Offline sudibarba
#1 Posted : 19 June 2007 05:31:29(UTC)
sudibarba
I see that LSMODELS in conjunction with Railtop are issuing a Northlander 4 unit rail train in Dec 07. It will be available in DC & AC with decoder. About US $ 420 at this point. Anyone have any experience with these brands? Any thoughts if Marklin will reissue a Northlander? I will never pay what the old ones go for so I will probably pre order one unless I hear huge negatives.
Eric
Offline arne
#2 Posted : 19 June 2007 06:08:29(UTC)
arne
Never heard anything positive nor negative about that brand before. And never used it myslef.
The Northlander #37500 is still available as new/boxed somewhere. But it's up on around the $11-1300 USD. Which is a bit expensive, yea. One of my train friends who was lucky to collect the #37500 while it was available, got it for around $200 USD, calculated around as the currency is right now. :)
Arne
Märklin H0, C & M Track, with Uhlenbrock's quality power and control.
Offline Vardex
#3 Posted : 19 June 2007 12:06:28(UTC)
Vardex
LS models is a good brand, quality is like roco. But.... my dealer said he isn"t convinced about the lifespan of their plastics. Models are made in china, and it seems chinese plastics harden with age. This can be seen on some piko models also. I asked him if he had any negative experience with LS models, and the answer was "no". Still I think you should wait for the trix and roco model, I am sure they also will bring out the northlander. Or do the same as I, and just order it from LS...biggrinbiggrin
Also check their website, or even better railtop.
http://www.railtronic.ch/html/guckloch.html
http://www.railtronic.ch/html/sbb_ns-ram.html
Bart
Offline PierreGILLARD
#4 Posted : 19 June 2007 17:27:42(UTC)
PierreGILLARD
A Märklin revamped Northlander is definitively on my wishlist. [:p] Hope makes life !
I will however have a look on models from other brands.
Further details about LS Models' Northlander here. wink
Thanks for the information, Eric.
I have good experience with LS Models cars till now ... even if I only own 4 of their passenger cars : report about SNCB cars.
Pierre.
Offline ulf999
#5 Posted : 19 June 2007 22:08:13(UTC)
ulf999
I like the options Smile. links bookmarked...
Offline Sander van Wijk
#6 Posted : 19 June 2007 23:55:15(UTC)
Sander van Wijk
I wonder whether anyone has experience with parts deliveries of this brand? I personally consider it to be almost just as important as the lifespan of their plastics as having the opportunity to get a spare can overcome issues like a short lifespan of part (or a little accident, or wear or something like that.) After some rather bad experiences with Mehano parts, I'm appreciating a good parts service even more...
Sander
Offline jonquinn
#7 Posted : 20 June 2007 05:15:01(UTC)
jonquinn
how much worse can it be for $400 US? after the marklin northlander is nothing more than an overpriced hunk of poorly detailed plastic.
at least with the 37500 set the F7 is metal, but it is way overpriced otherwise.
I am considering one of the Roco or maybe the LS TEE trains (maybe a northlander). supposedly the new Trix edition is still plastic. Roco's run nice and smooth too.
Offline Larry
#8 Posted : 21 June 2007 10:02:13(UTC)
Larry
Views messages in topic : 1,443
Yikkes. How could this model be worst in terms of plastic than some of the older Marklin plastic models? The quality of the plastic on the older Marklin's was so horrible it would actually warp. Hard to believe, but true. Then they look like a "banana" Marklin train. Can't get much worse quality than that from Maerklin or anyone else.
#9 Posted : 21 June 2007 16:38:54(UTC)
Very nice,Thanks for the information.
Offline sudibarba
#10 Posted : 25 June 2007 03:23:56(UTC)
sudibarba
The company I work for does a lot of injection molding. Anywhere from 80 ton to 1000 ton presses. I am in the finance area and know the product cost for molded parts. If any company is using incorrect resins or too much regrind - I would be suprised if they are - then they are screwing up the simplist part of their manufacturing process. Top quality virgin resins used in a body of a loco cost less than a dollar. Far less.
I have to believe that warped parts have been exposed to excessive heat and or sunlight no matter what brand. I don't think these people would risk business over pennies.
Eric
Offline Larry
#11 Posted : 25 June 2007 08:48:18(UTC)
Larry
That is helpful, Eric, but the fact is this has been a common problem with the old Northlander models from Marklin. Many of them ended up after time looking like bananas, whether heat induced or not.
#12 Posted : 25 June 2007 11:53:18(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by sudibarba
Hm...
Warped parts would normally be the result of incorrect cooling.
During the cooling phase an injection pressure is normally upheld, and this pressure, together with the cooling time AND type of cooling can be very difficult to determine. Only experienced engineers knows the optimal values for these parameters, together with the type of polymers used. (and the way the tool works and how it is cooled)
The heat "cause" the deforming/warping if a part has been cooled incorrectly: What actually happens is that the heat releases inner tensions in the parts. Tensions that are already there because of the incorrect cooling.
Sunlight would normally first degrade the colours, later cause brittleness (destruction) of the polymer.
Most plastics have been added sunlight-stabilitizers, but these evaporates over the years)
No plastic is really capable to stand up against UV-rays.
Offline jonnymac
#13 Posted : 26 June 2007 01:26:36(UTC)
jonnymac
I just returned from a short business trip to Belgium and I couldn't resist a couple of non-Marklin items.
I brought back the LS Lok Series 13 and a Heris made coach. Very nice pieces for my collection and a reminder of the trip.
Here are a couple of pictures - quality not so good but I'm practicing.
http://i117.photobucket....mckerracher/IMG_0904.jpg
http://i117.photobucket....mckerracher/IMG_0912.jpg
http://i117.photobucket....mckerracher/IMG_0918.jpg
Rgds,
JonnyMac
Offline sudibarba
#14 Posted : 26 June 2007 03:41:59(UTC)
sudibarba
I am not a plastics engineer but when I get back from my current trip I will talk to the folks in our corporte tooling engineering department. We buy millions of lbs of resin a year. If the parts are malformed in the molding process they would never be used as they would not fit or pass QC (operator or inspector). Heat and light leach out the plasticisers (spelling?) causing the parts to get brittle etc.At any rate, I will let them enlighten me to the realities of the processing. I do not believe inferior resins or processes are causing downstream problems with other companies products. This was the point I was trying to make. Roco, Pico, LS are all probably making good plastic parts. Marklin does not have any special knowledge of molding. Try making 500 syringe barrels in a mold compared to making toys.
Eric
Offline 7gauges
#15 Posted : 26 June 2007 06:49:54(UTC)
7gauges
Actually early RAM models are the only ones affected - the two Northlander sets are just fine, as well as the latest RAM sets (I have the 3071 / 4071, 3150, 37500, 3471 & 39700). Most Marklin plastic models from the 60's into about 1971 are effected by warping - and it has nothing to do with UV or heat (some have never left the box and been stored quite well in a cool dry place - it has to do with volatile stabilizers in the plastics - the key word being volatile - the stabilizers prevent kinking (warping) of the polymer chains - as the volatiles dispate over time the polymer chains kink causing such warping in the body of the model - they can bend metal .... a very interesting process that is effectively irreversible and basivally unavoidable - the newer plastics do not use volatile stabilzers.
Offline Larry
#16 Posted : 26 June 2007 09:31:39(UTC)
Larry
Amazing. I had no idea locos turning into looking like bananas could engender such an interesting dialogue. You guys are amazing and a wealth of knowlege. Smile
Any insights as to the existence of mankind? Ah, guess that is another Forum, sorry. Or, the answer is to play with model trains. biggrin
John - Those Belgium models look great!
Offline Caplin
#17 Posted : 26 June 2007 14:37:53(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by 7gauges
<br />Actually early RAM models are the only ones affected - the two Northlander sets are just fine, as well as the latest RAM sets (I have the 3071 / 4071, 3150, 37500, 3471 & 39700). Most Marklin plastic models from the 60's into about 1971 are effected by warping - and it has nothing to do with UV or heat (some have never left the box and been stored quite well in a cool dry place - it has to do with volatile stabilizers in the plastics - the key word being volatile - the stabilizers prevent kinking (warping) of the polymer chains - as the volatiles dispate over time the polymer chains kink causing such warping in the body of the model - they can bend metal .... a very interesting process that is effectively irreversible and basivally unavoidable - the newer plastics do not use volatile stabilzers.
Hi 7gauges,
Thanks for the thorough explanation.
Now I know why some of my plastic bodies form the 60's (although Fleischmann) have developed slightly skewed shapes.
A typical shape in this picture, the center bottom is raised and the two sides are bended outwards as if a too wide cargo was forced down into it. Actually with this particular wagon I tried to heat up the sides and keep them in line. It was a lot worse before, but it is not perfect.
Benny - Outsider and MFDWPL
#18 Posted : 26 June 2007 15:18:46(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Larry
<br />I had no idea locos turning into looking like bananas could engender such an interesting dialogue. You guys are amazing ...
Ya know, Larry - just use one of the wonder words (BEER, FOOD). And we're singing your tune ... biggrin
Offline alonso231gery
#19 Posted : 26 June 2007 15:31:40(UTC)
alonso231gery
So the famous northlander was not fully metallic .
The item is no more in my wishlist .
An outsider.
Offline sudibarba
#20 Posted : 27 June 2007 05:43:26(UTC)
sudibarba
Oh well. After all of this I guess I will order the Ls Northlander and take my chances.
Eric
Offline jonnymac
#21 Posted : 27 June 2007 06:17:20(UTC)
jonnymac
Here are the other 2 LS items I bought in Belgium. Nice bar stools in the Disco Car! Once again, apologies for the poor photography skills
jonnymac
http://i117.photobucket....mckerracher/IMG_0911.jpg
http://i117.photobucket....mckerracher/IMG_0908.jpg
#22 Posted : 27 June 2007 11:20:50(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by jonnymac
<br />Here are the other 2 LS items I bought in Belgium. Nice bar stools in the Disco Car! Once again, apologies for the poor photography skills
I suppose it is distortion caused by the camera, but the above picture shows the waggon already heavily "banana´d"!?
Offline jonnymac
#23 Posted : 28 June 2007 22:06:48(UTC)
jonnymac
Any distortion is caused by the photographer's skills not the camera and certainly not the wagon. The wagon is a beauty.
jonnymac
Guest (5)
Northlander (Prototype)
by dickinsonj 03/01/2026 13:09:42(UTC)
Question about packaging northlander (H0-scale)
by Davidbelgium 09/12/2025 04:41:54(UTC)
Northlander 39705 (H0-scale)
by Vincent Jr 02/06/2025 18:04:38(UTC)
39705 Northlander (H0-scale)
by QQQ1970 18/08/2024 22:19:45(UTC)
39705 Northlander release date (General MRR)
Belarus obb_taurus 23/05/2024 17:16:14(UTC)
Northlander (General MRR)
by sudibarba 05/11/2023 03:05:55(UTC)
New Roco Ontario Northlander (H0-scale)
by michelvr 23/10/2021 23:04:34(UTC)
How to open the Northlander 37500 FP7? (Digital)
by blid 06/03/2017 16:22:00(UTC)
New decoder for Ontario Northlander (Digital)
by Oliver nagel 14/05/2016 14:05:31(UTC)
The Northlander Website (Prototype)
by michelvr 12/08/2013 18:29:16(UTC)
Ontario Northlander (Collector's Corner general)
by Dreadnought 04/08/2013 14:34:58(UTC)
Northlander - The last train (Prototype)
by jcrtrains 29/09/2012 02:19:28(UTC)
37500 Northlander value (General MRR)
by klarinettmeister 12/12/2010 12:57:03(UTC)
northlander question - real or not? (Collector's Corner general)
Belarus jonquinn 01/11/2008 03:36:59(UTC)
by sudibarba 14/03/2008 03:47:27(UTC)
Here is another "Northlander" (Collector's Corner general)
Belarus nevw 14/07/2007 06:47:10(UTC)
37500 Northlander (H0-scale)
by foumaro 20/02/2005 16:15:02(UTC)
MiniTrix Northlander (General MRR)
by Bill 05/10/2003 04:55:57(UTC)
Marklin Northlander (H0-scale)
by Campodma 15/01/2002 20:36:30(UTC)
This page was generated in 0.918 seconds.
