Offline morsing
#1 Posted : 06 September 2014 17:35:45(UTC)
morsing
I'm finally up and running, almost can't believe it! 15 days to get hold of a connector box!
Anyway, I have a derailing problem... I'm pulling Marklin carriages with a Roco loco, but between both the carriage and the loco and front carriage it frequently derails by the buffers getting on top of each other if there is a tiny straight stretch between curver. Say I come out of a curve and there is a 077 then a point, and this happens.
Even the little straight bit on the curved R1 points cause this problem.
Is there something that need adjusting?
Thanks in advance.
Marklin C-track + CS3+
#2 Posted : 06 September 2014 19:26:17(UTC)
Maybe you just have to get rid of the Märklin couplers and get some NEM compatible couplers.
Märklin couplers are too high for scale models.
See also:
http://blog.mailez.de/eblog/?p=65
Offline morsing
#3 Posted : 06 September 2014 22:51:45(UTC)
morsing
See also:
Looking at that blog, my Roco loco already has Maerklin like couplers...
#4 Posted : 06 September 2014 23:10:10(UTC)
A Märklin coupler on the Märklin coach next to the loco can still be a problem because it is too high - and the buffers on the Roco loco are lower than buffers on Märklin locos.
#5 Posted : 07 September 2014 03:34:45(UTC)
It is possible that a Maerklin type 7203 coupling on a Roco coach or locomotive can contact the underside of the buffer in curves. You can avoid this by either using a hook only coupler on the locomotive or by replacing the Maerklin coupler with Roco's universal coupling. The reason for this is that the Roco Universal coupler is about 1mm longer than the Maerklin one, which allows it to avoid snagging the buffer. The other possibility is to use regular hook couplings for the locomotive and for the end of the coach next to the locomotive.
#6 Posted : 07 September 2014 07:36:42(UTC)
According to Reiner Lüssi's site, the difference is only 0.1 mm. IMHO length doesn't matter here, but Roco Universal coupler saves about 2 mm in height.
#7 Posted : 07 September 2014 08:29:53(UTC)
It seems Roco universal coupler wins.
#8 Posted : 07 September 2014 09:37:59(UTC)
Roco also make height-adjustable Universal couplers which are really longer. They can be used when longer couplers are needed.
They are not normally needed, but may help if the NEM pocket of loco and/or coach are not at the correct position.
#9 Posted : 07 September 2014 10:00:36(UTC)
Morsing, This has happened to me too with a Roco loco.
The Roco locos don't always handle Marklin couplers well. As Tom has said, the buffers are mounted lower than on Marklin locos.
I had a few Roco standard couplers available from Roco wagons which I had fitted with Marklin close couplers. I fitted the first wagon or coach next to the Roco engine with one of the Roco couplers and this stopped the derailing.
Offline morsing
#10 Posted : 07 September 2014 11:17:51(UTC)
morsing
The buffers are exactly the same height as far as I can tell.
I found the "problem" anyway. The buffers on the Maerklin coaches have two positions, short and long. I pushed the buffers on the coach hooking onto the loco to the short position and that fixed it! I've even reversed through points and S-curves at fairly high speed without problems.
Photo below shows what happens when they're on the long setting:
Couplers
thanks 3 users liked this useful post by morsing
#11 Posted : 07 September 2014 18:16:26(UTC)
Glad you found the problem!
I'd forgotten about the two buffer positions. This did happen to me once with some new coaches and it took me a couple of days to figure out.
Offline TrainIride
#12 Posted : 07 September 2014 18:28:48(UTC)
TrainIride
I had the same behavior with some SNCF corail coaches ...
I did not know it was common to Märklin recent models.
Thank you for the information ThumpUp
Best Regards
Joël
#13 Posted : 07 September 2014 18:36:40(UTC)
What track curves(radii) do you use as S-curves?
Offline morsing
#14 Posted : 07 September 2014 20:24:07(UTC)
morsing
It's just an R2 with an R1 curved point then going into a normal point with a 24224.
Offline Drongo
#15 Posted : 08 September 2014 05:19:34(UTC)
Drongo
Couplers
Do all Marklin coaches have the 2 position buffers, or is something special?
#16 Posted : 08 September 2014 08:09:26(UTC)
AFAIK all 27 cm and 1:100 coaches with close couplers have them.
I think the "new longer length" (28.2 cm) coaches don't have them.
trains derailing (H0-scale)
by jbiggie 06/02/2024 10:50:18(UTC)
class 800 37984 front bogie/truck derailing- any thoughts? (H0-scale)
by plg 29/12/2023 17:37:23(UTC)
Roco passenger cars derailing on double slip switch (H0-scale)
by MarcelV 02/11/2022 23:14:57(UTC)
29721 locomotive keeps derailing (H0-scale)
by mfaris01 16/10/2020 15:39:05(UTC)
Spontaneously derailing tin plate passenger cars (H0-scale)
by sjbartels 10/01/2019 23:22:26(UTC)
Roco Railjet Loc Derailing (H0-scale)
by PMPeter 07/08/2017 16:31:08(UTC)
ICE 3 37788 Derailing (H0-scale)
by Harvey 24/03/2017 21:49:00(UTC)
S 3/6 derailing (H0-scale)
by Donb 23/01/2017 19:44:41(UTC)
Brawa S9 derailing (General MRR)
by franciscohg 15/04/2016 01:02:40(UTC)
Santa Fe derailing -- one thing that worked (H0-scale)
by BillJ 16/02/2013 16:15:58(UTC)
Marklin P8 Front Truck Derailing (H0-scale)
by Imagine 25/01/2013 05:02:56(UTC)
HELP! Marklin bi-level cab control car derailing (H0-scale)
by BigJeffyLawd 25/12/2012 21:00:34(UTC)
Interesting experience with Roco cars derailing on Marklin C track (General MRR)
by Chris6382chris 20/07/2010 08:54:32(UTC)
Risk of DB Freight carriages derailing (Prototype)
by river6109 20/11/2009 13:24:30(UTC)
4367 SBB 6 car set derailing (H0-scale)
by gachar001 11/03/2009 20:17:22(UTC)
This page was generated in 0.629 seconds.
