Offline dboost
#1 Posted : 24 February 2021 00:51:34(UTC)
dboost
Hello...I am wondering if I could power 3 Marklin HO engines with a single Marklin transformer #6646. Thanks for any advice. Dietrich
Online JohnjeanB
#2 Posted : 24 February 2021 01:23:24(UTC)
Hi Dietrich
The transfo is 32VA, depending on the loco you use and if you use signals (not all locos are running simultaneously) the needed power will vary from 10W (one modern loco with LEDs), to 20 W (one old 3015 / CCS800 loco). multiply this by the number / type of locos you have and you will get the result.
Usually for most Märklin usual types, one such transfo is good for 1 to 2 trains running simultaneously.
Note: the steam generator add approx. 10W to the needed power
Marklin transformer 6627 (H0-scale)
by Jerry McLane 12/04/2025 21:38:56(UTC)
Marklin Transformer from 1960 (General MRR)
by Slinger 30/12/2022 15:12:15(UTC)
Marklin transformer 6611 (H0-scale)
by michaelh 13/10/2021 09:30:34(UTC)
Marklin Transformer Voltage (Small scale)
by zoooctan 04/05/2021 14:40:11(UTC)
Non marklin transformers (H0-scale)
by Traindutchman 23/04/2021 17:20:33(UTC)
Old Marklin Transformers (Collector's Corner general)
by GG1 Fan 24/03/2021 05:54:57(UTC)
Marklin Transformer 67271 (Small scale)
by Carlos 20/03/2020 19:17:19(UTC)
Blue marklin transformer repair (H0-scale)
by Victor Almeida 01/11/2019 00:51:49(UTC)
Marklin Transformer No. 37547 A (General MRR)
by Albert Lind 19/01/2018 05:08:18(UTC)
Marklin transformers: 278A (16 VA) vs. 280A (30 VA) (General MRR)
by Albert Lind 04/01/2018 05:00:04(UTC)
Marklin Transformer 66185 (General MRR)
by sjbartels 14/10/2016 05:00:46(UTC)
Using a non marklin transformer or laptop PSU for CS 60215 (Digital)
by kpallund 12/11/2013 17:43:44(UTC)
Marklin Transformer 60055 (Digital)
by David1954 15/09/2013 02:35:04(UTC)
Marklin Transformer 60055 wire colors (Digital)
by Semaphore 30/06/2013 03:01:16(UTC)
Marklin Transformers (Digital)
by dandrikop 10/01/2007 13:20:04(UTC)
Marklin transformer controller 278A (H0-scale)
by steventrain 30/05/2005 00:29:19(UTC)
Marklin Transformer (General MRR)
by pjdlm 05/11/2002 00:15:09(UTC)
This page was generated in 0.242 seconds.
