Offline charles Sharpe
#1 Posted : 05 November 2007 20:26:21(UTC)
charles Sharpe
Please can any one help me I have 2 questions.
1] I have my turntable in my layout and the small control box that comes with it wired in and the TT is working fine. Were do I pick up the power to make my K tracks live which go to my engine shed. I have looped each track to the next one but I need a feed.
2] I have two pieces C track connected to the TT and when I backed a train on to the TT today the train shot straight across the TT at full speed and crashed the speed stetting to the CS was only on very low and when I tried it again the train stopped on the TT and started to smoke very badly so much so know when I but that train on the track it causes a short. I think the train is dead.
CHARLES SHARPE
Offline TTRExpress
#2 Posted : 05 November 2007 23:20:55(UTC)
TTRExpress
Charles,
What model TT are you using? If you are using a CS then I assume all your locomotives are digitally controlled. You will need power to all your tracks. Without knowing what your electrics look like it is difficult for me to envisage. I would not loop each track to the next but have feeds for each one individually.
You should follow the wiring descriptions that came with TT. If you are using a Marklin TT it should come already with the 3rd rail power to the aligned track. For the new TT I recall that either Marklin Magazine # 3 or 4 from 2007 gives a good description.
Sounds like you fried the motor on the locomotive. If you have a digital locomotive or Delta, try setting the switches all to zero and attempt to see if loco works in analogue mode on a test track section.
Hope this helps a little.
Best regards (a Scot in Wisconsin)
#3 Posted : 06 November 2007 00:23:48(UTC)
charles Sharpe
Hi TTRExpress
Yes I am using the marklin TT with the CS all of my track is C type appart from the 8 engine sheds.If I have seperate feeds to the K track in my engine sheds were will it come from.
Charles
CHARLES SHARPE
Offline TTRExpress
#4 Posted : 06 November 2007 08:04:14(UTC)
TTRExpress
Hi Charles,
For your K-tracks you will need to wire them for connection for digital use, ie, brown ground wire to the rail joint bar and the red wire to the underside of the of track for the centre rail. You can then run the wires back to your Central Station via a distributor strip.
You should use another transformer to supply the power for your TT controller and lighting. Do not use the same transformer that you use for your Central Station. Use a 32 VA controller, the yellow/brown leads for your TT controller power and the red/brown leads can be used for house lighting and lamps.
Let me know if this helps.
Regards (a Scot in Wisconsin)
#5 Posted : 07 November 2007 20:15:52(UTC)
charles Sharpe
Hi All. Can I use an 60a transformer in place of the 32a as suggested by TTRExpress and on page 40 in issue 3/2007 Marklin mag as I have a spare 60a in stock.
CHARLES SHARPE
Offline TTRExpress
#6 Posted : 07 November 2007 20:24:34(UTC)
TTRExpress
Hi Charles,
You can use a 60VA transformer to power your accessories. As long as your power your accessories with one transformer and use the other for your Central Station and locomotives you should be ok.
#7 Posted : 07 November 2007 20:45:03(UTC)
charles Sharpe
Hi TTRExpress. Many thanks for that . Yes I have 4 trans 1/CS 2/Accessories 3/4 Boosters.
Charles
CHARLES SHARPE
Offline TTRExpress
#8 Posted : 08 November 2007 17:41:56(UTC)
TTRExpress
Hi Charles,
Thanks for the note. Glad the turntable and transformer are working out well for you. Did you ever get your locomotive working again?
Regards (a Scot in Wisconsin)Cool
#9 Posted : 08 November 2007 20:03:37(UTC)
charles Sharpe
Hello TTRExpress.
The train is well and truly dead
CHARLES SHARPE
Offline TTRExpress
#10 Posted : 08 November 2007 22:15:08(UTC)
TTRExpress
I am sorry to hear that Charles. Hopefully it will not be to costly an affair to repair it.
Catenary for trasfer and turntables (H0-scale)
by quarkhirad 03/11/2024 20:28:29(UTC)
Layout Design - Turntables & Roundhouses (H0-scale)
by Richard556 24/05/2016 04:03:53(UTC)
Marklin 7186 & 7286 Turntables (H0-scale)
by trainsman2001 27/02/2013 19:01:18(UTC)
Signals on Marklin Turntables (Digital)
by Oscar0645 21/08/2012 23:58:21(UTC)
How many Turntables do you have/need/want.... (General MRR)
by Ian555 08/04/2012 16:10:24(UTC)
Turntables -wow (H0-scale)
by Jeremy Palmer 24/02/2012 10:47:00(UTC)
CS2 Directly Supports Turntables with a k84? (Digital)
by sokato 10/01/2012 10:45:13(UTC)
Ecos and turntables (Digital)
by laalves 04/08/2007 04:54:27(UTC)
by charles Sharpe 17/04/2007 11:03:29(UTC)
Turntables (General MRR)
by bobhunt2 13/02/2007 07:30:49(UTC)
Smooth Motor For Transfer Tables and Turntables (H0-scale)
by Munich 1860 21/05/2005 21:53:56(UTC)
This page was generated in 0.319 seconds.
