Offline wally45
#1 Posted : 13 March 2022 16:44:03(UTC)
wally45
Hi i recently encountered a problem with one of my 6021 controllers where the after a few minutes running the loco lights started to flicker, luckily one came up for sale and so i bought it, unfortunately the problem remained. So i swopped controllers and the lights flickered on the alternative controller. My controllers are connected to plugs and sockets so i can swop to analogue and i discovered that the wires to controller question was to heavy a gauge, substituted thinner cable all good . Hope this might help someone Phil.BigGrin
#2 Posted : 13 March 2022 18:51:58(UTC)
I suspect you actually have some other connection problem that was solved by replacing the wires. The heavy wire gauge on its own won't cause problems like you describe.
Offline PMPeter
#3 Posted : 14 March 2022 15:00:49(UTC)
PMPeter
Totally agree with kiwiAlan. Problems usually occur when your wire gauge is too small, not the other way around. The act of replacing the wire caused whatever your underlying problem was to be fixed, not the fact that you used a smaller wire gauge.
Offline wally45
#4 Posted : 21 April 2022 19:41:11(UTC)
wally45
Many thanks for your thoughts most helpful one for reference.Phil
#5 Posted : 21 April 2022 20:56:53(UTC)
What power supply are you using? Is it a dedicated transformer for the 6021 (600X) or is it a regular transformer (664X)?
I don't know what kind of issues would cause flickering of lights. You mention that on the first one, it was the lights on the locomotive that were flickering.
You then mention that "the lights flickered on the alternate controller". Did you mean the LED display on the controller or did you mean that the locomotive lights still flickered with the new controller?
The gauge of the wires is not too major, as long as the wires for live and ground are of similar type. Using two different type wires can create a weak spot, especially where the wires are connected to transformer, track or other connection. Most often, this would be noticeable in terms of heat and not in flickering of lights.
Might I inquire as to the model of the locomotive in question? Some older locomotives still had the lights connected via the chassis for return and this caused flickering in digital operation. Newer models had the lights connected by wire directly to the circuit board/decoder which solved the flickering issue. Was it an older 36XX lok (1990s)?
Offline BenP
#6 Posted : 22 April 2022 00:22:15(UTC)
BenP
Flickering on my digital system (using 6021/IB2/CS3+) was caused by grounding lights to track (it is "alternating current"), from lights base to train chassis/wheels. Using the grounding wire of decoder solves this, which can be used for multiple lights by splitting decoder ground wire (don't mess with decoder plate). I replaced the original screw/bajonet lights with pin lights and holders that are insulated from chassis (more recently, I am using LEDs).
Offline wally45
#7 Posted : 25 April 2022 11:28:51(UTC)
wally45
Hi the controller in question was connected to the correct transformer, the locos lights flickered on a range of locos Marklin old & later models fitted with 60760 decoders Fleischman Roco Piko Lilliput locos fitted with Lokpilot or Roco decoders, another 6021 controller connected to an anaologue controller did not suffer with this problem.The wiring was tested with a meter & no issues were found with the connections as i said problem was solved by a cable change. does not really make sense but it worked. Best regards Phil
6021 control dip switches (Digital)
by marklinist5999 26/03/2025 17:16:02(UTC)
6021 Control Unit (General MRR)
by hdunsmore 08/12/2024 05:08:09(UTC)
Marklin 39621 Lockup on 6021 controller layout (Digital)
by SteveK-O 03/03/2023 15:46:46(UTC)
MFX and 6021 controller (Digital)
by cintrans 16/07/2022 01:37:41(UTC)
Help finding 36240 address on 6021 controller (Digital)
by GenDemo 21/11/2021 11:51:04(UTC)
Sound Functions using 6021 Controller (Digital)
by Johnvr 12/06/2021 10:11:58(UTC)
764xx signals with 6021 control unit and 6040 keyboard (Digital)
by PeterCambridge 11/10/2018 17:56:25(UTC)
MTH and Marklin 6021 Control Unit. (H0-scale)
by Hoover007 22/11/2015 02:57:59(UTC)
Programing the MTH Proto Sounds 3E+ 3rd rail loco to the Marklin 6021 control unit, (H0-scale)
by Gary Gibler 17/11/2015 16:36:03(UTC)
6021 Controller Killing Decoders? (Digital)
by StuartA 06/07/2014 21:43:01(UTC)
Setting CV Addressesfor running locos with sound functions using 6021 controller (Digital)
by Johnvr 08/06/2014 18:14:39(UTC)
6021 Controller question (Digital)
by ChooChoo 19/04/2014 18:57:08(UTC)
6021 Control Unit with Uhlenbrock UHL64820 Loconet & IRIS infrared remote control to use k83 decoder (Digital)
by Hoover007 20/03/2014 08:00:50(UTC)
37622 Santa Fe Diesel Dead - no response to 6021 controller (H0-scale)
by abisel 21/12/2012 04:52:43(UTC)
Converting to digital no output 6021 Control unit (Digital)
by upnatum 05/11/2010 23:49:02(UTC)
Mobile station and 6021 controller (Digital)
by Bahn-an-arama 21/08/2009 16:23:30(UTC)
Digital control with 6021 control unit (Digital)
by Tex 22/10/2008 07:06:48(UTC)
Blown 6021 controller (Digital)
by rnickl 26/11/2007 01:30:30(UTC)
ganging 2* 6021 control units (Digital)
by teecee 28/10/2005 03:39:55(UTC)
6021 Control Unit (H0-scale)
by jimbrauer 27/03/2003 05:41:09(UTC)
This page was generated in 0.549 seconds.
