9 Pages«<23456>»
Offline Jabez
#151 Posted : 21 July 2019 16:50:37(UTC)
Jabez
The Märklin that puts the legal hammer on anyone using their photos in German forums due to their copyright status, even when the photos actually help advertise/identify their products (no fair use in Germany).. will certainly go all Lego on anyones ass that attempts to make a 'compatible' track piece solong as their patents are in effect.
What about this third party C to flex transition piece then?
https://www.weichen-walt...ex.php?cPath=29_72_48_74
Jabez
#152 Posted : 21 July 2019 18:44:58(UTC)
I suspect since those are constructed using Märklin c track there isn’t a claim they can make. I don’t think you can claim inconvenient if someone uses your part to build something greater, just if they create your part directly.
Offline fynrfin
#153 Posted : 23 November 2019 19:53:43(UTC)
fynrfin
What do the very topmost and the bottom most paths give you? Seems they are redundant.
Yes you are right Minok, I don't need those - thank you for catching that.
Steen Jorgensen
Offline fynrfin
#154 Posted : 23 November 2019 19:56:05(UTC)
fynrfin
Hi Steen:
Originally Posted by: fynrfin Go to Quoted Post
I drew this up and it seems to work with all but two turnouts permanently shown.
What do you mean by "permanently shown" please?
Sorry I meant permanently "thrown" not shown
However, since the gurus on this site all use a figure 8 and not just one circle, I must be doing something wrong.
Sorry, I do not understand. What is wrong about having a circle instead of a figure 8?
Nothing, I just could not figure out if I needed a figure 8 or could make do with a circle. I guess I can
Steen Jorgensen
thanks 1 user liked this useful post by fynrfin
#155 Posted : 25 November 2019 21:39:53(UTC)
More from my parallel C track universe.
#156 Posted : 25 November 2019 21:46:56(UTC)
1x 24172
1x 24077
1x 24912
3x 24071
1x 2471x
2x 24649
3x 2461x
#157 Posted : 25 November 2019 22:47:41(UTC)
Why? Because I can.
#158 Posted : 26 November 2019 01:50:34(UTC)
Why? Because I can.
The Norfolk and Western railway (and probably Pennsylvania too) had many double track routes that occasionally widened to three tracks to allow faster trains to overtake slower trains.
Though in most cases it was simply both tracks merged into (and out of) the third middle track.
Offline rrf
#159 Posted : 28 November 2019 22:11:12(UTC)
rrf
My understanding is that all Pensy mainlines were three track. So it is quite reasonable to expect one and two track branch lines merging into three. BTW, I've been driving a lot over the last year in eastern and central PA (work). I've stumbled across quite a few old PA RR lines that support this premise.
Rob
Mackenrode Wende Bahn
thanks 3 users liked this useful post by rrf
Offline hvc
#160 Posted : 07 January 2020 02:00:39(UTC)
hvc
Apols if this has been covered before - I'm replying to a recent post and thought the content belongs here....
For transition from 64.3 mm track distance to 77.5 mm a common solution is:
But this can be achieved much more elegantly with the same number of pieces like this:
Here I show R3/R4, but you can substitute R4/R5 curves and it works the same.
Alternatively, if you have more space and are willing to use a little flex in the C-track, then this is even more elegant:
- Herman
- Herman
thanks 9 users liked this useful post by hvc
Offline hvc
#161 Posted : 07 January 2020 02:17:55(UTC)
hvc
and of course the solution doesn't have to be a 90 degree corner...
- Herman
thanks 6 users liked this useful post by hvc
Offline hvc
#162 Posted : 07 January 2020 08:15:31(UTC)
hvc
or even more simply...
and just one more, but with S-curve elimination...
- Herman
- Herman
thanks 5 users liked this useful post by hvc
#163 Posted : 02 May 2020 21:06:48(UTC)
Outer course:
24671+24107+24912+24912+24107+24672
Inner course:
24671+24107+24207+24130+24649+24130+24115+24672
#164 Posted : 08 May 2020 17:43:51(UTC)
Extended.
Offline Johnvr
#165 Posted : 08 May 2020 21:38:43(UTC)
Johnvr
Hello AK,
Just for some entertainment during lockdown :
How many trains can you run on this without an accident ?
RegardsBigGrin
thanks 6 users liked this useful post by Johnvr
#166 Posted : 09 May 2020 03:15:14(UTC)
Extended.
What ?? Lockdown driving you up the wall? Oh no, it's all right, its lying on the floor and Alsterstreek is hanging from a sky hook Woot RollEyes Smile Wink
Offline jrbburg
#167 Posted : 12 May 2020 20:20:23(UTC)
jrbburg
Has Marklin got this wrong?
Page 248 of the 2015/2016 Catalogue Suggests the DEBA3CCF-CEC2-4CB0-AE1A-A33D7E6EB905.jpeg
I hope the photo attached.
I’m experimenting with C Track and built this. The outer rails (24188s) are not flush with the 24172s. While I’m sure it must be me I can’t work out how.
#168 Posted : 12 May 2020 23:19:20(UTC)
Hello AK,
RegardsBigGrin
Hi John,
Nice test.
I think you could run 3 trains perfectly without ever meeting, because there are 3 contiguous but independent circuits in there.
Each is capable of running a train either clockwise or anti-clockwise.
Offline TEEWolf
#169 Posted : 13 May 2020 00:27:16(UTC)
Some documents about Maerklin's C-track system and its geometry. Hopefully you find out why it does not work for you.
Offline rbw993
#170 Posted : 13 May 2020 02:18:59(UTC)
rbw993
One mistake that I have made is mixing the 24130 and 24224's. They are about the same length but not interchangeable. Good reason not to use R1.
Roger
Offline Johnvr
#171 Posted : 13 May 2020 10:42:41(UTC)
Johnvr
Hello
Marklin have got it correct, and, yes, the outer rails will be flush with each other if done correctly.
RegardsBigGrin
Offline hvc
#172 Posted : 13 May 2020 12:11:36(UTC)
hvc
Hello
RegardsBigGrin
Agreed - it definitely works...
- Herman
thanks 2 users liked this useful post by hvc
Offline dickinsonj
#173 Posted : 13 May 2020 14:48:21(UTC)
I agree. I have two of these 2x24630 interchanges and the geometry works out perfectly. My only complaint is that some of my rolling stock do not like the 3-way turnouts but I find that taking them at a slow speed helps. Oddly my Big Boy and Challenger never have a problem, while several freight wagons with three axle trucks and a few locos locos do.
Offline hvc
#174 Posted : 13 May 2020 15:57:27(UTC)
hvc
Also, using the two 3-way turns is not very practical unless you want uneven length yard tracks - it might be more practical to just do this:
- Herman
thanks 4 users liked this useful post by hvc
Offline hvc
#175 Posted : 13 May 2020 16:09:56(UTC)
hvc
This kind of pattern gives you a space-efficient station throat from two track mainline to 5 tracks at the station, where both mainline tracks can go to any platform...
- Herman
thanks 10 users liked this useful post by hvc
Offline hvc
#176 Posted : 13 May 2020 16:16:13(UTC)
hvc
...but this can also be done without the three-way by adding a double-slip... I do really love how clever the two different length straight pieces are in C-track...
- Herman
thanks 7 users liked this useful post by hvc
Offline hvc
#177 Posted : 16 May 2020 11:29:45(UTC)
hvc
I'm curious what other people do in C-track for a station throat when using the high-speed (schlanke) turnouts. The case above is one I use a lot - a two track mainline, entering a station with 5 or 6 tracks (for me generally 4 platforms and a bypass track for freight).
So how do you do this with schlanke C track in the shortest space possible? The lack of a schlanke double-slip makes these structures very long. The only space saving thing I've done before is a schlanke Hosenträger, which is well-known:
in front of my 2->5 throat that makes:
It's interesting to use a regular double slip. The one below breaks my usual rule because the two mainlne tracks can't get to every platform, but it's not a bad compromise - each mainline track can reach 4 out of 5 of the station tracks...
What do others do? Do you have any pretty, amazing or compact ways to build a schlanke station throat?
Edited by user 16 May 2020 16:04:56(UTC)  | Reason: Not specified
- Herman
thanks 3 users liked this useful post by hvc
#178 Posted : 17 May 2020 10:18:35(UTC)
HI Herman,
How about the circled "slack" areas? Do the tracks connect in reality?
Offline hvc
#179 Posted : 17 May 2020 11:41:13(UTC)
hvc
HI Herman,
No they don’t connect - if you do exactly this you end up with a gap to fill. (Although you can get it to actually fit into if you make it bigger - by adding 077s from memory - I’ll look that up). I was more just trying to lead in to my thoughts about the station throat by using the left side of this.
- Herman
thanks 1 user liked this useful post by hvc
#180 Posted : 17 May 2020 13:15:15(UTC)
Since you went "hybrid" by introducing a not so slim double slip turnout, I enter the contest with this contribution. I took advantage of the slack C track is offering, and the arrangement is working with real C track (I have tried this before).
Six station tracks can be reached by both double-track mainline tracks. In addition, the concept is using the entrance curve, which might appeal to the average 4x8 ft baseboard model railroader. The shown segment measures 158 x 55 cm.
Edited by user 17 May 2020 23:40:50(UTC)  | Reason: Not specified
#181 Posted : 17 May 2020 14:47:30(UTC)
If one is not afraid of using a saw:
http://www.web-hgh.de/pp...C-Gleis-Hosentraeger.pdf
Another approach without using a saw.
http://www.heinzherrmann...mages/Hosentraeger_1.JPG
;0)
hvc
#182 Posted : 17 May 2020 15:32:23(UTC)
This one...:
...in black and white:
hvc
#183 Posted : 17 May 2020 15:44:07(UTC)
Like this, I suppose?
Offline hvc
#184 Posted : 18 May 2020 09:51:22(UTC)
hvc
I went back and found it - and no! I previously had this for a hacksaw-free solution:
So that I could do this...
- Herman
Offline hvc
#185 Posted : 18 May 2020 09:52:56(UTC)
hvc
Also, I want to "like" this more than once! Love it.
- Herman
Offline hvc
#186 Posted : 18 May 2020 10:07:36(UTC)
hvc
and so another place I end up is here - still one track that each mainline can't get to, but good for those who like straight lines and symmetry :-)
- Herman
Offline hvc
#187 Posted : 18 May 2020 10:11:20(UTC)
hvc
and could maybe fill the gap with a run-around track - although this one doesn't fit exactly and I'll try and build it to see if it really works...
- Herman
Offline hvc
#188 Posted : 18 May 2020 14:40:08(UTC)
hvc
No others takers so far, so here's one I came up with this evening... both of the mainlines can reach any of the six platforms
- Herman
thanks 8 users liked this useful post by hvc
#189 Posted : 18 May 2020 22:50:12(UTC)
No others takers so far, so here's one I came up with this evening... both of the mainlines can reach any of the six platforms ......
Wow - that looks like Kings Cross, London.
#190 Posted : 19 May 2020 13:03:43(UTC)
Looks somewhat familiar :
and no comments about the current unfinished utility area on the left please AlanFlapper
thanks 7 users liked this useful post by PJMärklin
Offline hvc
#191 Posted : 21 May 2020 07:29:55(UTC)
hvc
The perfect example of why I miss the schlanke double-slip in C track. This is exactly what you would do (love your layout), and if you look at my plan above the two wonky curved "arms" leading to the outermost platforms are only necessary because the schlanke double-slip don't exist.
- Herman
- Herman
Offline black_pete
#192 Posted : 28 May 2020 16:02:06(UTC)
black_pete
And here's today's dumb question BigGrin
Just wondering whether anyone has any experience of the visual difference between the 74470 Turnout Lanterns and the newer 74471 Warm White version ?
I guess the warm white LED's would be a little less bright and a bit more subdued when lit.
Oops ... just noted that it seems these aren't deliverable from Marklin yet Blushing
Edited by user 28 May 2020 22:33:12(UTC)  | Reason: Additional research ...
Pete
expat Kiwi - now living in Melbourne
SBB Era IV & V - Digital - CS1 - C Track
Offline applor
#193 Posted : 23 July 2020 00:55:12(UTC)
applor
I've designed this station throat for my Dads layout loosely based on AK's design.
However there is one track piece I can't reconcile though it is very close, perhaps someone with the track pieces can confirm if it works IRL?
Offline applor
#194 Posted : 23 July 2020 00:58:00(UTC)
applor
And likewise at the other end I have one piece that isn't quite 100% but I think it should be OK:
#195 Posted : 23 July 2020 09:29:56(UTC)
Trimming track is one thin, but you are not honoring the Marklin R9 (sic) geometry
Edited by user 24 July 2020 22:18:36(UTC)  | Reason: Not specified
Offline hvc
#196 Posted : 23 July 2020 15:33:40(UTC)
hvc
Trimming track is one think, but you are not honoring the R9 (sic) geometry
Indeed - there are 24071s missing at the places indicated.
applor - if you do this you'll have to cut the track ballast out on the tracks at those spots. Or did you miss out the 071 tracks by accident (which is a mistake I make all the time) , in which case the plan will need some re-jigging as per clapcott above.
- Herman
Offline applor
#197 Posted : 24 July 2020 00:28:37(UTC)
applor
Yes I just missed a couple of 071's by accident, thanks for pointing that out.
Offline hvc
#198 Posted : 24 July 2020 05:28:45(UTC)
hvc
On the good news front, I built enough of this to confirm that the circled red section does work in real life...
Note however there is a different problem - the turnout mechanism circled in yellow fouls with the other track so that you can't attach the turnout. By removing the adjacent R3 turnout filler piece I was able to bend the 315 piece a little to get it to fit, but I can't put the filler piece back in (you see it lying next to the track in the photo). You could solve it by cutting down the turnout mechanism a little, or you need to mess with your plan a bit...
- Herman
- Herman
Offline hvc
#199 Posted : 24 July 2020 07:25:07(UTC)
hvc
Also, you've used a crossing rather than a double-slip here. If you use a double slip this will give you better access across the tracks. On the other hand, if you don't care about this and are happy with a crossing, then here's a version that maintains schlanke angles and min R3 radius...
- Herman
Offline applor
#200 Posted : 25 July 2020 05:05:10(UTC)
applor
Thanks Herman. Yes I intended to use crossover, don't want to use the C track double slip until they introduce a wide radius version.
I have however come up with a revised plan in any case and no joining issues on the plan and perfect track access. I can post it Monday if interested.
Guest (12)
9 Pages«<23456>»
This page was generated in 1.230 seconds.
