Offline Adam
#1 Posted : 03 June 2011 06:35:37(UTC)
Adam
Hi all there,
Greeting.
I'm a bit confused with the Marklin MS 60652, now going to upgrade my decoder to sound, but only mfx or M4 recommanded, can someone know other Loksound decoders can run in this system? Eg, Loksound V4, select etc?
Thanks a lot.
#2 Posted : 03 June 2011 07:34:51(UTC)
Hi, Adam,
any decoder that supports the MM protocol or the mfx protocol can be used, so the Loksound V4 should work.
You can easily control 5 functions per loco - with tricks you can control 9 (maybe 10) functions per loco.
The new MS2 controls 16 functions per loco - without tricks, with DCC, MM, or mfx.
ESU Loksound 5 version 58813 (Digital)
by pederbc 03/04/2025 17:57:21(UTC)
LokSound 5 decoder help (Digital)
by osoraku 22/02/2025 16:57:47(UTC)
37591 SBB Ae 8/14 installation of LokSound 5 Decoder (General MRR)
by jpklecker@yahoo.com 18/07/2024 23:32:25(UTC)
CS3 with it's new update 2.5.2. & ESU Loksound 5 (mfx) (Digital)
by bygger01 14/03/2024 20:11:58(UTC)
Telex with Loksound 5 (Digital)
by einotuominen 14/09/2023 17:05:09(UTC)
Issue with Piko CHME3 and ESU loksound 5 (Digital)
by Sashmeister 19/04/2023 22:47:40(UTC)
How sync an ESU LokSound 5 Fx decoder with the origin engine decoder (Digital)
by PeFu 25/03/2023 12:28:57(UTC)
CV for ESU LokSound 4.0 in a bit jerky DCM motor engine (Digital)
by PeFu 24/03/2023 21:49:03(UTC)
programming Marklin decoder with Loksound programmer (Digital)
by kirkcampbell33 18/12/2022 17:14:02(UTC)
Conversion of the snow plow with recent loksound decoder (Digital)
by French_Fabrice 20/11/2022 18:16:17(UTC)
ESU Loksound 5 - Accel/Decel Off option (Digital)
by xxup 13/02/2022 12:32:08(UTC)
Smoke generator and LokSound XL (Big scale)
by ktsolias 25/08/2021 11:33:31(UTC)
MARKLIN 39893 WITH ESU LOKSOUND V 5.0 (Digital)
by lvfocus 02/02/2021 18:16:39(UTC)
CS3 and Loksound MFX (Digital)
by Joakim_B 13/01/2021 17:18:12(UTC)
ESU Loksound 5 Decoder, CS2 or Intellibox (H0-scale)
by johnmarklin 29/11/2020 12:49:47(UTC)
ESU Loksound XL 5 does not work on MS2 (Digital)
by nygma 04/09/2020 12:37:52(UTC)
Mobile Station 2, ESU Loksound 5 and MFX Issues (General MRR)
by skeeterbuck 03/06/2020 12:53:30(UTC)
LokSound v. 3 (Digital)
by ocram63_uk 28/05/2020 17:57:16(UTC)
BR 59 / Württemberg K sound files for Loksound 4 (Digital)
by Bigdaddynz 25/04/2020 02:32:06(UTC)
Loksound 5 decoder programming for Marklin High Beam Function (Digital)
by rbw993 27/03/2020 16:01:17(UTC)
Conversion to ESU Loksound v5 (Digital)
by QQQ1970 22/03/2020 04:42:16(UTC)
Solved - Will a Central station 2 or 3 automatically recognize a Loksound V 4.0 decoder (General MRR)
by river6109 11/03/2020 03:57:58(UTC)
ESU Loksound V 5.0 decoder & ESU adapterplate 51958 (Digital)
by river6109 14/12/2019 16:48:39(UTC)
Changing protocol on Loksound V3.0 mfx (Digital)
by Donb 26/05/2019 19:22:56(UTC)
change Loksound v4 functions allocations with MS2 (Digital)
by lulumiaou06 30/01/2019 21:40:48(UTC)
ESU Loksound Version 5.0 (News from Märklin and others)
by river6109 07/01/2019 00:54:42(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
loksound 3.0/3.5 wheel sensor (Digital)
by applor 12/12/2018 01:32:21(UTC)
Loksound MFX E64400 from ESU retrofiting (H0-scale)
by arcanjo 08/08/2018 23:54:00(UTC)
Loksound V4.0 (Digital)
by Torstein 01/06/2018 13:43:23(UTC)
Speaker replacement for ESU Loksound 3.5 mfx decoder (Digital)
by White Buffalo 17/03/2018 06:18:23(UTC)
37171 DampfLok with Loksound 2 v.1 chip running crazy recently (Digital)
by White Buffalo 30/01/2018 19:40:47(UTC)
Loksound 3.0 M4 (MFX) decoder - chuff sync (Digital)
by applor 20/10/2017 01:38:52(UTC)
Programming / Uploading sound scenes / files into ESU LokSound decoders (Digital)
by Minok 01/03/2017 00:06:32(UTC)
ESU loksound 4.0 M4 mfx decoder on CS 2 (Digital)
by craigericks 01/10/2016 03:00:12(UTC)
Cam/synch chuff/Loksound Xl (Big scale)
by tommyheadleycox 08/08/2016 16:28:25(UTC)
LokSound V4 M4 - How to control the flow of smoke unit (Digital)
by Armando 28/03/2016 01:17:08(UTC)
MS2 and esu loksound v4.0M (Digital)
by Dimitris Kanellos 11/03/2016 10:13:42(UTC)
LokPilot/LokSound Question (Digital)
by Roland 29/02/2016 05:13:12(UTC)
Märklin 55711 DB BR 218 with ESU LokSound XL 3.2 version decoder (Big scale)
by Janne75 26/08/2015 21:58:31(UTC)
ESU LokSound Decoder - English Instruction Booklet?? (Digital)
by Joseph Meiring 23/06/2015 21:29:22(UTC)
ESU Loksound decoders for "old" V200 diesel 3021? (Digital)
by Joseph Meiring 31/05/2015 19:38:57(UTC)
What Loksound Decoder Is This? (Digital)
by trainstamp 30/04/2015 16:04:14(UTC)
loksound conversion br18 3411 (Digital)
by stlcards54 12/02/2015 01:28:24(UTC)
ESU Loksound Decoder (Digital)
by ice 1 21/01/2015 13:35:54(UTC)
ESU LokSound 3 puzzling problem (Digital)
by Peter Neumann 01/12/2014 04:08:22(UTC)
CS2 and Brawa BR232 with LokSound V3.5 (Digital)
by PMPeter 20/09/2014 19:08:19(UTC)
Loksound Select Micro #73800 need help (Digital)
by Dave Banks 13/03/2014 22:25:25(UTC)
ESU Loksound V3.0 MFX decoder advice required (Digital)
by Dave Banks 11/12/2013 23:53:27(UTC)
Programming an ESU Loksound decoder (Digital)
by Drongo 03/09/2013 12:56:16(UTC)
