Offline argal
#1 Posted : 25 February 2003 10:07:21(UTC)
argal
Firstly I must say that I am aware that this subject has been covered extensively and I have read all the references contained in the forum.
However, I would still like your opinion on two points.
My problem is that no smoke comes out of smoke generator on BR 18.4.
The smoke unit has been tested outside the loc and it works, also as far as I can see, it does maintain good contact with the tongue and it touches well the inside of the funnel. Most likely cause would be that there is no current going to the tongue but before taking her to a dealer for repair, can anyone tell me
1) if the problem could be the 6647 32 VA transformer that I use (underpowered), although no other locs are running simultaneously and
2) Why is that that when the F1 button on the 6021 is lit (for smoke generator) and you also press F2 or F3 for horn/bell, then the horn or bell sounds every 2-3 seconds continuously. Could it be some problem with F1 button?
Aris
Offline KLB
#2 Posted : 25 February 2003 14:49:54(UTC)
KLB
Hi Aris,all,
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote> Most likely cause would be that there is no current going to the tongue but before taking her to a dealer for repair, <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=1 id=quote>
You can check it yourself with a meter.Also you might what to sand out the smoke stack.Sometimes when the factory paints these units paint gets inside therefore the smoke unit does not make good ground contact with the stack.
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote> you also press F2 or F3 for horn/bell, then the horn or bell sounds every 2-3 seconds continuously. Could it be some problem with F1 button?<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=1 id=quote>
Possibly,.....
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Kevin!
Offline argal
#3 Posted : 25 February 2003 15:24:25(UTC)
argal
Thanks Kevin,
I did use sandpaper on the smoke stack, I reversed the red/brown cables, all the suggestions in the past subjects in the forum but unfortunately all to no avail.
Pressume the DIP switches on 6021 have nothing to do with it.
No 2 ON, all others OFF.
Aris
#4 Posted : 25 February 2003 23:20:26(UTC)
Have you tried to run the loco on a non-digital track with the transformer only? It should then smoke, since F1 should be default "on" while running analog...
Offline argal
#5 Posted : 26 February 2003 11:25:25(UTC)
argal
Thanks Webmaster for the brilliant idea.
Will give it a try this evening.
This is why this forum is invaluable!
best regards/Aris
Offline bigbird888
#6 Posted : 01 March 2003 15:03:54(UTC)
bigbird888
Hi Guys, just wondering what's the result of the test. I have the same problem. The smoke generator on BR 18.4 would not smoke, and when F1/F2 or F1/F3 are active, the horn and bell sound repeatedly.
Ka Wei
Ka Wei
Offline argal
#7 Posted : 03 March 2003 13:03:49(UTC)
argal
Hi Webmaster, Ka Wei, all
The test proved negative, still no smoke coming out. It seems that no (or very little) current is going to the tongue.
The local repair shop advised me that it is probably a fault of the decoder, as about 80% of the BR 18.4 from starter packs develop smoke/sounds problems very shortly.
The question is whether can one by-pass the decoder and give current directly to tongue from the shoe (any problems with this? -apart from smoke coming out continuously), spent about Euros 100 in Greece for a new decoder, or live a smokeless train life which is also healthy!
best regards
Offline jcegido
#8 Posted : 03 March 2003 17:14:28(UTC)
jcegido
Hi Aris,
If decoder replacement is the solution, perhaps you may consider any other cheaper (but no worst) decoder option. I´m talking about ESU´s Lokpilot, Uhlenbrok´s, Roco´s for AC,... Lokpilot is sold for 30€ in many online German shops. I´ve got a couple of these in my Märklin loks, and I´m very satisfied with results.<img src=icon_smile_big.gif border=0 align=middle> Think about this.
Best regards.
Juan Carlos
Juan Carlos
Offline McLae
#9 Posted : 03 March 2003 18:55:49(UTC)
McLae
When I got my digital S 3/6, the smoke unit came separatly. After putting in the smoke generator, nothing happened.
On looking at the smoke unit, there is a 'pigtail' wire comming out at an angle. I put the smoke unit back in with the angle pointing forward, toward the contact strip. Now it works!
Try rotating the smoke unit.
Good Luck.
The McLae
Offline argal
#10 Posted : 03 March 2003 18:58:54(UTC)
argal
Thanks Juan Carlos,
I will give it a thought. The sound at the moment is O.K.
Will the decoders you mentioned provide solution for my smoke problem?
Hello Ka Wei,
If you find yourself any solution to this problem let me know please. Likewise I will do the same of course.
best regards
Aris
Offline jcegido
#11 Posted : 03 March 2003 19:48:32(UTC)
jcegido
This decoders will probably give a solution for your smoke problem, if the problem is in the decoder. Maybe a more experienced member, should give us a view on how to manage this (instalation of lokpilot) with the present loco sound decoder.
I´m thinking on something... Have you tested the decoder output soldering for the smoke generator? Is that wire OK?
Juan Carlos
Juan Carlos
Offline argal
#12 Posted : 04 March 2003 09:54:41(UTC)
argal
Hello Juan Carlos, McLae, all
Thank you for your ideas but everything has been tried like turning the smoke generator or testing the cable and the soldering. Simply there is very little current going to the decoder output for the cable connected to the tongue. It is probably that the decoder has gone dead for this function. I have given up now, I will try connecting the tongue directly to the shoe and perhaps later go for a new decoder whilst using this decoder on another loc without smoke.
best regards
Aris
Offline bigbird888
#13 Posted : 04 March 2003 17:04:52(UTC)
bigbird888
Thanks Guys for all the suggestions. I have also tried aligning the smoke generator but there is still no smoke. I take it that a properly working generator would produce smoke almost instantaneously. But now, all I hear is a faint regular ticking sound when F1 is pressed. I will try the local dealer during the weekend and see if he has got any other tricks. Meanwhile, like Aris, I will have to go without smoke :-( Regards.
Ka Wei
Ka Wei
Offline jcegido
#14 Posted : 04 March 2003 17:50:52(UTC)
jcegido
Just another suggestion; is there any other function terminal free in the decoder? So, you should be able to connect the smoke generator to it and try.
Juan Carlos
Juan Carlos
Offline argal
#15 Posted : 05 March 2003 15:15:12(UTC)
argal
Hi Juan Carlos, all
This is also a good idea.
There are no free function terminals (f1=smoke, f2=horn, f3=bell, f4= braking/starting delay) but perhaps one could substitute one of sounds with the smoke generator, although I think the smoke requires more current.
Thanks very much Juan Carlos and appreciate your help.
best rgds
Aris
Offline argal
#16 Posted : 10 March 2003 21:06:32(UTC)
argal
Hi Kai Wei, Juan Carlos, all
I followed Juan Carlos advice and changed the smoke generator current cable with the bell sound (which was not brilliant any way) and vice versa. So now bell is on F1 (not working), but the smoke generator on F3 works perfectly.
best regards
Offline jcegido
#17 Posted : 10 March 2003 22:37:26(UTC)
jcegido
Hi Aris, Ka Wei, all,
Glad to help you<img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_wink.gif border=0 align=middle>
Juan Carlos
Juan Carlos
Offline bigbird888
#18 Posted : 12 March 2003 13:22:18(UTC)
bigbird888
Thanks Juan. Regards. <img src=icon_smile.gif border=0 align=middle>
Ka Wei
Ka Wei
Offline berdos
#19 Posted : 08 August 2003 16:28:20(UTC)
berdos
Hi all
Aris i have the same problem...which is the cable for the smoke generator and which for the bell? I don't know a lot about the decoder's architecture.Any photo or site?
thanx
Offline Davy
#20 Posted : 29 August 2003 18:29:25(UTC)
Davy
I have some 10 steamlocs with a lot of different smoke generators. If you have a smoke generator with a small pipe and a reservoir in the bottum. The best thing you can do is using a syringe with a small needle.
M-track with a CS2.
Smoke units (H0-scale)
by Keim 30/05/2024 01:05:28(UTC)
Ac analog smoke units (H0-scale)
by Keim 09/03/2024 02:10:54(UTC)
BR53 Mallet & smoke unit (H0-scale)
by cintrans 03/03/2024 21:19:29(UTC)
Smoke units - can you tell the difference? (General MRR)
by ocram63_uk 21/01/2023 17:14:26(UTC)
Smoke unit (General MRR)
by BenP 03/01/2023 15:14:17(UTC)
Marklin 55082 SCNF 241 65 A Smoke Unit (Big scale)
by BurritoJoe 22/12/2022 13:17:35(UTC)
KM1 01 180 1 Gauge loco Smoke Unit repair (Big scale)
by Bigdaddynz 29/12/2020 05:59:05(UTC)
Connecting 2 x 7226 Smoke Unit in Borsig (H0-scale)
by Johnvr 05/11/2019 16:31:02(UTC)
Smoke Unit Issue (H0-scale)
by madhu.gn.71 04/11/2019 03:41:36(UTC)
eCig fluid in smoke units (General MRR)
by ocram63_uk 10/03/2019 14:16:06(UTC)
Which Smoke unit for 37195? (General MRR)
by Melbourne marklin 07/02/2019 13:21:50(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
Adding Wires to Seuthe Smoke Units (General MRR)
by skeeterbuck 03/11/2018 17:21:56(UTC)
Smoke units and there use (H0-scale)
by danmarklinman 27/12/2017 23:15:25(UTC)
Why Do Smoke Units Fail? (General MRR)
by SteamNut 26/10/2017 22:12:54(UTC)
3046/3047 BR 44 Digital Conversion- Keeping the smoke unit? (Digital)
by 5HorizonsRR 20/10/2017 02:25:14(UTC)
smoke units for Lady C (Württembergerin) locos? (H0-scale)
by DaleSchultz 11/03/2017 04:50:53(UTC)
Fitting smoke unit to 37085 - help (General MRR)
by twmarklinfan 28/02/2017 12:51:01(UTC)
3102 with 6090 - Smoke Units and Lights not working anymore (General MRR)
by mb300e4m 27/02/2017 21:39:06(UTC)
my 3047 Loc runs slower as soon as I enable the smoke unit (Digital)
by acwertheim 03/07/2016 19:33:06(UTC)
Need to set my smoke unit 7226 to be always on (Digital)
by acwertheim 14/06/2016 18:29:21(UTC)
LokSound V4 M4 - How to control the flow of smoke unit (Digital)
by Armando 28/03/2016 01:17:08(UTC)
Smoke unit in Marklin 3099 (General MRR)
by joyofmarklin 09/03/2016 22:29:37(UTC)
Marklin 7226 & Marklin 72270 Smoke Units (General MRR)
by skeeterbuck 20/01/2016 19:36:23(UTC)
Problem while installing smoke unit on 36243 (H0-scale)
by madhu.gn.71 01/09/2015 10:51:26(UTC)
smoke unit fitted to S2/6... (H0-scale)
by Joseph Meiring 25/06/2015 21:28:54(UTC)
Adding a Seuthe Smoke Unit to a Trix 2-8-2 (Digital)
by trainstamp 17/04/2015 20:01:15(UTC)
Help With Smoke Unit (H0-scale)
by SteamNut 28/01/2014 23:22:53(UTC)
Trouble with smoke unit (H0-scale)
by SteamNut 28/09/2013 14:43:56(UTC)
Smoke Units (H0-scale)
by SteamNut 21/09/2013 02:08:43(UTC)
7226 Smoke Units - does anybody try to maintain these ? (H0-scale)
by Johnvr 07/09/2013 12:51:23(UTC)
Smoke unit 7226 for 3047 Loc? (H0-scale)
by acwertheim 04/07/2013 23:29:05(UTC)
can't turn off smoke unit. is that bad? (Digital)
by obxbill 30/01/2013 02:38:03(UTC)
39103 BR 01 1057 smoke unit output not working (no voltage) (Digital)
by Janne75 23/01/2013 18:14:30(UTC)
Help with smoke unit for M BR 94 37160 (H0-scale)
by Torstein 25/12/2012 16:37:47(UTC)
Strange smoke unit behaviour (General MRR)
by sebastian 01/01/2012 22:17:30(UTC)
Need Advice On 72270 Smoke Unit Operation (H0-scale)
by 5HorizonsRR 24/11/2011 03:25:55(UTC)
smoke unit for 39022? (General MRR)
by Joseph Meiring 30/10/2011 17:01:20(UTC)
Installing the tapered smoke unit in BR 55 (H0-scale)
by Armando 14/10/2011 21:24:55(UTC)
Smoke Units identifications (H0-scale)
by ac jacko 18/06/2011 04:42:10(UTC)
Smoke unit not working (Digital)
by REUBEN 10/06/2011 21:44:49(UTC)
Marklin 3311 smoke unit questons (H0-scale)
by Kevin Weis 10/02/2011 02:27:27(UTC)
37193 and Smoke Unit (H0-scale)
by I_love_Marklin_37538 03/01/2010 10:07:55(UTC)
Running steamers w/smoke unit w/o smoke fluid (H0-scale)
by Brakepad 18/03/2009 22:45:47(UTC)
smoke units for dummies (H0-scale)
by dlarson 22/05/2008 19:20:01(UTC)
Adding a Smoke Unit (Digital)
by elsleuth 24/04/2008 02:06:21(UTC)
smoke units for buildings (Model kits & layout details, kitbashing and such)
by prc 04/01/2006 05:04:47(UTC)
smoke unit vs decoder (Digital)
by HvR 04/07/2005 14:49:36(UTC)
Busted Smoke Unit (Big scale)
by xxup 19/12/2004 09:21:03(UTC)
Smoke unit retrofit (H0-scale)
by Tamrac 08/11/2003 19:06:23(UTC)
This page was generated in 1.624 seconds.
