Offline BigJeffyLawd
#1 Posted : 25 December 2012 21:00:34(UTC)
BigJeffyLawd
Merry Christmas to all, I go a marklin regional express for Christmas which is what I wanted and when I was on holiday in Germany earlier this year I bought a doppelstock-steurewagen which is very nice, but keeps derailing. It's fine when pushed but when pulled the front bogie derails. Can I have some help, I loosened the piece of metal which senses which direction it goes in, any help. ps. It hasn't been oiled
thanks 1 user liked this useful post by BigJeffyLawd
Offline kbvrod
#2 Posted : 25 December 2012 22:50:44(UTC)
kbvrod
Hi all,BigJeffy,
Some questions first: because I do not have this model.
Does it derail on switches,curves? Or all-the-time? Type of track?
I am going to assume the wagen has separate NEM coupler sockets,...
Are the bogies 'free' wheeling?
How do the wheels sets sit/move in the bogies?
Dr D
#3 Posted : 25 December 2012 23:22:54(UTC)
BigJeffyLawd
It is running on C track and is derailing on curves, what do you mean 'free wheeling'. The wheels are sort of stiff and it has reflex couplings, thanks
#4 Posted : 25 December 2012 23:28:36(UTC)
Sometimes the wheels are pushed in too far (maybe caused by a shock during transport).
Are the wheels turning when you pull the coach by hand? Do all wheels have contact with the rails?
Offline kbvrod
#5 Posted : 25 December 2012 23:35:04(UTC)
kbvrod
Hi Jeff,all,
What I mean by fre-wheeling,is that the bogies swivel without hindrance and that's not hitting any steps/skirting.
Wheels are stiff,not good,...
Are the Relex couplers attached to the frame or to the bogies?
Dr D
thanks 1 user liked this useful post by kbvrod
#6 Posted : 26 December 2012 00:56:39(UTC)
BigJeffyLawd
The bogies are sort of hitting the skirting but I have fixed it now, I turned the bogies around further that they are supposed to go on both sides and then turned it back. It worked well but some of the wheels aren't touching the rails but you wouldn't see it, its no problem. Here it is Flickr
#7 Posted : 26 December 2012 04:02:15(UTC)
The axle should not be floating like that. Can you check to make sure that the axle is properly in position? I would also check to make sure that the slider is not lifting the bogie off the tracks. If possible, can you take a photo of the bogie from the side when the coach is lying on it's side, as well as a photo of the underside of the coach taken from beneath the slider? Was the axle lifting off the rails before you turned the bogies around?
You can just attach the photos to the post using the "Attach files" feature.
#8 Posted : 26 December 2012 09:14:40(UTC)
I think wheels not touching the rails are the problem. I guess that at least one of the axles is not properly in the axle bearings of the bogie.
#9 Posted : 26 December 2012 12:34:25(UTC)
BigJeffyLawd
Ok, I'll upload them to flickr as they don't have any file size limits. It's not the bogie with the slider but the one in the front which doesn't even have couplings. Thanks for your help guys, really appreciated. http://www.flickr.com/photos/80970834@N06/
#10 Posted : 26 December 2012 21:10:10(UTC)
The front axle has a contact built onto the shaft which determines whether the lights are white or red, depending on whether the contact is made with the pin attached to the bogie. It appears to me that this assembly may be out of position, which would prevent the axle from properly sitting on the rails. I have the 43305, 42178 and 43410 pilot coaches which have a similar mechanism, but it would probably be best to have the actual model in hand for comparison. Check to ensure that the metal plate attached to the axle has play when moving in one direction and that it is not always contacting the little pin. Looking at my 42178, it is hard to tell exactly what the problem is.
Do you have a Maerklin dealer in your area who could inspect it or do you know of other forum members in your area?
You can also try asking service(at)maerklin.de to see what they suggest.
Offline kbvrod
#11 Posted : 26 December 2012 22:17:31(UTC)
kbvrod
Good call Mike!The contact has to have balance,that is enough contact on the axle's but not to inhibit them.
Dr D
#12 Posted : 26 December 2012 22:52:21(UTC)
BigJeffyLawd
Thanks, very helpful, will do
This page was generated in 0.598 seconds.
