Offline Kenneth_H
#1 Posted : 18 November 2007 04:48:14(UTC)
Kenneth_H
I have a BR03 that has the smoker in it and forgot where to put the smoke fluid, do I put it in the small hole or the cup like thing of the smoke generator.
Kenneth
#2 Posted : 18 November 2007 05:22:04(UTC)
in the cup
#3 Posted : 18 November 2007 09:52:28(UTC)
Drop 4 or 5 time of fluid in the cup.
Offline al_pignolo
#4 Posted : 18 November 2007 11:24:27(UTC)
al_pignolo
How much time your locos keep on smoking when you fill the generator? My 3315 (BR50) doesn't go over 30-40 seconds. I suspect I've to adjust some CVs in its lokpilot.
Pietro
Offline monster134
#5 Posted : 18 November 2007 11:31:17(UTC)
monster134
[size=1" face="Verdana" id="quote]quote:Originally posted by al_pignolo
<br />How much time your locos keep on smoking when you fill the generator? My 3315 (BR50) doesn't go over 30-40 seconds. I suspect I've to adjust some CVs in its lokpilot.
Pietro
If it smokes a LOT and doesnt last long the little smoker tube is blocked.Seuthe includes a tube and cleaner with every smoker you buy.Just clean the tube.
Offline charles Sharpe
#6 Posted : 21 November 2007 21:47:31(UTC)
charles Sharpe
Hello All I have a BR50 and that only smokes the same as yours I also have a BR03 and that will last 4/5 mins.
CHARLES SHARPE
#7 Posted : 21 November 2007 22:26:07(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by charles Sharpe
<br />Hello All I have a BR50 and that only smokes the same as yours I also have a BR03 and that will last 4/5 mins.
Same as well.
Offline al_pignolo
#8 Posted : 21 November 2007 23:32:54(UTC)
al_pignolo
Thank you Steven and Cahrles. But it still semmes strange to me, because the smoke generator is the same to BR03.
Besides, on a digital locos I expect a more uniform behaviour.
Are your br 50 analog?
Mine is digital with Lokpilot 2.0.
Te smoker is connected to F1, and I set the Cv 115 wit value 111 (smoke generator, 15 V). I don't know what kind of changes in output are made by this "smoke generator" option!
Pietro
Offline hmsfix
#9 Posted : 23 November 2007 00:10:45(UTC)
hmsfix
On my digital steamer (37973 Mikado) with a 72270 smoke generator I usually have smoke for 3 - 5 minutes. The smoke generator is filled with 0.2 milliliter of smoke oil (Volmer).
This seems to be the maximum quantity of smoke oil for the 72270 generator. More oil will "drown" the filament.
Hans Martin
Smoke fluid (H0-scale)
by rhfil 04/03/2023 19:59:10(UTC)
smoke fluid (General MRR)
by Dreadnought 04/02/2023 19:02:19(UTC)
Smoke fluid (Digital)
by Normmeister 19/05/2022 03:09:16(UTC)
Smoke fluid help (General MRR)
by Puttputtmaru 17/05/2021 18:35:06(UTC)
Smoke Fluid (H0-scale)
by garben 16/12/2019 03:11:59(UTC)
ESU Smoke Fluid (H0-scale)
by bugsmasher 08/06/2018 07:20:31(UTC)
Smoke fluid question (General MRR)
by mike c 26/01/2018 00:51:09(UTC)
Smoke fluid - is it safe to use? (H0-scale)
by baggio 09/03/2016 05:51:21(UTC)
Prairie Pony, smoke fluid and other steam locos - how long does one dose last? (H0-scale)
by baggio 07/03/2016 03:42:35(UTC)
Smoke Fluid for Seuthe (H0-scale)
by Hoffmann 07/02/2014 04:41:39(UTC)
Marklin 02420 Smoke Fluid - Health/Saftey Info? (General MRR)
by BrandonVA 26/09/2013 15:46:05(UTC)
Overfilled a seuthe with smoke fluid. Now doesn't work (Digital)
by nelson77 01/02/2012 21:46:43(UTC)
Final decision_Marklin Smoke Fluid (H0-scale)
by FMS 17/01/2012 21:47:26(UTC)
Clean after smoke fluid? (General MRR)
by Mitropa 20/02/2010 19:24:39(UTC)
Märklin/Seuthe Smoke Fluid (H0-scale)
by Armando 01/08/2009 02:01:17(UTC)
Running steamers w/smoke unit w/o smoke fluid (H0-scale)
by Brakepad 18/03/2009 22:45:47(UTC)
Damages from smoke fluid? (General MRR)
by Armando 04/02/2005 06:18:20(UTC)
DIY Smoke Fluid (H0-scale)
by justin182 12/10/2003 20:33:58(UTC)
This page was generated in 0.359 seconds.
