluegelmeister 24/12/2019 15:28:32(UTC)
by Fluegelmeister 08/12/2019 05:25:19(UTC)
Union Pacific Steam Shop Tour and Big Boy 4014 Restoration (Videos)
by ShannonN 15/01/2019 04:38:22(UTC)
Help/Advice needed for restoration (Steam engines)
by johnmarklin 02/10/2018 20:02:47(UTC)
Marklin O Gauge Collection HR 70 12920 + TW + Restoration (Collector's Corner general)
by CCS800KrokHunter3 31/01/2018 02:24:30(UTC)
3053 restoration (H0-scale)
by dominator 18/07/2017 23:24:21(UTC)
HO scale restoration. (General MRR)
by Kim Stevenson 08/03/2017 13:18:05(UTC)
Märklin 3024 little restoration (Collector's Corner general)
by TrainIride 10/12/2016 11:04:00(UTC)
3048 BR 01 restoration (H0-scale)
by ktsolias 23/11/2016 10:58:55(UTC)
Restoration of 469 Signal House (Collector's Corner general)
by Tiki734 16/09/2016 13:16:12(UTC)
346 restoration (H0-scale)
by bodger 28/04/2015 08:36:00(UTC)
Marklin 3015 Restoration Project (Collector's Corner general)
by johnmarklin 17/01/2015 19:27:01(UTC)
"Restoration Corner" Questions on Original Marklin Factory Paint and Electrical (Painting & Weathering)
by 5HorizonsRR 13/08/2014 22:57:08(UTC)
Advice sought on 3034 restoration (Collector's Corner general)
by Anton70 22/12/2013 00:46:28(UTC)
Big Boy 4014 restoration update. (Prototype)
by NS1200 10/04/2013 20:48:00(UTC)
painting restoration SLR 700 and HR 800 (Painting & Weathering)
by thiesedenys 02/05/2012 23:26:10(UTC)
Ritter Restorations GERMANY (Collector's Corner general)
by 20-VOLT-AC 04/02/2012 11:08:51(UTC)
Marklin CCS 800 Restoration & Operation (Collector's Corner general)
by CCS800KrokHunter3 07/06/2011 02:56:07(UTC)
SNCF 9200 restoration 3038 (Collector's Corner general)
by dan67millie 21/04/2011 09:37:37(UTC)
351 roof restoration, last pictures (Collector's Corner general)
by jvuye 21/03/2011 14:41:34(UTC)
3038 SNCF BB9200 "mini" restoration-painting update (Collector's Corner general)
by Brakepad 20/02/2011 11:57:01(UTC)
4015 restoration (Collector's Corner general)
by hennabm 19/02/2011 20:09:40(UTC)
SK 800 tender restoration (challenge) (Collector's Corner general)
by CCS800KrokHunter3 30/01/2011 03:56:24(UTC)
TT 800 + SK 800 restoration (Collector's Corner general)
by CCS800KrokHunter3 08/04/2010 02:39:13(UTC)
TM800 restoration/modernization (General MRR)
by FMS 11/07/2009 14:42:08(UTC)
Märklin ST 800 restoration (Collector's Corner general)
by Bayer 01/07/2009 17:31:38(UTC)
3021 restoration (Collector's Corner general)
by obxbill 27/06/2009 20:27:30(UTC)
3045 Restoration (Collector's Corner general)
by jetavdk 03/03/2009 08:48:11(UTC)
Marklin - Restoration (Collector's Corner general)
by CCS800KrokHunter3 26/08/2007 07:59:59(UTC)
Restoration of the Adler in H0 (H0-scale)
by Rocca 17/12/2005 20:21:28(UTC)
Restoration of roofs (Painting & Weathering)
by Gregor 22/08/2005 23:30:52(UTC)
Marklin rebuild /restoration service (H0-scale)
by Dave 25/11/2004 01:46:49(UTC)
Restoration on an old BR 80 (H0-scale)
by JCami 25/05/2004 00:12:00(UTC)
This page was generated in 0.720 seconds.
